Question about Asrock K7VT4A-Pro Motherboard
Won't load windows xp
On boot up the computer goes to boot options in windows. It will go into safe mode but doesn't show any problems, each time I try a restart it goes back to the boot options in windows and just loops forever.
Have disconnected all devices internal and external except HDD without resolve HDD is a Maxtor diamondmax 80Gb (fairly new). Change BIOS Ver 1.30 to defaults and back to correct settings no results. Assistance would be appreciated, Thanks
  • fubard Jan 18, 2008
    Thanx for the advice but it turned out to be a dodgy eide cable, second time its been replaced!!!
  • 205 Answers
If this is a recent problem the first thing you might try is a System Restore.
Start->Programs->Accessories->System Tools->System Restore
If System Restore was enabled on your system then you can restore to a date before the problems began. This will not remove any files or programs you may have installed since that date, it will simply recover important system files that may be corrupt. You can run this from Safe Mode which is what you'll need to do.
If that does not help you, you may need to perform a clean boot and sequentially start adding back startup items and services until you find which one is causing the problem. Here's a great link that will walk you through this process step-by-step.
http://searchwinit.techtarget.com/originalContent/0,289142,sid1_gci968108,00.html
If you find any of this helpful I hope you'll give this solution a positive rating. I don't get paid for this. I know it's a strange hobby, but I like helping if I can. Sadly, lots of people never rate the solutions or make comments so future users can see what works and what does not.
Posted on Jan 12, 2008
  • ohiotom Jan 18, 2008
    Glad to hear you got it working. In all the times I've helped people with this kind of problem it never occured to me that it would be better to disconnect the IDE or SATA cables from the motherboard rather than the device itself. I can imagine a bad cable would cause a problem even if it were not plugged into the drive. I'm glad you explained what you found because I'm sure it will help me in the future.
Start my pc on safemode
Windows 2000 and XP users Tip: If you are running Safe Mode because you cannot get into Windows, you may want to first try loading the last known good configuration.
To get into the Windows 2000 and XP Safe mode, as the computer is booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu" as shown below. Use your arrow keys to move to "Safe Mode" and press your Enter key.
Note: With some computers, if you press and hold a key as the computer is booting you will get a stuck key message. If this occurs, instead of pressing and holding the "F8 key", tap the "F8 key" continuously until you get the startup menu.
Trouble Getting into Windows 2000 or Windows XP Safe mode - If after several attempts you are unable to get into Windows 2000 or Windows XP Safe Mode as the computer is booting into Windows, turn off your computer. When the computer is turned on the next time Windows should notice that the computer did not successfully boot and give you the Safe Mode screen.
Please select an option:
Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt
Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode
Start Windows Normally
Reboot
Return to OS Choices Menu
Use the up and down arrow keys to move the highlight to your choice. Once you're done in Safe mode if you want to get back into Normal Windows restart the computer like you normally would and let it boot normally. Click here to get additional information about getting out of Safe mode.
loading the last known good configuration.To get into the Windows Vista and Windows 7 Safe Mode, as the computer is booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu" as shown below. Use your arrow keys to move to "Safe Mode" and press your Enter key.
Note: With some computers if you press and hold a key as the computer is booting you will get a stuck key message. If this occurs, instead of pressing and holding the "F8 key", tap the "F8 key" continuously until you get the startup menu.
Trouble Getting into Safe mode - If after several attempts you are unable to get into Safe Mode as the computer is booting into Windows, turn off your computer. When the computer is turned on the next time Windows should notice that the computer did not successfully boot and give you the Safe Mode screen.
Choose Advanced Options for: Microsoft Windows Vista
Safe Mode
Enable Boot Logging
Enable low-resolution video (640x480)
Last Known Good Configuration (advanced)
Debugging Mode
Disable automatic restart on system failure
Disable Driver Signature Enforcement
Description: Start Windows with only the core drivers and services. Use
when you cannot boot after installing a new device or driver. Once you're done in Safe mode if you want to get back into Normal Windows restart the computer like you normally would and let it boot normally.
Aug 13, 2014 | Computers & Internet
Wont boot in safe mode
start your laptop before booting windows press f8 button continuously
ndows 2000 / XP users
bulb.gif If you are running Safe Mode because you cannot get into Windows, you may want to first try loading the last known good configuration.
To get into the Windows 2000 / XP Safe mode, as the computer is booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu" as shown below. Use your arrow keys to move to "Safe Mode" and press your Enter key.
