Hi i cant connect to internet
Hi i got a zyxel nbg334w wireless router ive plugged it in and installed it and it worked for a couple of days then i had to unplug as i was moving computer now it will not let me connect to internet it keeps say limited or no connectivity but if i just use my modem i can get on the net i bought the router so i could use xbox 360 on live the leads go from pc a blue ethernal lead from pc to router then a yello 1 from router to modem then internet lead to modem any ideas y i cant get on?????????
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 198 Answers
I don't know why this is posted in UPS problems, but anyway...
Try two things--the easiest is to turn off (unplug from power) your router and your modem. Let sit a few minutes, turn back on, then see if that has done the trick.
If that doesn't work, you may simply need to go to network and sharing center if you have Vista, click on "connect to a network", and see if your router is found as a wireless connection available to you. If it is, just click on it, and you are in business. If you can't find your router via the windows utilities, (various other things to do are in "help"), you may have to
reconfigure your router setup by resetting your router to its virgin state--usually by pushing a paper clip into the reset hole in the router--usually mentioned in the directions. Then just reconfigure it according to directions, and you are in business.
Posted on Jan 13, 2008
6ya staff
SOURCE:
I have connection between my mac 10.4.11 and the zyxel router and I have connection between the zyxel router and an old compaq desktop upstairs but I cant access the internet, which is last mile. Ive...
dchp problem. sounds like the modem is doing dhcp that's why it works plug in directly. disable the dhcp server in the router go to Network > DHCP Server > General in the router and disable it. only the modem or router can do dhcp.
Aug 02, 2017 | Zyxel NBG-417N Wireless Router
Forgot my SSID and password. how to make it work again
Best option is to log into the router and make a new one.
Plug the router into your computer using ethernet.
Open interent exploer and type into the address bar http://192.168.1.1
Username: admin
Password: 1234
This may be of some help to you
http://www.zyxel.co.uk/upload/doc/NBG334W%20User%20Guide.pdf
Apr 25, 2011 | Zyxel (91-004-361002) Wireless Router
I have zyxel nbg334w bought before xmas 08 can connect pc to internet with it but although wireless laptops and games consoles find it still wont connect i am connected to internet via virgin media...
Had the same problem connecting zyxel NGB334W to XBox 360. Other computers and devices would see the SSID but the XBox 360 would not. I had no luck talking to the techs at zyxel, they said it was incompatible with the wireless XBox device. Good news!!! This can be resolved. I went into the setup (192.168.1.1) / Wireless Lan / Advanced / Wireless Advanced Setup. Under the 802.11 mode set to 802.11b. Factory is 802.11b/g and this was not seen. Hope this helps you out.
Jan 30, 2009 | Zyxel Prestige 334 Router
Zyxel nbg334w router configuration
Hi
To configure the wireless router it is recommended the it is connected directly to router.
Please follow these steps to fix your issue
1. Reset the router using reset button on the back of the NBG334W router
2. Configure or change the laptop ehternet adaptor setting to "Obtain IP address automatically.
3 connect laptop and router using ethernet cable. check the ip address using ipconfig command in DOS prompt. If IP address is 0.0.0.0 or 169.X..X..X run command
ipconfig /release
ipconfig/ renew
best way restart the computer
4. if you still have issue in getting ip address double check ethernet cable and try reseting the router again.
5. Still problem persist install new firmware on the router. you can download router firmware from
http://www.zyxel.com/web/support_download_list.php?indexflag=20040906164737&ModelIndexflags=0,420070320142921
Please vote if this information is helpful in resolving your issue
Dec 27, 2008 | Zyxel Prestige 334 Router
Configuring nbg334w router
ipconfig /release
ipconfig/ renew
Got a ZyXEL NBG334W wireless cable router and trying to set up on my computer, everytime it says cant find dns server.
1 Install your software that came for NBG wireless cable router CARD DRIVERS.
2 Now INSERT your NBG wireless cable router CARD in your PC
3 Window will say found new hardware.
4 Now Insert your router DISK and open your Internet Explorer
5 You should have your default ROUTER IP ADDRESS
YOU MIGHT HAVE TO SIGN IN OR PROVIDE PASSWORD
Jul 15, 2008 | Computers & Internet
Installing wireless router
um is it compatible with vista and/or upgradable?
Jan 15, 2008 | Zyxel Prestige P-330W Wireless Router...
Trying to configure zyxel nbg334w router
If the router will not connect to the internet, you will need to create the PPPOE internet connection with the username and password that your ISP provided. BPCS
Dec 28, 2007 | Zyxel Prestige 334 Router
Zyxel cable router nbg334w
same ere until one it worked im not telling you how cus its long and i cant b bothered
Dec 27, 2007 | Computers & Internet
Open Questions:
Computers & Internet Logo
97 people viewed this question
Ekse
Marvin
Marvin
