Question about Canon PIXMA MP150 All-In-One InkJet Printer
Paper loading Hi, The paper won't load to print. It makes all the noises of doing so, but where the paper sits, there is a little white plastic lever at the bottom edge of the paper that is holding the paper back
    Scholar:
  • 35 Answers
The issue you have posted regarding your printer which is un able to load the paper could be due to number of reasons like if there is any foreign material for example pen, pencil or any other obstacle which is blocking the paper to feed through the printer feeder then the printer will not be able to load the paper. However I would appreciate if you try the steps below in order to fix the issue.
1. Confirm that no foreign materials are inside the machine.
2. Confirm that usable paper is set.
3. Confirm that the paper is set properly.
4. Confirm that recommended paper is used, and the number of sheets set does not exceed the required limit.
5. Disconnect the printer power cord as well as the printer cable form the printer.
6. Turn the printer upside down and shake the printer in order to remove any obstacle which is stuck inside the printer causing the paper jam error.
Open the printer cover and remove the cartridges and check carefully if there is any small piece of paper which is stuck inside, if so remove it carefully.
7. Disconnect the printer power cord and press and hold the power button on the printer for about 15 to 20 seconds( this will release the flee power) and reconnect the printer and check.
8. Check and set the paper guide in the feeder to the paper size.
9. Try loading a single sheet and check if it is printing.
10. Try different type of paper.
11. try to rotate the roller inside the feeder which pulls the paper manually if possible to ensure that it is not jammed
Should you require any further assistance regarding the printer or even for any other computer related issue please feel free to contact me I will be more than glad to assist you.
Regards
Malik Khan
Posted on Jan 31, 2008
My officejet 4500 is making a horrible noise when it warms up
Where was the pen stuck? All the gears in that printer are plastic and therefore are subject to shearing off or stripping.
Jan 07, 2018 | HP Officejet 4500 G510G Inkjet...
Hp cp3525 printer makes clicking noise when printing and start up
  • Make sure the paper type levers are set right in the tray. When loading paper this can get moved and the printer will think it is picking up bigger paper than is actually loaded and it will click.
  • Locate the fuser, usually just before the paper exits and it should be easily accessable from the back panel. Remove the fuser and inspect the gears, they will get chewed up and may need to be replaced. A good sign will be a lot of white dust which is bits of the gear itself.
Jan 13, 2013 | Vizio Xwr100 Dual-band Hd Wireless...
When i try to print its pulling the paper in wrong, and then saying paper jam whats wrong?
Maybe the paper loading.Try this:-
  • Remove the previously stuck paper and turn the printer off and on.
  • Extend the paper guides by pressing down the paper adjustment lever.
  • Now load the paper making sure it goes into the center of the paper support and then adjust the paper guides by moving the lever up or down.
  • Make sure the paper guides rest against the edges of the paper.
Hope this helps.Thanks!
Please rate this answer.
Nov 04, 2011 | Lexmark X5650 All-in-One InkJet Printer
I have a problem with my printer, when i switch it on the cartridge carrier moves to the left and all of a sudden the rollers rotate fast afterwards the cartridge carrier moves back to the right again and...
The machine is not detecting paper in it. If you have paper loaded in the machine, then your paper tray needs to be adjusted so that the rollers can pick up the paper. There is a plastic lever that you press and push up to the end of the bottom of your paper when its loaded in the tray. Remove the paper tray, load it with fresh paper and put it back in. Press the plastic lever and push the paper all the way up to where it is supposed to be to make sure that the rollers can pick it up. Then clean any documents that have not printeed out of your print que. You can find the print que down by your clock on the bottom right side of your screen. Click the arrow and look for a picture of a printer. Right click on top of the printer icon and delete documents that are pending. That should solve your problem.
Oct 14, 2011 | HP Deskjet D2660 All-In-One InkJet Color...
I have Epson LQ 2180. When Ever i load paper from rear tractor feeder it loads the paper and still shows the paper out LED. If i press Load/Eject button it only loads the paper not eject. I have cleaned...
Hi
My friend we have LQ2180 in our office, there i a lever in the right side of the printer that indicates when you print your document. Adjust to upward to print the document from rear tractor and to print from the front push the lever downward. Maybe you accidentally, push down the lever.
Any problem, just message me. Regards.
Jan 11, 2011 | Epson LQ-2180 Dot Matrix Printer
How topaper load cannon mp 160 pixma
Loading Paper into your Canon MP 160 Pixma.
A) Loading Paper :
Follow this procedure:
1) Open the Paper Support, then pull out the Paper Support Extension.
2) Place a stack of paper (print side up) in the Auto Sheet Feeder, pinch the Paper Guide and adjust it to the left side of the stack.
* Set the Paper ThicknessLever to the correct position for the paper.
Note : Set the Lever to the left for most paper. When the Lever is set to the right, the confirmation message appears before the machine starts printing.
Important : Make sure the stack does not exceed the Load Limit Mark.
