Question about Hamilton Beach 40729 Espresso Machine
Hamilton Beach Espresso Machine
Steamer won't steam. No parts clogged - everything is cleaned out. Doesn't seem to be building any pressure at all. Suggestions???
    Problem Solver:
  • 18 Answers
I have had similar issues with my 40729.
Assuming that when you turn on the steam switch, the steam light goes on and then off when up to temp:
I have resolved this by filling my steaming pitcher with boiling water, remove the end-cap from the frothing wand and soak the end of the steam pipe in the hot water for several minutes. Then fire up the steam and blow it out. if the obstruction is more serious, then you may need to unplug the machine and run a thin and stiff wire ( like a guitar string ) up through the wand to break up the clog.
This unit uses one heater for both the extraction and the steam, so if you are getting extraction then the heater is good. You may also have either:
  • a bad needle valve in the steam knob on the right.
  • a bad thermostat that regulates the heater temp when you turn on the steam switch.
Posted on Jun 11, 2009
My Hamilton Beach duration iron produces steam but the burst steam feature doesn’t work
put a solution of 10% vinegar in it and try to flush the system out.... probably that circuit, which pushes a shot of water into the heating coils, is plugged.... if REALLY plugged, you may be looking for a new iron since passage of water with the vinegar is necessary to dissolve the clog to a great degree...
Nov 19, 2017 | Hamilton Beach Irons
I have a Krups coffee/espresso maker, with a milk steamer. It makes great coffee and espresso; however, the steamer is not working. It is not clogged; I cleaned the handle with a fine needle, and water...
There must be a blockage in that steam pipe, I think you need to dismantle the machine and remove all of the steamer parts off the boiler and look for the cause of the problem. Oftentimes it will be old hard milk that has been drawn up the pipe and gone hard from the heat. Once cleaned out prevention by blowing a large amount of extra steam through it after each use is the solution.
Apr 22, 2017 | Krups Gusto 880-42 Espresso Machine
The steamer dosen't work at all. When the knob is
First you should remove the end tip of the steam hose and try to clean the steam holes with a pin. The steam should come frealy withou the end tip. If not then you shoul desasemble the steam tap , clean it and put it back together. The problem is only caused by dry milk or milk with chocolate. Even if you manage to have some steam then the problem can be solve by using the steamer warming just water in a glass and leave it all nigh long inside the boiling water in glass this will meld the dirt and will gos away.
Feb 09, 2010 | Rancilio S24 Espresso Machine
My Hamilton Beach 40729 will not brew! The motor hums and I can get water to pump through the steamer. Please help!
This unit does not use the pump to generate steam, so if the pump is bad (motor works but the pump it drives does not transfer water) you will get steam but no water through the head to the portafilter.
The unit is not user serviceable and at $68 to buy a new one, it is for the most part, disposable.
The pumps on this unit do not like to be run dry as they rely on water as a lubricant. Without water in the reservoir, the pump may fail in a short running time.
Feb 21, 2009 | Hamilton Beach 40714 Espresso Machine
Blocked steamer outlet /frother tube
hello take the pipe put it in a solution of calcium remover leave it in for a couple a day calcium in pipe is like concrete after a day or so try to pass a steel wire in it the calcium gonna get softer everything gonna come of after take the same product fill the machine run the machine with it for a good clean up most of the people loose good expresso machine because of hard water a clean up every few month it gonna work good and our coffee gonna be warmer .p.s when you use special cleaner rinse the machine very good the cleaner is very corrosif cheers
Jan 14, 2008 | Coffee Makers & Espresso Machines
No steam!
Ran into the same problem on mine just after using the steam, so it definetely wasn't clogged... hope this helps.
Just try running the expresso maker through a full cycle and then try the steam again. Not sure if the machine air locked or something, but the expresso cycle appeared to get the water flowing again and then it had no trouble producing steam.
Hope it works.
Jan 11, 2008 | Hamilton Beach 40729 Espresso Machine
Hamilton Beach Espresso Machine not working
When you turn on the steam switch, does the steam light turn on, then eventually turn off when it comes up to temp?
If so, your wand may be plugged with a dried plug. I have resolved this by pouring boiling water into my steaming pitcher and soaking the wand for several minutes, then fire up the machine and heat for steam, then blast it out.
Might take a few tries. You may also need to run a thin wire, like a guitar string, up the wand to help free up the plug.
Jan 07, 2008 | Hamilton Beach 40729 Espresso Machine
Steam wand not working
The coffee brews fine but the steam wand is not working.
Pressure build ok.
Dec 09, 2007 | FrancisFrancis! X1 Espresso Machine
Hamilton Beach 40729 Espresso Machine Logo
476 people viewed this question
Top Hamilton Beach Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
Are you a Hamilton Beach Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
