Question about ASUS P5PE-VM Motherboard
PC won't start - most probably a motherboard problem.
I understand that this could be due to overheating. what can be done? is my motherboard damaged for good? this already happened before with my P5V800-MX motherboard and now it happened again with my P5PE-VM.
here are my specs:
Pentium IV 2.80 GHz 533 MHz FSB 1 MB L2 Cache
512 MB PC3200 CL3 184 - Pin DIMM
64 MB GeForce4 MX
I have 2 IDE HDD's:
a 40 GB Samsung
and a 20 GB Fujitsou
I have an LG 16x DVD Writer
2 aux fans and a floppy drive..
that's about it, is it too much of a load? oh and I have a 500-W power supply.. a mitsui AVR and an EMERSON UPS.. please help me.. what's wrong? what could be wrong? and an aditional info, these are all the specs I used with my P3V800-MX board..
  • 5 more comments
  • bLyCheE Jan 12, 2008
    on my previous board, nothing happens at all.. on this one, the led (power led) lights up for half a second then nothing.. so, it's completely dead..
    no recent hardware changes.. actually, i was right here in my room when my PC went completely dead.. i didn't touch it though.. but it was on (running) the whole night last night and this happened around 10 AM today (it's 11 PM in my place now).. i was using my laptop and the PC just went dead.. (PC and Laptop is not networked..)
    thanks for the quick response..
    nope.. my CPU works fine..
    yes jmorgan123, i did that.. and ohiotom, i have an extra power supply lying around but still it won't start..
    sorry about that.. accidentally clicked on it.. peace..
    ohiotom, ive tried the solution on your link, my PC started now after disconnecting all the mini drive power supply connectors.. i will now attempt to connect each mini drive..
    i just found out that it was my 2nd HD that has a short probably.. after replacing the power on each drive, (rom,floppy,and first HD) it was the 2nd HD where it did not switch on..
    im really sorry coz im new to this.. it was my first time asking for help here on the net.. but i think i have read here somewhere that u could be payed for helping.. that would mean being to have an "expert" rating on this site..
    what i didn't know that ratings were really important to you.. i'm sorry, how insensitive of me.. but i didn't upgrade your rating cuz u ranted about it.. i did because it really was helpful and yeah, i think it fixed my problem..
    i was only trying to rate how your comment really helped.. so i think "thanks for trying" means literally thanks for trying..
    but if you read my first post carefully, though i didn't specify it, i did mention that the specs were still the same and only the board was changed.. so it meant that power supply and processor, etc. didn't have a problem.. that's all..
    thank you so much ohiotom..
  • ohiotom May 11, 2010
    When you say it won't start, does anything at all happen? Do you hear any beeps or hear the fans turn for a moment or is it just completely dead?
    Did you change anything recently or did this failure occur with no recent hardware changes?
I think its the power supply... i have the same problem right now. but i just cant get it right. me and my friend mark tried to fix my pc. we checked every wirings, clean the memory, check the processor, and everything. now hear this, we switct it on. the motherborad lights up, the cd rom works, the HDD run, fans are spinning, keyboard and mouse lights up... but no video output!
after a bit of trials and using the pcs parts to another pc to check if theyre work or not. yet all remoavble stuffs work in another pc. even the board. after a 2 hours of these.. we fix it all together then suddenly it just work! what was wrong with it? my power supply is 600watts with dual fan. my board is a asus pvp5 asus with 512 ddr and 40 gb hdd, no vdcard, dvdwriter.
im just sharingmy problem, just for referal. hope u can help me too.
Posted on May 15, 2008
Coincidentally, I am having the same problem, although slightly different. I can boot up after many tries, but once in Windows, it will freeze after a while. I had the CPU temperature error before for many months but ignored it and it was fine until now. My mobo is P5P800, which I think is similar to the mobos you have. And I have a Pentium IV 3.00 GHz. I have sent it out to some technicians to be diagnosed and still waiting for their response. After doing some reading on the net, i think it could be due to either the PSU or CPU fan (which I didnt realised before). My CPU fan was quite dusty - I believe your one is too, bLyCheE? might be worth a try to change it. If the PSU or CPU is not the problem, then i think my mobo is.
