Question about Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC
NET WORK DOS PRINT
HOW TO DOS PROMT NETWORK PRINT GIVING IN WINDOWS XP PRO.
  • 84 Answers
1.
copy [disk][path][filename] print
2.
print [disk][path][filename]
Example:
copy c:\log.txt print
print c:\log.txt
Posted on Jan 12, 2008
Following the steps outlined in the wizard I did manage to install the print server utility on one of our computers (my wife's notebook / Windows 7) and get it to print successfully. However, when I...
Oddly enough I did almost the exact same thing. I sucessfully installed and printed a test page on my wife's Win7 notebook, and was almost ready to install on my XP Pro notebook and daughter's computer. When I got it installed on my XP Pro notebook, it failed. Since then I have been trying to get the network to see it. It doesn't work! Even when I hardwire plug directly into my router, the router does not acknowledge something is plugged in. To eliminate the possibility of faulty networking cable, I used the same port and cable for my Apple TV unit. It worked just fine. The the TEW-MP1U appears to be a brick at this point. It only gives a green status light, my appears to have no network functionality any longer, wired or wireless. What gives?????????????
Apr 02, 2011 | Trendware (TEW-MP1U) Print Server
I cant use usb printer to get print out from dos base softwear
If you are using a NT based Windows (ex. win nt, win 2000, win xp, etc...) you could try sharing the printer than MAP it as a network printer and direct it to a virtual LPT port with a DOS command ex: net use lpt2: \\ComputerName\SharedPrinterName /yes
Than setup the DOS software to print on LPT2 it should worke, i've done this many many times
Note: if you absolutely have to use LPT1 dont forget to change the physical LPT 1 port in Windows hardware manager to something els so it do not conflict with the virtual one
Feb 15, 2011 | Epson LX-300+ II Matrix Printer
"how to print settings for
If you are talking about one of the TallyCom print servers there is a small blue test button on the side of the box, press this when the print server is connected to a printer that is online. If you press the test button for over 9 seconds the print server will be reset to factory settings. If you want to print from DOS to a network printer as I recall you have two options; 1) Install the printer in Windows and share it, you can then print to the share name 2) Use "NET USE" command in DOS to map a local port to a network port, this is nessesaey if you can not print to LPT1 or COM1 from the application. For help of NET USE go to DOS and use the help options.
Jan 05, 2011 | Tally (43555) Print Server
Can't get to websites that require a log on ; can get on to internet but any place i have to log on and give a password, it says internet explorer cannot display page; can't access email so don't email
got to run then type CMD enter a dos promt will show on the screen, type IPCONFIG, check your IP address if it istarts with 169 then that is APIPA a windows feature if threats are tryin to get in your system blocking any outside access to you system from any network, also check if the default gateway of your router or modem is detected, if not then try check conenction if all are ok from router to modem and if wireless is turned on thr router providing a signal to your computer for wireless, if all Addressess are ok and still you get page cannot be displayed type in the DOS promt ping 69.147.125.65 this is yahoo.com if this pings yahoo's ip address then your problem is with the DNS of your Internet service provider, try this to renew your DNS ipconfig /flushdns then ipconfig /registerdns to renew ur DNS on the systm if still fails ty a different browser and if all else fails call ur ISP provider posibble something on the internet service is wrong or downtime issue on the internet
Jun 04, 2010 | Microsoft Windows XP Home Edition
Upon booting, i get dos prompt, doesn't do anything further
No compatibility problem in your case. XP should work well with Dell optiplex gx280. Try re-installing the OS, there is problem with the OS version you had used to install.Rate me if it is useful!!
Aug 19, 2009 | Dell Optiplex GX280 (99301) Motherboard
Landtech dos for windows - new systems (XP) need to windows
you can get a hub for the lpt and usb try www.tigerdirect.com
Jan 25, 2009 | Intuit QuickBooks Pro 2008: Windows
Can't Boot
restore disks are not worth a w**k......
all you need is xp disk with a cd key...
you can repair (dos prompt) or reinstall or repair(windows app)same as restore.
you can download xp/xppro of net though it does take a while.
if you have ares you could get off me my pc has been uploading xp pro with sp2 integrated all day and most of the night to various people also xp pro with sp3 integrated I also have iso of xp pro sp3 integrated and registered all you have to do is load it then install updates dont even need the key cos that also is integrated.
can give you links if you want but like I say it takes a while to download.
Jan 25, 2009 | Computers & Internet
Cannot print from DOS mode of shared printer
Make sure that your computed is on the same workgroup or domain as the other computers are.
You can check that by going into the control panel. Press system. Press the computer name tab. Change the domain name or workgroup accordingly.
Oct 31, 2008 | TallyGenicom 6312 Matrix Printer
How do I know what my IP address is?
If you are running Windows XP you can click on Start>>Run>>type in CMD...this will open a command promt (DOS) window. Typpe in: ipconfig. This will give you your IP address, subnet mask and your default gateway.
I hope this helps!
Sep 24, 2008 | Lexmark Office Equipment & Supplies
Printing from Dos Prompt
1. Save your text file (.txt).
2. On the command prompt navigate to that directory
3.Type "Lpr -S 192.168.1.200 -P lp text.txt"
Substitute 192.168.1.200 for your copier's ip
Substitute text.txt to filename.
Or you can: to print from MS-DOS apps.
1. Share the printer on a networked windows computer. Make sure you make the name MS-DOS compatible.
2. At a DOS prompt, type the following command:
"net use lpt1: \\servername\printer_share/persistent:yes"
NOTE Servername=computer name
printer_share=printers share name
Sep 28, 2007 | Office Equipment & Supplies
Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC Logo
115 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
