Removal & Installation
Raise and support the vehicle.
Support rear of the powertrain frame.
Remove four rear frame bolts.
Lower the frame no more than 73.2 mm (3 inches).
Disconnect the rear oxygen sensor electrical connector.
Remove the rear oxygen sensor from the rear exhaust manifold.
To install:
Install the rear oxygen sensor in the rear exhaust manifold. Tighten
the rear heated oxygen sensor (HO2S) sensor to 41 Nm (30 ft. lbs.).
Connect the rear oxygen sensor connector.
Raise the frame.
Install the four rear frame bolts. Tighten the frame bolts to 100 Nm (74 ft. lbs.).
Lower the vehicle.
Heated Oxygen Sensor Bank 1 Sensor 1 (HO2S 1/1)
WARNING:
Handle the oxygen sensors carefully in order to prevent damage to the
component. Keep the electrical connector and the exhaust inlet end free
of contaminants. Do not use cleaning solvents on the sensor. Do not drop
or mishandle the sensor.
CAUTION: Remove oxygen sensors with the
engine temperature above 48C (120F). Otherwise the oxygen sensors may
be difficult to remove.
A special anti-seize compound is used on
the oxygen sensor threads. New service sensors should already have the
compound applied to the threads. Coat the threads of a reused sensor
with anti-seize compound P/N 5613695 or equivalent.
Fig. Showing the location of the HO2S Bank 1 Sensor 1
Heated Oxygen Sensor Bank 1 Sensor 2 (HO2S 1/2)
CAUTION
Handle
WARNING: A
special anti-seize compound is used on the oxygen sensor threads. New
service sensors should already have the compound applied to the threads.
Coat the threads of a reused sensor with anti-seize compound P/N
Fig. Showing the location of the HO2S Bank 1 Sensor 2
Remove the heat shield.
Disconnect the heated oxygen sensor electrical connector.
Remove the heated oxygen sensor.
To install:
Install the heated oxygen sensor. Tighten the heated oxygen sensor (HO2S) to 41 Nm (30 ft. lbs.).
Connect the heated oxygen sensor electrical connector. CAUTION
Ensure connectors are securely installed beneath harness heat shield to prevent damage.
Install the heat shield.
Lower the vehicle.
Heated Oxygen Sensor Bank 2 Sensor 1 (HO2S 2/1)
CAUTION: Handle
CAUTION: Remove oxygen sensors with the engine temperature above 48C
(120F). Otherwise the oxygen sensors may be difficult to remove.
WARNING: A
Remove the air deflector.
Disconnect the front oxygen sensor electrical connector.
Remove the front oxygen sensor from the front exhaust manifold.
Fig. Showing the location of the HO2S Bank 2 Sensor 1
To install:
Install the front oxygen sensor in the front exhaust manifold. Tighten the front HO2S sensor to 41 Nm (30 ft. lbs.).
Connect the front oxygen sensor electrical connector.
Install the air deflector.
Lower the vehicle.
Hope this helps; also keep in mind that your feedback is important and I'll appreciate
your time and consideration if you leave some testimonial comment about
this answer.
Thank you for using Fixya, and have a nice day.
