Question about RCA D52W19 52" Rear Projection Television
Horizontal problems Not all channels are scrambled with horizontal lines. Only channels 22 thru 48. Other channels are perfect. Is there any control on the TV that can correct this problem. Have had cable service here and they said it is the TV. Have connected another TV to the cable and picture is perfect. Cannot understand, if it is the TV why aren't all the channels blurred with the horizontal lines? PLEASE HELP!!!
  • Cateye Jan 16, 2008
    Not sure what abbreviations indicate for solution. If someone can
    respond I would appreciate it. Thanks.
Its may due to problem on IFsection or tuner,afc problem
Posted on Jan 16, 2008
How can i solve horizontal blue linecollapse screenI think, but sound ok
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
Line, faults & possible causes are given with illustrations. You can get an idea about the fault to an extent.
Aug 06, 2015 | Televison & Video
Wavy horizontal lines across the screen
It sounds that the main power supply section to your TV has the fault. The horizontal thik lines that appears crawling down across the screen should be of video 'HUM'. Have you replaced the main filter capacitor at the power supply section? If not, replace it along with the main rectifier. The AC power is rectifed by a bridge and applied ot this main filter capcitor. It will have a capacitance value between 120 to 350MFD 450VDC. Check this section. Measure the rectifed DC voltage acorss this main filter capacitor. It should be around 350VDC, if your home power supply line is 220VAC. If it is 110AC, this DC voltage will be around 165VDC; and it should be. If rectified DC voltage found lower than the input AC voltage, replace the rectifier bridge. In some sets, this bridge section have four diodes. Some other circuits, a bridge rectifier stalk may be used.
May 20, 2012 | JVC AV-27050 TV
Hi i have the sony kv32fs120 the tv wont turn on the stand/by timer blinks but no picture tried to unplug for 5 min but it didn't work any advice. thakyou anthony
Possible failure in the horizontal section of the horizontal driver or the failure of the line output transformer.
You will have to disconnect the +B to confirm if the SMPS gives the power.If so check for short in this section .
Sep 30, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Samsung Plasma Lines and Colors on Screen
yes it can fix. its only loose connections from LCD connectors. trust me.
May 29, 2009 | Samsung HP-R4272 42 in. Plasma HDTV
PJ458D Displays Multiple Lines and scrambled picture
White noise-the image you get when you turn your television to a channel that isn't receiving a signal. Sorry, this is an old term for on-air televisions. Its kinda the same image you get when your DirecTV signal gets scrambled during a thunderstorm.
Sep 20, 2008 | ViewSonic PJ458D Multimedia Projector
Scrambled picture
Which caps on which boards as that sounds like a issue with the signal and FMT PCB. The v26 chassis like yours has problems with bad caps on the DM, Signal, FMT and the PWB and terminal
Jun 28, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Hitachi 51GWX Scrambled Picture
STK392-560 STKS convergence CHIPs Replace both of them.
Feb 24, 2008 | Hitachi 51GWX20B 51" Rear Projection...
Cable setuo for model 27r410t
Get an antenna hooked up, even rabbit ears should pull in a few analog channels. Set top boxes will only output Ch 3 (switcheable to ch 4 on the back if needed) and cable may be dead or only give you scrambled CATV channels. You need to set your tuner to "antenna", not CATV, IRC,HRC, or ATSC (if you have a digital tuner) and do the setup again. You could have a bad tuner at worst, and all is not lost, just hook up a VCR via RCA cables and use the VCR tuner to change channels. Keep TV on Ch3.
Feb 12, 2008 | Televison & Video
Green Patches and Horizontal Line
its your ccd chip,, its broken,, u can let them repair it but its cheaper to buy a new one,, your ccd chip does not show the manufactor on your screen but it controls the colours of your photo, so u only can see this when u took the picture,, and for some reason the video does not need the ccd chip,, the ccd chip is only for the photos u gonna take,, hope i helped ya
Oct 01, 2007 | HP Photosmart R707 Digital Camera
Horizontal 'pinstripe' lines on all channels
sound like the screen control on the flyback is set just a little too high. the flyback has the red wire attached to the tube. the flyback has 2 small adjustable controls. if you look close enough 1 is marked focus & on is screen. turn the screen slightly to the left & look at your picture. the screen is like a master brightness & if it's up too high you will see what is called retrace lines. good luck.
Jan 16, 2007 | Daewoo DTQ-20N3FC 20" TV
RCA D52W19 52" Rear Projection Television Logo
63 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