Posted on Jan 17, 2008
    Problem Solver:
  • 14 Answers
Try this. Re-seat the video card, reseat your memory modules. Unplugg all USB cables. ethernet cables, power cables, and reset your BIOS by finding the reset jumper on your motherboard. Now plug in your keyboard, mouse and power cord. NO USBs, now try and start computer, it if starts replug USBs one at a time after computer is working. If no power up, are you getting any beeps? Possible causes for computer to try and start for a second and immediately power off.
1. Short Circuit (Motherboard touching chasis)
2. Bad power supply
3. Bad/stalled USB device plugged in.
4. Bad connection on Video Card / Memory Module (Corrosion?)
5. Bad Video Card / Bad Monitor
6. Look at the pins on the VGA connector and make sure there are none bend creating a short.
I hope this works for you!
Good Luck!
Posted on Jan 12, 2008
  • 205 Answers
It could be the power supply, the motherboard, or the processor. And, unfortunately when the power supply goes it can take out the motherboard and processor too.
The easiest of these three components to test and rule out is the power supply. If you have another power supply around that has both the 20 pin ATXPWR and 4 pin ATX12V connectors you should try it.
If you don't have another power supply lying around, disconnect every power supply cable from the motherboard and all components and check out this link:
Try this technique and see if the power supply fan turns. If it does then the power supply is probably good. If the fan does not turn then your most likely problem is the power supply. Hopefully that's the case because it will be the easiest and most inexpensive thing to replace.
Good luck and let us know what you find.
  • 1 more comment
  • ohiotom Jan 12, 2008
    LyCheE, you may not realize this, but jmorgan123 and I don't get paid for this or anything. We just like trying to help. I'm sorry it looks like your motherboard is shot, but I have to say it's disheartening for you to ask for help and then rate us with a "Thanks for trying" when you did not tell us you had already tried our suggestions in your original post. If you had told us everything you had tried then we would not have suggested these your rating has lowered both our scores. Just my 2 cents.
    Thanks for upgrading my rating....
    You are very welcome and I'm happy you got your problem fixed. I appreciate your explanation and there are no hard feelings.
    This website is a funny thing. In some ways I wish there were no ratings at all. It's become a sort of a hobby for me and it is very rewarding for all of us who post solutions when we can actually connect with somebody and help them. Unfortunately the internet is anonymous and anonymity can bring out the worst in some people. There's no shortage of people who never reply or give bad ratings and it's very frustrating when we're just trying to help.
    But again, I'm glad you're on your way and thanks again for your comments.
  • 317 Answers
So are you saying that there is no video on the display at all? Just completely black? I have ran into this several times and 95% of time it's a burned up CPU. Replace the CPU, you can probably find one pretty reasonable on ebay and it should work fine. It's possible that it's also the MB as well, but I would bet on the CPU.
  • Peter Burns Jan 12, 2008
    So you've taken the CPU out and tested it in a working system?
    So, it sounds like you've narrowed it down to the motherboard. Everything that it could be, we know is working now, so it would have to be the motherboard. The only other possibility I could thing would be the video card, but not likely.
    Why the inappropriate rating? I'm only trying to help you with your issue.
Graphics fails
Graphics cards can fail due to age - but very often due to overheating - like using on carpet or duvet or some soft surface that can block the air-vents.
Sometimes the card can be replaced - but most often its the whole motherboard.
Not something i think you can fix if I understand the question correctly - you will need bring it to shop to be looked at.
Dec 20, 2013 | Dell Computers & Internet
Overheating and shut down d915grv
CPU/ Processor resources and due to the heavy processing the PC heats up. Excessive heat up beyond usual is alarming and PC shuts down by itself when the processor/ CPU temperature exceeds the safe temperature limit. There are mainly two reasons for heat up.
Heating issue generally occurs due to fan failure, which may damage the system, if not checked properly. Another most likely cause of overheating is the dust present inside the PC, which clogs the fan and heat sink.
