Question about Sony Ericsson W800i Cellular Phone
Camera Problem Every time i take a picture it returns back to the main screen without taking a picture, it focuses and makes the shutter sound but no picture.... Video works fine. I have tried turning the phone on and off, still the same. I have tried updating the phone through SEUS, still the same. I have tried formating the memory stick, still the same. Can you help?
Re: Camera Problem
I used the solution mentioned in,1.html
there one guy says
"I experienced this with my w810 ONLY WHEN : I tryed to take a picture with lot of details on screen in FINE mode. I switched to normal and it tooked the picture without problems. "
it worked for me too. better than taking it to a service station!
Posted on Jan 25, 2008
0 characters
3 Points
IPhone camera doesn't work. Screen goes black. Doesn't save pictures.
That sounds like a software problem not saving pictures but does the shutter open up at all? Did the camera ever work or is it only recent that the problems are happening? I would suggest that you back up your phone then restore it back to its factory settings, after that sync it as a new iphone as any past bugs would just be reinstalled into it and cause the same problems. The latest software would then be installed in the iphone at the same time. Try not to download any apps for a day or so and see if that makes any difference.
Dec 27, 2010 | Apple iPhone Smartphone
Sometimes when I want to take a photo my phone indicates that camera is on standby and camera does not work. When I take a photo the phone shows :"operation failed" and then freezes up for a couple of...
nothing is wrong with the phone, it is a normal function in every phone. If u leave the camera open for some time, it will go on standby mode, u have to turn it off. so better is that the moment u take a picture and there is a gap in taking the other picture, u turn the camera mode off. when u need it again, then again put it on.
Sep 12, 2010 | Nokia 6303i Cell Phone
Picture taking problems
if phone doesn't have free shared memory(ram not the memory stick) it will not save u're pictures. try deleting and free u're main memory
May 30, 2010 | Sony Ericsson K800i Cellular Phone
this is quite normal with all samsung. u have to hold the phone for a second longer to get the perfect picture.. otherwise if still in dought format ur cell phone..
note: you need to take out the sim card first before you do this. put it back only after the phone restarts.
Aug 12, 2009 | Samsung S8300 Ultra Touch platinium-red...
RE: LG CU920 camera focus problem
Press the shutter button partially down and hold it there. The image centering box will turn green momentarily and then you can take the picture and it will be clear. I almost returned the phone because the pictures were blurry before I figured this out.
Jul 09, 2009 | LG Vu CU920 Cellular Phone
About camera shutter sound
HI Maddy, You can turn off the shutter sounds in teh settings menu. This will turn off the sound altogether so not ideal but at least a work around.
Oct 28, 2008 | Sony Ericsson K750i Cellular Phone
Camera Problem, Need HELP...
hi friend. better u try to flash your mobile with R1CA021 firmware
Apr 11, 2008 | Sony Ericsson K750i Cellular Phone
Camera on a W375
I had the exact same camera blacked-out malfunction. I followed booj's advice and it cured the problem. What I did: I turned off the w375 phone by pressing and holding the red button (not just closing the clam shell, like I normally do), after the phone powered down, I restarted it by pressing and holding the green button. After it powered up, the camera at first had the same black screen, then, all of a sudden, the view finder started working normally and it now takes pictures correctly. - MGB
Feb 02, 2008 | Motorola Mobility W375 Cellular Phone
Won't take pictures
the solution for your prob is...
1-connect ur mobile with your PC.
2-open the file manager
3-then open pictures
4-now the folder which camera photos save
delete that folder
5-n make new folder n give that same name to this folder (which named folder u hv deleted)
6-now u can use ur camera properly.
good day
Jan 30, 2008 | Sony Ericsson W800i Cellular Phone
Sony ericsson w580i camera problem
I have found a solution to this problem without sending your phone back and/or paying to get it fixed. Now you can do this on you own personal computer and only takes around 5-10 mins depending on your internet and computer speeds. Ok below are some simple instructions to follow. Please give me a 'Fix ya!' if i helped :)
1. Go to either - to view some information on updating your phone or go to - to download the application straight away.
2. Once you have downloaded and installed the program, open it, the program may download program updates and such - this is normal.
3. Once everything is open it will ask you for your language, so in my case, English (United Kingdom) and just follow the on screen instructions, everything basically self explaniary.
Note: This will wipe everything off the PHONES memory, take your memory card out to make sure you dont lose anything off that. If you think this is going to be a waste of time then you're wrong as this fixed my camera problem..
Also note: It will say your phone has the latest software installed, just click continue anyway as this will wipe your phone and install everything again, FIXED! :)
Hope I helped.
Dec 29, 2007 | Sony Ericsson W850i Cellular Phone
Sony Ericsson W800i Cellular Phone Logo
110 people viewed this question
Top Sony Ericsson Cell Phones Experts
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
