Question about RCA HD52W59 HDTV Projection Television
Front screen The front screen cracked, need to replace it. Is the front screen just a piece of plexiglas? I see how to remove it, looks like maybe 8 or 10 screws to remove the frame work around the outside screen, anything I need to be aware of? Thanks
  • Ocky57 Jan 12, 2008
    Ok, Thanks for the info, will give it a shot.
    Genius:
  • 1,153 Answers
Be aware of bottom middle because there is a tab that sticks up thru the hole that can be alittle hard to come off. You can find Protection screen at Vancebaldwin.com
Posted on Jan 12, 2008
My Samsung frontload washer has detergent trapped on the front Plexiglas. It seems to be between two pieces of Plexiglas because I cant clean it with a rag on the outside or the inside your thoughts
it probably just ran down from the soap box, the door is in 2 halves held together by tiny clips and about 10 large screws on the inside of the door, if you really want to clean it just remove all the screws then pry the 2 plastics halves apart (it will resist a fair bit as the tiny clips on the inside will hang on once the screws are out) the whole door will come off and you can remove the glass and clean it
Jan 29, 2017 | Samsung Washing Machines
How to change bulbs on Dimplex HTN 20
If you have a compact fireplace in a cabinet mantle, you will need to remove the front Plexiglas and frame from the front of the firebox. Remove the logs, then the 1- piece ember bed (it just lifts out). This will give you access to the light bulbs.
If you what looks like an old wood stove, you access then from the rear of the unit. Remove the bottom access panel by unscrewing the 4 screws that hold it in place. You can then reach the light bulbs to change them.
In both cases, the replacement bulbs are small base chandelier bulbs.
Hope this helps to solve your problem.
Mar 11, 2011 | ACE Dimplex (r) Compact Electric Fireplace...
My son hit the tv with a wii control. The tv screen now has a "cracked" look to it and a lot of lines going down the screen. Is there anything we can do to fix this?
Hello; Your LCD panel is cracked. The new panel if even available will cost more than the set sells for. Some people buy these sets to harvest parts, but don't expect much. The cracked sets are everywhere and often go to the dump. On your next set, put a 1/8" piece of clear Plexiglas over screen. John
Jan 26, 2011 | Vizio L32 32 in. LCD HDTV
THE SCREEN ON THE PANASONIC PT-53WX42F CRACKED WHILE MOVING IT
Depending on how bad, there are many layers of screen, if the outer layer is smooth and does not have ridges you can use a piece of Plexiglas to replace that. although glare may be more prevalent with a Plexiglas replacement. if the outer layer has ridges or more than one layer is broken there is not much you can do yourself. The screen from the manufacturer is cost prohibitive to replace. But if you have a local tv repair shop they may have a junk one, that they can sell you for a reasonable price. If it is just a small corner it might be better not to do anything at all, when you watch a tv it is the middle of the tv you watch and the corners are hardly noticeable under normal tv watching, although it may bother some people that the crack exists it actually may not cause you much discomfort watching the tv.
Oct 12, 2009 | Panasonic PT-47WX49 47" Rear Projection...
Tv lcd screen got knocked know a red line and a dark patch is getting bigger across screen
You have damaged the LCD Display, the cost of those are close to the cost of a new set. One day the manufacturers will put a safety screen on the front like the older projection sets had to protect those screens. When I sell a lcd set I always recommend to the customer to have a piece of Plexiglas installed over the front, especially if it's for the kids room. Of coarse it's a DIY project.
May 31, 2009 | Goodmans GTVL32W27HDF 32 in. LCD TV
How do I remove the screen on a Sony KP-51ws520?
Below are 2 images which helps you to remove front screen (Beznet Assembly)
Good luck.
Jan 09, 2009 | Toshiba 50HDX82 50" Rear Projection...
Front door plastic face plate of washer HE3t
yes. there aretorque screws around the inside frame remoive them and the 2 pieces will seperate. you can replace it then. be carefull if you remove the screws from the hinge the whole door will fall off. only six or so screws need to be removed
Jan 04, 2009 | Kenmore Elite 45986 Front Load Washer
Crack on screen, tv working good couple mounths old (LG 32LC5DC), how much to repair it?
The screen has a Plexiglas protector over the actual screen. If that is all that is cracked you can go to the hardware and have them cut a piece of Plexiglas the same size. an It's fixed much cheaper the ordering a factory replacement.
Jul 25, 2008 | Televison & Video
Reply to my post on how to remove front panel.....
I WOULD NEED TO GET THE SERVICE MANUAL FOR THAT. YOU CAN CALL RCA THEY CAN TELL YOU. IF YOU WANT TO REPLACE IT I THINK YOU CAN GET A PIECE OF PLEXI GLASS FROM LOWES OR HOME DEPOT. IF YOU MEASURE IT TO THE 1/8" THEY CAN CUT IT FOR YOU.
DON..
Apr 26, 2008 | Televison & Video
RCA HD52W59 HDTV Projection Television Logo
110 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
