Question about Canon imageRUNNER 400S Copier
Minolta Konica 7145 error code 26-3
My copier has been in storage for about a year and now that I've plugged it in it gives me the error code listed above after it starts up.
  • 3 more comments
  • Anonymous Jul 01, 2008
    machine is not taking a toner automaticly
    machine is not taking a toner automaticly and 26-3 is comming
  • Anonymous Aug 10, 2008
    same problem 26-3
  • Anonymous Mar 20, 2014
    C 5014
  • Anonymous Mar 24, 2014
    c2563
    Genius:
  • 1,003 Answers
NOT SURE BUT YOU CAN GET SERVICE MANUAL WITH ERROR CODES DEFINITIONS www.precisionroller.com type in your model
Posted on Jan 13, 2008
How to remove minolta 7135 code E 56-1
replace the image control board, all check all connection to printed circuit board remove each connector seperately and check for a bent pin
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Oct 11, 2016 | Konica Minolta Office Equipment & Supplies
Konica 7145
fuser code hot part replace it
Apr 13, 2014 | Konica Minolta Konica 7145 Minolta Bizhub...
Konica error code f-51-6
try to reinstall the driver from CD you've when you buy the konica.
or you can download 3DP Chip v11.12 from Mediafire
Open it,and you will found Your driver like Example on the screenshoot,and Click it,you will Redirect to the Driver you've need.
Please don't forget to rate it if this helpfull.
Jan 05, 2012 | Konica Minolta 7145 USB Driver for ISW
My konica minolta bizhub 7145 b/w copier is showing error code F-51-5 The copier will power up and then seize. The copier is about 5 years old with a total count of 320,000 copies
Hi the problem is going to be with the M1 motor most of the time replacing this motor will fix the issue However in rare cases if it still gives you the same error after replacing m1 motor then you will need to change CB Main Body control board my advice is to replace the motor and if it still gives error code replace the cb board but it will fix your problem
Mar 09, 2011 | Konica Minolta Bizhub 222 Black and White...
What are codes F-34 and F-35?
These are heat sensor abnormality error codes in Konica Minolta 7222/7145/7135/7235/7228 models.You did not mention the model.
Oct 04, 2010 | Konica Minolta Bizhub C300 All-In-One...
Konica 7145 Legacy Print Driver
konicaminoltaus.com has a complete list of the drivers for download on the site
Oct 09, 2009 | Konica Minolta Office Equipment & Supplies
I HAVE A KONICA 7145 COPIER ANND HAVE THE E-56-1 COPIAR
this code means the system control board and the main control board are not communicating with each other. the new main boards have modified to prevent this code. to reset the code turn the main switch on the left side of the machine off for about 10 seconds then back on
Oct 04, 2009 | Konica Minolta Office Equipment & Supplies
Konica 7022 with Problem code F-26-1
There is toner/starter spilled onto a sensor near the drum, it mite just need to be cleaned, this sensor monitors the drums abililty to develope a image, if the cleaning does not work it mite be the sensor or the drum. The drum needs to be removed to clean the sensors.
Mar 23, 2009 | Konica Minolta Office Equipment & Supplies
Eror code 82-2 konica minolta 7145
eror code f_26_1 konica minolta 7145
Feb 23, 2009 | Canon imageRUNNER 400S Copier
Canon imageRUNNER 400S Copier Logo
952 people viewed this question
old marine
old marine
