Question about RCA 27V530T 27" TV
Rolling Picture After the television has been on for a couple of hours if you try to change the channel the picture starts to roll and goes black but you can still hear the audio. If you turn the television off and then back on after several minutes you can usually change the channel without any problems
  • Anonymous Nov 14, 2008
    Same problem for an Audiovox television and can't get any answers! Sorry that I couldn't have a solution.
  • Anonymous Dec 31, 2008
    picture goes on for a few seconds then the screen goes blue but you can hear the program still.
Mebe the tv tuner no good.
Ben.
Posted on Jan 31, 2008
Sometimes the picture rolls for 30 minutes to one hour and then the picture is perfect. A few times when we turn it on, the picture is okay and then after a few hours, the rolling picture starts. Where is...
The rolling is a bad filter capacitor on the signal board in the set---Any Mitsubishi dealer can look the model up and see known faults including this one---some of the sets when cold---vertical jitter in picture or just menu---If the menu is stable you have a tiny bad cap= weak caps when cold act up and when get hot regain capacitance and start to work.
Aug 28, 2012 | Mitsubishi WS-55807 TV
My picture keeps rolling
Vertical sweep problem. Check vertical output section circuits to rectify this fault.
May 05, 2012 | Sony FD Trinitron WEGA KV-32FS120 32" TV
TV COLOR AND SOUND
The convergence board is shot you going to need a new board as the horizontal ic's have given out. Reapiring this would take expertise and cost you more then its worth then just get a new convergence board. Thanks and please do rate.
Aug 31, 2009 | RCA HD52W59 HDTV Projection Television
ROLLING PICTURE HATACHI
Replace Verical IC and componets in same circuit maybe 2or3 bad capacitors. 100uf 35v ,1uf or 2.2uf 50volt. you need to order vertical Kit.
Jan 08, 2009 | Hitachi 53UDX10B 53" Rear Projection...
Need help desperately!!!
A rolling picture means it is either not getting a good signal (possibly a bad cable or connection), or it is receiving interferrence from another device you have connected. Try disconnecting other devices or turn the power off to other devices and see if the rolling goes away. If you have Y cables connecting two devices it can cause this kind of interferrence even if the second device is not turned on.
Mar 09, 2008 | SVA-USA HD4208TIII-PDP 42 in. EDTV-Ready...
Vertical rolling on Hitachi 60SBX78B
It ended up being the Verizon Fios box. We recycled it and the picture stopped rolling. Thank you for being here to help. If I have any future questions, I'll definitely use your site.
Mar 07, 2008 | Hitachi 60SBX78B 60" Rear Projection...
When viewing images on TV the picture is vertically rolling.
Check the video setting in the set-up menu. It may be set to PAL if you are on the NTSC system, or vice versa. Also check the TV input to ensure your're on the correct channel.
Mar 02, 2008 | Canon PowerShot S2 IS Digital Camera
Picture is Rolling..stops after some warm-up
I have seen this many times. There is a 9 volt regulator on the small signal board that causes this. The regulator goes bad and the 9 volts starts dropping, especially at start-up when the regulator is cold. If the voltage is below 8 volts then the picture gets dark and the vertical becomes unstable, with the picture squeezing down and/or rolling. As the regulator warms up the voltage starts rising back towards 9 volts and the symptoms start clearing up. There are 3 regulators in a row on the board and the regulator in the middle is always the bad one. Replacing that regulator should cure your problems but it should be replaced by someone experienced in servicing Mitsubishi projection TV's because pulling the chassis out is quite tricky.
Aug 05, 2007 | Mitsubishi VS-45607 45" Rear Projection...
Hitachi 43FWX20B picture problem
yea take the set to a tech reprogram.or take out the plug and plug it in after 30 min.if the problem does not go.do as i say.good luck.
Apr 04, 2007 | Hitachi 43FDX15B 43" Rear Projection...
Toshiba Rear Projection TV 42WT29B
This is a problem with the low voltage condition in the main power supply or the sweep supply, or there is bad capacitors in the vertical driver circuit, or the PIP circuit if there is one. the best way to troubleshoot this would be with a schematic, measure all the voltages and see if there are any lower then normal levels. In the vertical and PIP circuits, you will need an ESR type capacitor meter. if you dont own this equipment, or have had no experience working on solid state electronics, play it safe and call in a tech to assist you in this repair. Good Luck Please dont forget to rate this thread.
Dec 11, 2006 | Toshiba 42H83 42" Rear Projection...
RCA 27V530T 27" TV Logo
66 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
