Question about Nakamichi SoundSpace 5 Shelf System
Power and lcd
My sound space 5 fell off the wall and now the lcd is smashed and i am not getting any power, can anyone suggest what i can do?
I have the same system sitting in a closet... I can sell you the cd part if you need it
Posted on May 03, 2008
How much?
Posted on Mar 12, 2008
You can sell the speakers to me!
Sell it to me
Posted on Mar 01, 2008
    Scholar:
  • 44 Answers
If you are comfortable with opening up your system you could order the LCD from the manu. and install the new one. As far as the power goes. you may have knocked a connector loose (easy fix) or you either cracked the circuit board or broke a solder connection. You can do a visual once you have the unit open to see which it is. Again, if you are comfortable with a solder iron then reflow the broken solder connection or take a small piece of wire and repair the broken circuit board connection. (using the wire and solder to create a new "bridge") If you are not comfortable with this and it is not a loose connection you will probably need to take it to a reputable repair shop. The manu should have a list of authorized repair shops.
Posted on Feb 09, 2008
I forgot my lock pattern on my samsung tablet i need helP!!!!
press the volume up and the volume down button together with the power button.if that doesnt work ill suggest smashing it against the wall and getting a new tablet.
Jun 19, 2018 | Samsung Tablets & eReaders
Hi. I have a 46" Samsung LCD (LN4661) and
Ysus board and backlight inverter. Need to be replace. I there any sound?
Thanks,
Dec 11, 2010 | Samsung LN-T4661F 46 in. LCD HDTV
My "t " bird hard drive fell onto floor from about
The '1TB' device is 10 to a large power.
The '930GB' is 2 to a much-larger power.
Since '1GB' is 1,073,741,824 bytes,
multiplying 930 times 1,073,741,824 is equal to 1TB.
So, your device is 100% empty -- all 930GB are "free" space.
Oct 31, 2010 | LaCie Hard Disk 1TB Desktop with Hi-Speed...
Tv was fell from wall unit. no power
Check for PCB damages,check for CRT damage.Not worth reparing or not repair able becuce of to much dmages.
Sep 13, 2009 | Philips Magnavox 20MT133S 20" TV
SONY BRAVIA KDL-40s4100 is not working right
Please check whether the connections are secured between the TV and the connected devices.
If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
Try connecting the TV to a different wall outlet and check if that helps.
Please connect a different device to the TV and check whether the issue persists.
If the issue still persists service of the TV is determined.
Jun 18, 2009 | Sony Bravia KDL-40S4100 40 in. LCD TV
Lcd felloff wall-has sound-cracked looking picture-can it be fixed
Yes it can be repaired,but it will probably cost less just to replace the whole thing.
May 31, 2009 | LG 42LG30 42 in. LCD HDTV
Garage door opens after a power surge.
Anytime a door opens and/or closes by itself I look for a smashed wire between the motor unit and the wall button.
If the wire is smashed the insulation becomes so thin that power will leak thru the insulation and activate the door.
Loosen the staples with a small screwdriver and slide the wire about ½ inch to move any areas of thin insulation away from the staples.
The second thing would be a bad wall button or a remote with a sticking button.
Or a remote in someone’s purse that gets the button pushed by other stuff in the purse.
The test is to disconnect the push button wires at the power unit. If the self operation stops you have located the problem. If you reconnect the wires and disconnect the wire at the wall button this will tell you if the problem is the wire or the button.
HOPE THIS HELPS
Dec 03, 2008 | Sears Craftsman LiftMaster Chamberlain...
Monitor takes a long time to wake up
replace 2 caps 1000uf each 16 volt
I purchased 5 of these babies (new) at the same time and 3 of them had this problem
Sep 25, 2008 | Sceptre X9G-NagaIV 19" LCD Monitor
32 in Olevia LCD Display Screen Cracked
youre screwed. panels for tvs cost almost as much as the tv, and they are very hard to replace. i suggest you sell the parts out of it.
Oct 21, 2007 | Olevia LT37HVS 37 in. LCD HDTV
Nakamichi SoundSpace 5 Shelf System Logo
115 people viewed this question
Top Nakamichi Audio Players & Recorders Experts
Jerry Greenberg
Jerry Greenberg
Rommel Balcita
Colin Stickland
Colin Stickland
Are you a Nakamichi Audio Player and Recorder Expert? Answer questions, earn points and help others