Safe Mode
Enable Boot Logging
Enable VGA mode
Debugging Mode
Reboot
Microsoft Windows Vista and Windows 7 users
Sep 27, 2011 | Lenovo G460 Laptop Computer - 06779XU...
After loading the laptop, the screen goes black showing only a white mouse cursor that you are able to move. Even tried loading in safe modes but the page still doesn't load.
Please restart the computer in safe mode and check if that is loading. If safe mode loads well, then run system restore (Steps depend on the windows version you have) and restore your computer to a earlier date (say 1 or 2 days earlier) when you know that your computer was working fine.
If you cannot login to safe mode then we might have to do a manual registry restore
Please use the link to know more about it. If you are going to use the step, please keep a printout handy of the instructions.
For XP:
http://support.microsoft.com/kb/307545
(follow the manual steps)
For Vista & Windows 7
Boot from OS DVD and run startup repair.
Feb 03, 2011 | Computers & Internet
Starting problem
Immediately after seeing the Dell logo, keep tapping the 'F8' key,
until you see a "menu" (white text over a black background)
giving "startup" options for Windows XP.
Select "Safe Mode" and see if you can start in that mode.
Then, use "System Restore" to go "back" in time, to the most-recent checkpoint (date/time) where your computer _DID_ work.
Restore to that point, and restart.
Jul 17, 2010 | Dell Inspiron 1525 Notebook
Unit wont start, gray screen then goes to a screen with options on how to start unit and then goes blank
Answer:To load the last known good configuration in Windows 2000 / XP reboot the computer and as it's booting booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu" as shown below. Use your arrow keys to move to "Last Known Good Configuration" and press your Enter key.
Trouble Getting into Windows 2000 or Advanced Options menu - If after several attempts you are unable to get into Windows 2000 or Windows XP Safe Mode as the computer is booting into Windows turn off your computer. When the computer is turned on the next time Windows should notice that the computer did not successfully boot and give you the Safe Mode screen.
Note: With some computers if you press and hold a key as the computer is booting you will get a stuck key message as the computer is booting. If this occurs instead of pressing and holding the "F8 key" tap the "F8 key" continuously until you get the startup menu.
Safe Mode
Enable Boot Logging
Enable VGA mode
Debugging Mode
Reboot
As can be seen from the above example, you should be able to highlight and press enter to load the last known good configuration. Once completed the computer should restart and attempt to load into Windows.
Will running the Last Known Good Configuration delete anything?
No, running the last known good configuration will restore your last good system settings and will not delete anything. The only thing you may have to reinstall programs you have recently installed because the configuration for those programs may have been lost.
Jan 27, 2010 | NEC Versa VX Notebook
Loads dell logo then goes to load xp then screen goes blank
Try going into safe mode if you can by pressing the F8 key when you first turn on the laptop.
If you get into safe mode then go into the system configuration utility underneath the system tools folder. Click on the startup tab and then click on the button that says disable all. This will keep programs from loading when windows boots up. Reboot the computer and see if you can get into windows normally. If you can then you know its a program thats causing the problem. If you still can't get into windows normally then you'll have to wipe out the drive and restore your computer back to factory default.
You also will have to do this if you can't get into safe mode as well.
May 04, 2009 | Computers & Internet
Safe mode
You can also force the system into safe mode. You click on startup and type in msconfig. Click the general tab and select diags and the system will reboot to safe mode. Change it back to normal to get your system out of safe mode.
Please rate my response.
Feb 17, 2009 | Microsoft Windows XP Home Edition
How to restart hp pavillion 7965 desktop
Hi there. Try these steps:
1. On restart, press F8. This should bring you to a screen with various boot options.
2. Select "Last known good configuration". Windows then may load correctly.
3. If this doesn;t work, try the same thing. This time select "boot in Safe Mode". If Windows now loads in Safe Mode you should be able to restart and Windows may load correctly after this.
4. If these two both fail, you may have to repair Windows...
Jan 09, 2009 | HP Pavilion 7965 PC Desktop
Windows wont load
is your computer set to boot from cd?
Jun 01, 2008 | Computers & Internet
Asrock K7VT4A-Pro Motherboard Logo
71 people viewed this question
Top Asrock Computers & Internet Experts
David
David
Computer Links
Iqbal Husain
Iqbal Husain
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
