Zanussi zwd1472s Whilst the washing machine was working all of a sudden it tripped the main sockets off. I tried to get the machine worj king again but it wont. All the lights come on but it wont start, i have ensured that none of the pipe are blocked.
  • brookesy Jan 13, 2008
    i have already cleared all the pipes and turned off the power. when you turn the power back on all the lights come on as normal but it still wont work.
    President:
  • 1,294 Answers
Press "end of cycle" to re-start a new cycle. Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped.
Posted on Jan 12, 2008
Start button doesn't work on King Size Washer
Are there any lights on at the washer? If not check the washer circuit breaker in your house main circuit breaker/service panel. If it is tripped reset it and try start button again. If it trips again you need a service call. If there are lights on try turning the washer main knob to off and unplug the washer from the wall outlet...wait 10 seconds then plug in and try start button again.
Mar 16, 2014 | Bosch Nexxt 100 Series WFMC1001UC Front...
Washing machine blowing trip?
It is best to disconnect the mains lines from the control panel to the different section, which are the motor, heater, inlet and outlet valve pump. If the fuse trips then the fault is the control panel board and could be a failure of the rectifier or SMPS driver. You might need to replace the board.
Jul 04, 2012 | Washing Machines
My zanussi washer dryer keeps tripping the electrics
check ground wire for tightness on plug in and on breaker box.
Mar 31, 2012 | Zanussi ZWD12270 Front Load Washer / Dryer
Zanussi washing maching keeps tripping trip switch
Sorry but with such a major fault it is virtually impossible for anybody on this forum to remotely guess what is wrong with your washer.
It could be internal wiring/plugs sockets, control panel switches, control PCB.
I fear that you only real option is a service call as the engineer will have the right equipment to safely diagnose what is wrong.
Sorry again and good luck,
John C
Mar 14, 2011 | Zanussi ZWF1420W Front Load Washer
Zanussi jet stream iz16s tripping ouy rcd once filled up with
It would seem to me that the heating element needs replacing from the information you have supplied especially as it performs most of the other functions like filling and spin and drain.
Good luck
Mar 17, 2010 | Washing Machines
Zanussi ZWD1680W Front Load All-in-One... Problem:
With the symptoms you describe i would suspect a intermittent heater element fault as you are getting earth leakage current which is tripping the whole supply rather than a current overload which would just trip the socket circuit breaker. Get the heating element checked over first as this is the most likely cause.
Nov 04, 2008 | Zanussi ZWD1680W Front Load Washer / Dryer
Zanussi IZ16 trips switch when plugged in/turned on?
as you do not mention make /age of machine and was this a sudden fault ? for now best to carry out the simple progress of elimination as to what is causing trip out to operate? start at the plug? check the wires in plug then wiring to machine motor for any damage to wires insulation? have you tried another appliance in the socket ? to see if ok? if trip operates then investigate socket ? any more info ? would help to advise on further options ?
Nov 01, 2008 | Zanussi Washing Machines
ZANUSSI 1237 Washing Machine
have you tried to plug your machine in a different socket try it if you can by using an extension instead of moving the machine.
Sep 22, 2008 | Zanussi WJS1265W Front Load Washer/Dryer
Zanussi turbodry w 1042 w
probably short to earth on the dryer elements. to check. take top off, disconnect dryer elements then run on dry program. if the trip stays in, then you have identified the fault
May 16, 2007 | Zanussi FJS1225W Front Load Washer
Open Questions:
Washing Machines Logo
147 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