B) Loading Envelopes
Follow the following steps:
2) Prepare the envelopes for loading.
Important : * Press down firmly on the edges of the envelopes to make the folds crisp. Also, press firmly on the area that corresponds to the edges of the back flap.
* Remove any curling by holding the edges diagonally and bending them gently.
* If the edges of the envelopes are inflated or curled, place the envelope on a flat surface. With a pen, press down while moving it from the center toward the edges of the envelope.
* Ensure that no curl or puff exceeds 1/8 in. (3mm).
3) Place the stack of envelopes (print side up) in the Auto Sheet Feeder, pinch the Paper Guide and adjust it to the left side of the stack.
* Load the envelopes in the Auto Sheet Feeder with the short side down.
* Set the Paper Thickness Lever to the right.
Important : Make sure that the stack does not exceed the Load Limit Mark.
Hope this helps. PLease rate my response.
Thanks
Have a good day.
Dec 01, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Hp l7590b no paper load
hi friend,
Step 1Turn on your printer. Make sure it is plugged into an electrical outlet and installed properly.
  • Step 2Wait for your printer to stop. Do not load paper while it is printing or running any kind of maintenance operation.
  • Step 3Prepare your paper. Make sure your paper is right side up (glossy, whiter or label side should be facing up). Make sure all the pages are lined up together, like a deck of cards.
  • Step 4Locate your paper tray. Some printers have a manual tray and an automatic feed tray. Refer to your printer’s documentation to find the automatic feed paper tray.
  • Step 5Place your paper in the tray. For 8.5 by 11 inch (standard) paper make sure the 8.5 inch side will be fed into the printer.
  • Step 6Set the paper guide. This is the movable piece on the side of your paper tray. One side should move and the other should not. Move your paper so it touches the side that does not move, and slide the paper guide so it touches the other side. Some paper guides have markings so you can set it to the exact measurements if you know the size of your paper.
  • Step 7Set the paper thickness lever. Refer to your manual to determine which setting this lever should be at. Generally, standard paper does not need a different setting and special media like glossy photo paper or envelopes should use a thicker setting. You can usually access this lever the same way you access your ink cartridges.
  • Step 8Let your printer know what it is printing. If you are using a special media, then set the options before you print. Click “Properties” on the print dialog before you print something. From there, change your media type to whatever kind of paper you loaded.
  • jQuery('.article ol .image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); }); Tips & Warnings
    • Fan your paper back and forth before lining it up to load into your printer. This prevents static build up which is the leading cause of paper jams.
    • If your printer doesn’t feed the paper correctly at first, try making slight adjustments as it tries to feed to find the right spot.
    • Refer to your manual for in-depth paper loading instructions.
    • Many printers have a resume/cancel button. This is to be used when you need to load paper mid-print job.
    • Do not overload your printer.
    • Avoid non-standard media types such as loose leaf paper with holes or folded or wrinkled paper or anything with affixed stamps or stickers. These can jam your printer.
    hope this helps u
    please rate me...........................
    thak u for using fixya
    regards
    sivaranjini
    Dec 01, 2009 | HP Officejet Pro L7590 All-in-One InkJet...
    Epson aculaser cx11nf MP E paper jam
    open the mp tray
    locate 2 white plastic egg shaped piece on the ends of the steel rod
    gently push one or the other towards the back of the machine
    if the paper jam error message is on then the roller will turn as soon as you give it a push
    re load the paper
    open and close door a or e
    printing should resume
    that white piece works with the paper lift to get the paper up to the in feed roller
    Sep 01, 2008 | Epson ACULASER CX11NF All-In-One Printer
    No paper error
    There's a little plastice lever type thing that hangs down above where the paper tray is inserted. When the paper tray pops up after being inserted, the paper moves this lever up. This is how the printer knows if there is paper or not. With the tray out, push the little white lever up and see if the "No Paper" message goes away. If it does go away, the lever/sensor is working OK, if not the lever sensor is bad. If that was not the problem, check that the paper tray is popping up after being inserted (look from the back of the device while you insert the tray). If it does not pop up, there is a little white plastic button type thingy on the side of the tray that releases the paper tray to pop up after you insert it into the printer. Make sure that is working correctly. If you flip the pritner upside down, you can see this little white plastic button type thing that should release the paper tray to pop up during the insertion process.
    Oct 09, 2007 | Dell 1600n All-In-One Laser Printer
    Check cover/cart
    Two possible solutions remove the top cover (Two screws on top after oepening the cartridge door and two push in black nylon screws in either side). and check the activation lever that activates the cover switch is not riding on top of the switch. Second if this happened your toner cartridge make sure this new cartridge is the correct one for the fax and not a HP modified recycled printer cartridge.
    May 31, 2007 | Canon FAX-L350 Plain Paper Laser
    Canon PIXMA MP150 All-In-One InkJet Printer Logo
    48 people viewed this question
    old marine
    old marine
