Question about Dryers
Dryer sometimes get hot and other times it does not the dry brand is GE
  • Marty marty May 11, 2010
    gain access to the heater coil and measure continuity although this is an intermittent problem. So also try heating the coil during this with a heat gun and also inspect for broken heater coil which sometimes completes the connection.
  • 883 Answers
Any progress yet?
Older GE dryers are notorious for broken heater coils.
Posted on Jan 19, 2008
Ge adora dhdvh66ghobb stops heating after 8 minutes
bad thermostat possibly, which will do that
May 05, 2014 | GE DHDVH52GFWW Gas Dryer
My dryer is not drying my clothes completely. I have to set it to time dry for at least 120 minutes to get a load of clothes to dry. I can feel that the dry is warm .I usually dry my clothes on optimum dry...
Your dryer has a double set of heating elements
1 side of the coils is probably broken and you are getting half the heat.
This is making the dryer take longer to dry them clothes.
Air restrictions in the dryer and vent can cause the heater control to shut down quickly also.
If you have a bad breaker the power will sometimes work and sometimes not.
If all of these are good you might have a problem with the timer.
Most of the GE timers have leaf switches in the that get a burr on the contacts. The come apart simple enough.
I have more HERE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Apr 01, 2011 | GE DWSR463EGWW Electric Dryer
GE DRYER MAKES A HIGH SCREECHING NOISE WHEN DRYING BUT NOT EVERY TIME AND SOMETIMES DOES NOT START TILL HALF WAY THRU DRYING OR SOMETIMES NOT AT ALL?
More than likely a bad wheel and or drum support. However there are a lot of different GE dryers so the model might help to narrow down your problem. The model number should be inside the door of the unit.
Feb 25, 2011 | GE Dryers
I have a GE washer/dryer Model WSM2700RAWWH stack type and the dryer is taking very long time to dry the clothes. Please advise if it can be fixed. If not what will be best alternate washer/dryer stack...
first things first. if any dryer regardless of brand takes 2-3 hours to dry cloths 90% of the time it is your exhaust duct. take the exhaust duct off the back of the dryer and dry some clothes if the clothes dry fast then you need to have your exhaust duct cleaned. either DIY or call a professional
if it still takes a long time to dry then it could be the thermostats or the thermistor.
but in my experience its normally the exhaust duct.
Feb 10, 2011 | GE Washing Machines
New dryer does not dry the clothes the first time
Have you checked to see if the exhaust duct line is clogged with lint ?
Feb 24, 2010 | Dryers
My dryer dosen't dry my clothes
Check the exhaust tube for obstructions. If this is a gas dryer it needs airflow coming and going through that tube. This is always the cheapest, easiest first step.
Sep 05, 2009 | GE Profile Harmony DPGT750EC Electric...
GE Profile Electric Dryer Low Heat Problem
You may want to remove the back of the dryer to see if all of the element is glowing. Sometimes the element opens and then welds itself to the metal case, which would cause a partial, but not total loss of heat (slower drying time). If that is the case, part of the element will be glowing, and part of it will not.
Jan 25, 2009 | Dryers
GE Dryer sometimes it drys and other times stays cold
If it's a Harmony, you have a bad blower motor. If other than Harmony, you could have loose wires to the main terminal block (where the power cord connects) or an intermittent circuit breaker. Model number would be helpful...
Dec 15, 2008 | Dryers
Electric Dryer Heating problem
Remove the rear vent and run a load on time dry for 45 minutes.
If it dries, repair your exhaust vent.
If not, replace your heating element.
Nov 18, 2008 | GE DBXR453EV Dryer
Dryers Logo
61 people viewed this question
Top Dryers Experts
Marvin
Marvin
