Question about LG 42PX5D 42 in. Plasma HDTV
Hdmi cnnection ps3 to lgpx5
Every time i connect ps3 to my lgpx5 i get buzzing through speakers with hdmi cable only
  • Anonymous Jan 20, 2008
    You are not alone. When my PS3 is connected via HDMI there is a persistant crackle from the audio, I have contacted LG customer service, who are useless. They only advice was to give me a number for their contracted engineers. They charge £150 just as a call out charge.I am not prepared to pay that much money when the problem is not my fault but the manufactures. I would love to be able to get the TV to work properly but have come up with a temp solution. Switch the audio output to Av and keep the picture through HDMI.
  • Anonymous Feb 07, 2009
    Guys, I have the same problem; I own a ps3 and a westinghouse hdtv and when I turn on the tv there is an annoying buzzing sound as long as I am not playin my ps3, in other words buzzing sound stops only when I am playin ps3 on the tv's hdmi component. To get rid of the buzzing sound when Im watchin tv I need to disconnect one side of the hdmi cable either from the ps3 or the tv. I looked a lot on the web for a sloution but no, all I found was problems' please post here if you can find a way to get rid of this
Lg had a problem with this wiring loom being unshielded.Common fault and should be replaced under warranty/recall. I had mine replaced because the sound became completely crackling.
Posted on Dec 14, 2008
The lg tv trainers can not get the sets to recognize the information from the ps3 either. It has to do with the HDCP info being sent from the ps3. "they aren't speaking the same language" you will have to use the component output from the ps3 to the tv, sorry.
Posted on Jun 02, 2008
  • 83 Answers
Check the connection on the tv and check the ps3 one could be faulty
Posted on Jan 14, 2008
A humming or buzzing noise through the tv speakers when hooked up with AV or componet cables!
This is a common problem with rca a/v aka red white and yellow cables.Time to buy new ones or go hdmi.But don't worry it's not your system.
Mar 23, 2010 | Sony Playstation 3 (PS3) Console
No surround sound when playing PS3 through HTDDWG700 via 2 HDMI
The HTDDWG700 does not transfer the audio through the HDMI cable that the vision goes through. To solve the problem i got an optical cable and connected the PS3 to the receiver with the optical and put the HDMI cable from the PS3 to the tv.
Oct 18, 2009 | Sony Playstation 3 (PS3) Console
PS3 HDMI Problem
it seems like the connectors on the HDMI cable is screwed or maybe a small connection issue within the console try a new cable is un helpful may need to check the connection on the machine or TV
May 29, 2009 | Sony Playstation 3 (PS3) Console
There is a slight buzzing sound on my TV
its the tv dude cuz i put the yellow white and red on a small old sony tv and it made the same noise and everything but then i changed it into another t.v. about 73 inches and it worked fine with an hdmi change the t.v.
Jan 11, 2009 | Sony Playstation 3 (PS3) Console
I want to hook up external speakers to my Acer H213H for when my PS3 is hooked up to it.
What method are you using to connect to the monitor?
If you are using the HDMI -> DVI adapter it does not support sound. HDMI does, but DVI does not.
If that's the way you are set up then all you need to do is use the HDMI -> DVI adapter for your video and use the regular RCA connections for audio.
You can set the video and audio settings in the PS3 with the "Display Settings" and "Sounds Settings"
That way you just use the red and white RCA ends to connect to a speaker system, the yellow won't be in use at all.
Dec 10, 2008 | Acer Computers & Internet
Connecting to surround sound system
Hi to connect your ps3 to your tv all you would need is a hdmi to hdmi connector which would mean the sound would come straight out of your tv. The sound comes directly out of the hdmi cable. If you want to connect the ps3 to an external reciver you might want to get an AV reciver with HDMI inputs. This would connect to your tv and you can switch channels to different sources connected into the receiver, also they come with very good seperate speakers so you wouldnt have to use you telly speakers and you can connect your directv box into it aswell.
Alternatively you can connect the audio phono outputs from your AV multiout connector on your ps3 (the cable should be provided) to a seperate sound system with phono AUX inputs, these are found on most soundsystems but check with whoever your buying it from. But this means that you cant use the HDMI output of your PS3 for video just the AV multiout video signal (which is a bit rubbish, so I suggest the latter solution.
Hope this solves your problem
Rob
Nov 26, 2008 | Audio Players & Recorders
Connecting PS3 to receiver via HDMI
First put the orginal ps3 cable onto ps3 then to tv.set tv to see ps3 and go to ps3 setup,now down to display settings,set to hdmi,picture will go off so now switch tv to hdmi input .Next go to sound settings for ps3 and set to hdmi if your amp can work this way ,if not set sound out to optical.
hope this helps.
CABLE GUY.
Jun 24, 2008 | Onkyo HT-SR800 System
Hum from speakers
I suspect an open ground or bad cnnection in your hdmi cable to the amp from the sat.A hum is very indicative of that situation
Dec 11, 2007 | Onkyo TX-SR604 Receiver
Please help with getting 5.1 sound from my TV!
You must run a Digital Optical cable from your PS3 to your reciever. Then press your function button on your recievers remote until you see SAT/CABLE on your recievers display. Next go to your PS3 settings and go to Sound settings, then Audio Output settings, and select Digital out (OPTICAL) then your done. This is the only way to get true digital sound from your PS3 to your reciever.
Oct 01, 2007 | Sony DAV-HDX500 System
LG 42PX5D 42 in. Plasma HDTV Logo
454 people viewed this question
Computer Repairing
Computer Repairing