1. Make sure the fan is running. (if not, it needs replacement)
2. Clean the fan and heat sink (thermal module). Take out the fan and heat sink. clean them with the help of tooth brush and put it back.
3. Also, make sure that the PC is placed in a well ventilated environment and the air flow the the PC is correct.
The procedure is very simple and I believe immediate action is required to prevent any damage to your machine and data.
Hope it helps! Good Luck!
Thanks for using Fixya!
May 27, 2013 | Intel D915GAV Motherboard
My HP Pavilion dv6830US Notebook overheated and now won't turn back on. What can I do?
I would start by cleaning the fan, vents and heatsink. Use a can of compressed air. You may have to open the Laptop to clean thoroughly with the air and a light brush, use ESD protection as well. . Improve air flow from the bottom of the laptop and the side vents, a Laptop Cooler is a option. Hopefully you haven't done damage to vital components due to overheating. Unplug, remove battery, leave battery out, plug in, try to reboot.
May 26, 2013 | Computers & Internet
Problem with Toshiba laptop
It stays on with Battery? Has the AC jack been damaged due to pulling on the cord while plugged in? Have you tried another cord/charger with the EXACT same power specs? Does the cord/charger charge the Battery? Charge LED lights? It sounds like a Graphics Adapter? If you connect to a external monitor is it the same. Your question/statement indicates multiple issues. 1 , Power, 2, Graphics. Can you clarify "color blank"?
May 22, 2013 | Toshiba Satellite PSLD8U-00G001 L355-S7831...
2010 chevy hhr won't start it's overheating and leaking coolant
coolant low and over heating mean no start to save the engine.But leak 2010 too soon.
Mar 09, 2013 | Cars & Trucks
Re: Dell desktop won't power up - blinking one green light
remove the laptop battery and power on the laptop and check
May 08, 2012 | Dell OptiPlex 780 MT Desktop Computer...
My laptop gets switched off while running though it has enough battery backup. And after that if i tries to restart it doesnt starts up for sometime untill it cools down. What can be done for that. I am...
Seems to be overheating problem. If it is overheating, the motherboard will try to turn off the system to prevent any damage to the processor.
You can use compressed air to clean the cooling vents
The following guide will provide more details
Mar 12, 2010 | Compaq Presario Notebook
2001 honda ex-Car overheated and doesnt start anymore!
The car overheated and something caused the overheating. Bad thermostat, low coolant level due to a leak or busted radiator hose, inoperative cooling fan, or a bad water pump. Lots of things can cause an overheating condition and I am not really sure that any blame can or should be assessed to anyone regarding what caused the overheating....something caused it and I would be hesitant to blame the driver. I doubt that the person did anything devious like drain the coolant out. However, poor judgement was used in continuing to drive the vehicle after it overheated. This can cause major problems like a blown head gasket or even a completely blown engine. Maybe the lady panicked or was unaware of the damage that it could cause to keep driving. I suspect that it wasn't something malicious (she probably feels bad enough, already), but just a simple error in judgement. I would probably give her the benefit of the doubt and explain (calmly), the mistake that she made and why it was a mistake. She didn't cause the original problem, she just handled it badly. I would check the condition of the vehicle out and go from there. What's done is done.
Start by trying to find out what caused the overheating and if it caused any permanent engine damage. Some of the things that I mentioned earlier would be a good start, or you could have a certified auto tech take a look at it. It was really nice of you to lend the use of your car to someone. I am really sorry for the trouble you are having and I hope this helped. Best wishes.
Sep 24, 2009 | 1993 Mazda Protege
Acer laptop. it won't start up, when i press the start button, it shows nothing but black screen, and i dont know what to do ....
First thing to try is to reseat the RAM on the laptop, as it could have came lose a little causing this non boot problem.
I might even be something wrong with the BIOS. You can try resetting the BIOS
Check if the laptop fans are working. As a overheating CPU or GPU can cause this problem as well.
Aug 14, 2008 | Computers & Internet
ASUS P5PE-VM Motherboard Logo
449 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
