Question about Bose Acoustimass 15 System
Same problem with woofer
I tried plugging into different outlet still nothing. I think I might take it in for service because I have run out of ideas and hearing a movie without the bass is terrible. Do you have anymore ideas I can try.
    Champion:
  • 238 Answers
Hi, to test the woofer , u take a 1.5 v battery, put one end of the +ev on one terminal and tap the -ev on the other and notice if u can hear a clicking sound as u tap, if not than the speaker/woofer coil or the cross over curcit is open, let me know,
Posted on Jan 13, 2008
Why does the fuse blow Instantly?
Link for the service manual: http://elektrotanya.com/pioneer_vsx-305_405.pdf/download.html On page 50 of the manual (36 of the pdf) it says for the "Sub woofer pre-out jack (Not available on the VSX-305 model) If you want to boost the low frequencies, connect to a subwoofer power amplifier" Your model will not drive a sub-woofer with out another amp. His sub may be a powered sub?
Aug 31, 2014 | Pioneer VSX-305 Receiver
Mcd 1311st blowing circuit breaker
Generally microwaves should be on their own breaker. Hard wired ones are required to be by code.
If yours has a plug - make sure the plug is original with the unit, not added later or spliced onto hard-wired power leads.
Plug into and outlet rated 15A as the only thing on a 15A branch circuit and try again. If it still trips, try a 20A line and circuit. If it trips that, trash the microwave and buy a new one. Nothing is meant to be repaired inside.
Nov 03, 2017 | Microwave Ovens
My son accidentally plug a 110v bose 3-2-1 to a 220v outlet. What do you think is the damage? Do we still need to send it to a service center?
If you are lucky you would have lost the fuse on the sub woofer module which powers the whole unit. If not, yes you will need a qualified technician to look into the matter because its not a small offense to plug a 110 device into 220v.
Jul 06, 2011 | Bose 3 2 1 GSX System
Can`t power it up. Connections and fuse OK. Stopped working after switching off and would never switch back on. LED indicator light`s neither green nor red but simply off.
First, I have to commend you for having a really fine piece of equipment. Mission makes great products. Now down to business. Being where I am and not being next to your sub-woofer with test instruments and tools I'm going to be so basic as to almost be insulting. However, If I were there, I would be testing these things.
Normally, when one has a catastrophic failure. i.e. no power, and no indication of power present one starts with the power supply. And that starts at the power company.
1st Determine if there is power in the actual outlet that the unit is plugged into. I have found that when installing a sub-woofer on a two plug wall outlet, for example, it might be plugged into a plug intended for a floor lamp. and is turned on and off by a wall switch. Many residences have this feature. It is usually one of the two plugs in an outlet. So you have to test the actual physical outlet. If the outlet is off, check the light switches. If there is no power to the outlet, check the household circuit breaker.
Let's assume that everything works, so far.
The next thing to do is check the internal fuse with a meter. If you don't have one, pick up a multimeter from Radio Shack or Walmart for less than $20.00 or Harbor Freight for less than $7.00
If the fuse looks good but checks out bad (sometime happens) replace it with A FUSE OF THE SAME VALUE. DON'T STICK IN A PIECE OF ALUMINUM FOIL OR BYPASS THE FUNCTION AND PURPOSE OF THE FUSE. The fuse costs a dollar, at the most, the Sub-Woofer costs $800.00 at the most.
OK, so now you have either a working sub-woofer, or an elegant paper weight.
If it is still being a paper weight, contact mission to locate an authorized service company. This piece of equipment in not designed to be user servicable
Here is their link below,
I hope this helps,
Best Regards,
Mark
http://www.mission.co.uk/Default.aspx?lang=En
Jan 20, 2011 | Mission M5AS Subwoofer
It will not power on
henrylshelt,
Your sub should turn on into standby mode when plugged into AC power without being attached to the receiver. If it does not follow the list below. If it does, the sub needs a signal from your receiver via either by line-level (RCA) or the speaker wires to turn on out of standby. Ensure that the cable or wires going to your sub is in fact sending a signal while the receiver is on. To Test, (speaker wires) hook up a different known working speaker; (line-level) Some receivers have a menu option to turn the LFE output on and off, ensure that it is on and producing a signal.
Diagnose the problem:
1) Remove all wiring to/from the unit except for the AC plug (use a different known working AC outlet), will it turn on? If so the other outlet is not working.
2) Remove the woofer, does the amp have a fuse that need to be changed? Change the fuse. If it blows again after replacing and turning back on, the speaker is blown; go to #4.
3) Unplug the woofer from the amp, does it turn on? If so, go to #4.
4) The sub need to be serviced. http://www.jbl.com/EN-US/Support/Pages/SupportOverView.aspx
-Hope this helps, Chris.
Aug 29, 2010 | JBL PSW-D112 Speaker
I have a Goldstar GHD30 dehumidifier. I have not used it in awhile. I plugged it in to run it today and it does not turn on. I cleaned the screen and tried different outlets, nothing works. HELP!
Check the condensate collection bucket. If the bucket is not inserted correctly the dehumidifier might think the bucket is full and thus not turn on.
Aug 30, 2008 | Goldstar DH504EL Dehumidifier
Infinity 3.5c , 2 powered Woofer 5.25" suddenly no sound.,
The woofers on my 3.5c stopped working, but with mine the light was off. I unplugged it and left it for about 24 hours and then plugged it back in and it worked. No idea why. It's happened twice and each time takes at least 12 hours or a day or so before it'll work again, just unplugging it for an hour won't do it.
It seems like both times the problem started when the speaker got unplugged without it being shutoff first, but I can't confirm.
But if your light is still on it's probably a different problem. With my 4.1t towers when the light was on but there was still no sound it equated to numerous fried amp components which cost about $150 for repair.
Oct 31, 2007 | Infinity Intermezzo 3.5C Center Speaker
Bose Acoustimass 15 System Logo
110 people viewed this question
Top Bose Audio Players & Recorders Experts
jjcicala
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
