Question about Symphonic ST419E TV
Video mode i cant find a remote for my tv and the tv is stuck on video.  how can i change the channel so i can watch regular tv.  i cant seem to find a universal remote that will program.  mayne because i am in video mode.  can anyone help
  • magz958 Dec 09, 2008
    my symphonic is stuck on channels and i cannot get it into video mode. i do not have a remote for it.
  • Anonymous Mar 13, 2014
    cant change video on tv
I went to add/delete channels in my menu on my symphonic and it let me scroll through the channels, make sure you have them all set to add (by pushing the volume buttons to make them light blue instead of purple)....after adding all of your channels (or just the one if you use dish) just power the tv off while on a channel and then power back on and you should have tv.
Posted on Aug 21, 2008
If u hook up an old vcr with channels You may be able to change channels thru that...All we get is channel 3 and aux and we cant find the remote...if anyone knows????
Posted on Nov 26, 2008
I was lucky enough that mine quit workin while i was in tv mode instead of game mode. I dont believe u will find a remote to work for ur problem , i believe the sensor in the tv ( for the remote ) quit working, i know it really sucks, i could never find anything on the menu to let u switch back and forth either :-(
Posted on Aug 20, 2008
Good luck, I believe you need the remote to switch it back and fourth. I am having same problem trying to get universal remote programmed to do it...
Posted on Jan 19, 2008
I can not get the tv to go back to channel 4 to watch reg tv after hooking up a Dvd player to it
Do you mean the gray CRT Durabrand from 2004? I had one of those exact ones myself recently with the remote and everything.
You need a remote control to go back to the regular channels if you're in Game or Video mode (like watching your DVD player); those inputs are entirely separate from the channels to the point that you can't use the channel left/right buttons to get out of there. In fact, before I got my remote, I couldn't even get INTO Game / Video mode; I had to use an RF modulator on channel 3. For the Durabrand 13", the remote unlocks much more out of the TV.
Jan 30, 2018 | Televison & Video
No remote tv stuck in cable mode no channel 3
See if you can get a manual for the set at web site or try a google search.
Sep 07, 2017 | Televison & Video
Stuck in vedeo mode wont play movies dvd or vhs.dont have a remote can i reset or reprogram the tv to play movies or at least get back to regular channels
Tries this go to the tv set itself presss the channels up or down u will get out of the video modes line1 or line 2 u will get out to regular tv signal.If u need a new axact remote go to this website.1-800-Remotes Factory original.
Aug 24, 2009 | Zenith B27A11Z 27" TV
Durabrand DCF2003
try opening it up and clean the remote with alcohol and soft cloth.let it dry.while drying, check the rubber buttons for breakage.then assemble.be sure your batteries are ok.
May 28, 2009 | Durabrand DWT1905 TV
How to get TV/video mode without remote
some tv do that changing the channels.
in the control panels in the tv where r the buttons for change channel there must be video button, push it and there you go.
Good Luck
Jan 12, 2009 | Toshiba 14AF44 14" TV
Can't change channel
Most remotes have the source button at the top right hand side all the top left hand side it should be called sauce or it might just have three lines if you have a black lever on the right hand side then you need to press that in and wait it should put you to the av screen then if you let go you can press down or up that will let you chose av or video of hdmi ok if you want to send me a pic of the Tv so I could help you more if you can't find it I don't mind ok
Jul 10, 2017 | Toshiba Televison & Video
Tv/remote input problems
Try plugging your cable box in using a/v cables (red,white,yellow) and see if you have a picture on a different input from the box. If so, go into your general settings in the box and change the output channel to 4 instead of 3. Then try your TV on 4 and see if your picture comes in. I have seen TV tuners go out on just one channel before.
Feb 24, 2008 | JVC AV-27230 27" TV
Dvd hookup
  • First make sure the audio (red &black) and video (yellow) are plugged into their respective color matching inputs on the TV monitor.
  • Second either using the TV remote contol or TV's builtin control panel set the tuner mode to video. Depends on which TV's input terminal you connect the DVD player; that's where the Video mode has to be assigned.
  • For example: if you connect them to video1, set the tuner to video1. changing the channels up or down will never set it to video mode. You must press video button to change the tuner from regular channel mode to video mode.
Feb 16, 2008 | Televison & Video
Sanyo stuck on video mode
Yippie, I figured out a solution that worked!!! I have a univeral remote from comcast, on that remote near the bottom left is a small button that says (input) tv/vcr, press that one time and whala!! the tv video screen was gone, I had to manually change the channel from the tv channel button on the unit. once I changed the channel to 3, my universal remote worked... the button is the second one from the bottom left... I was on hold with sanyo for a long time and just kept trying on my own, so good luck!!!!
Jan 13, 2008 | Sanyo DS27510 27" TV
Cant change channels
Your in the video mode so you have to change the input. On the original remote, its the button left of the power button. A universal may not work for this. If you need the original remote, Its available at http://www.remotes.com Good Luck
Aug 18, 2006 | Sanyo DS31520 31" TV
Symphonic ST419E TV Logo
847 people viewed this question
Top Symphonic Televison & Video Experts
matt martin
matt martin
Are you a Symphonic Televison and Video Expert? Answer questions, earn points and help others
