Don't heat up
Sheri, This says that you have an electric dryer and that it fails to create hot air. It can be 2 issues. (1) the electric heating coil (behind a panel in the lower back of the dryer) has broken and must be replaced or (2) the air duct work inside the dryer is clogged and the heated air is unable to pass through the dryer.
If you are sure that air is flowing, the it is the coil and to replace it, remove the panel screw and locate the 2 mounting screws for the heating coil. Remove it and take it to your local appliance parts place and ask for another. Insert that, connect and fasten as the original and you should be of and running
