HP Photosmart C6280
How do I enter a special key combo for the HP C6280? There are no number keys.
  • 1 more comment
  • Troubled XO Jun 11, 2008
    I pressed the Red Eye Correction along with the Print Photo Button, the display gives me the same Question: Enter the Special Key Combo. Does anyone know what the key combo is?
    a million thanks
  • Sunrayecho Mar 06, 2009
    I have installed a HP Photsmart C5280 All-in-one-printer within the last 7days. It has now come up with a display that states "Msg Command - Enter Special Combo". There are NO instructions in the Operating manual on how to deal with this fault. I have checked troubleshooting sites for similar but they affect other models of HP printer and not mine so the remedies are not the same. Has anyone else experienced this problem and what is the resolution. Obviously the printer is under warranty and that may be my final resolution. Any help appreciated! This printer replaced a HP Photossmart 2575 All-in-one that had similar problems. I am not over-amoured with HP at this point in time!!
  • lranere Mar 11, 2009
    same problem...never got it working properly and now is past warranty! let me know if anyone figured it out
If you have the photosmart with a blue dash key, a grey dash key, and the green dash key, enter them in the order installed on the machine, blue, grey, green. that is the combo for the HP photosmart c4400 series and others.
Posted on Mar 19, 2009
  • andyman100 Mar 19, 2009
    sorry, i screwed up, i thought it was a printer for a sec. disregard mine
I have the same problem with the HP C5180 won't go no further and is now a brick! Any suggestions? Never had it working at all
Posted on Jul 06, 2008
What is the Special Key Combo
•"print photo" + "red eye removal" buttons pressed together
•printer will not ask you to enter the combo
•release the buttons you pressed then
•press "red eye", "print photo", "red eye" in sequence
•scroll down or right until you find resets menu
•press ok
•scroll down or right until you find semi-full reset
•press ok
•your printer should turn off, wait for 3 minutes before turning the printer back on
(i may represent HP but this advice is solely my own)
Feb 03, 2015 | HP EPPSC5280PHOTOTRAYAS PhotoSmart C5280...
Hello, my printer had several paper jams... Now, once the paper jams are gone, it skips and then shoots the paper out. I can not align the paper or calibrate it.
- Press and hold the "*" key.
- Press the "#" key and release both keys.
- Display should say "Enter Special Key Combo" then release the keys and press "1", "2" and "3" buttons in sequence.
- then you will get few options, now look for an option that says "System Menu or System Information" using arrows keys.
- Press "OK" on it & now look for "semi full re-set and press ok".
- Now printer will turn off and will turn on automatically after few seconds.
- Now printer will align it automaticaly.
Feb 25, 2011 | HP Photosmart C6280 Printer
Having difficulty getting my HP photosmart 3310 to print! Tried all the suggested reset options etc. even was able to get to the 'OVM reset', however, I'm still getting an ink failure msg... and when I...
There are several special key combo for ex. 1-2-4 and 3-2-9 also 1-2-7 depending on the purpose of using it.
My suggestion would be,
Remove the cartridges,
Clean the golden ( electrical contacts ) with lint free cloth
Put the cartridges back and check if the error message disappears
If not,
Try the Full reset following these steps
Disconnect the power cord from back of printer ( while printer is on )
While holding the # and 6 button, connect the cord
( if you do this reset, the printer will loose all the memory it has stored like fax logs, will get disconnected from Wireless network )
The error message is likely due to a cartridge expiry date and certain printers do not accept such expired cartridges from present date. Try replacing such cartridge
Oct 12, 2010 | HP Photosmart 3310 Printer
How do I fix Error:Oxc18s0301 Ink system failed.
Try using these two reset instruction...these clears most of hp errors starting with 0xc...It works on different hp models.. it could work on you too.
Semi reset
1. While your printer is on.. unplug to power cable from the printer.
2. Press and hold the "OK" and "HELP" buttons while you plug the power cable at the back of the printer. Try these steps to reset your printer to default setting.
Full reset
1. Press & hold " * " key...(asterisk sign)
2. While holding the " * ", press "#" key and then release both keys..."Enter Special Key Combo" will be displayed...
3. Press "1", "2" and "3" to display Support...
4 Press ">" right arrow button and release when System Config Menu appear....then click OK
5. Press arrow key to display Hardware Failure Status...click OK....
6. When Hardware Failure Status:Clear appeared, press "OK" to clear...
7. Press "OK" again to display "Hardware Failure Status Cleared. Press Cancel To Continue".....
8. Press "CANCEL" as many times to display "Welcome To Photosmart Express" or "Ink System Failure".....
9. The last part is to turn off the printer and unplug at the back...wait for 30 sec, then plug and turn on the printer...if asked, press "OK" to continue and allow the "One Time Ink Initialization" to proceed..After this try to print...
If you find the reset solutions helpful to you...Please rate this solution and vote on this on the YES below..thanks..
Aug 20, 2010 | HP Photosmart C6280 Printer
Hp photosmart C6280 ink system has failed. what do I do?
Please follow the below steps.
STEP 1.
1. Un plug the power chord from the back of the printer.
2. Press and hold the power button of the printer.Wait for 30 seconds.
3. While holding the power button, re-plug the power cable.
4. Turn on the printer, if it is not on.
STEP 2.
Reset the All-in-One to the factory default settings by using these instructions:
1) Press Red Eye Removal & Print Photos button simultaneously
2)Enter Special Key Combo is displayed on the screen.
Press and release in sequence "Red Eye Removal", "Print Photos", "Red Eye Removal"
Display should say "Support" and display the FW rev XXXXX.
3) Press Right Arrow button untill "Reset Menu" is displayed. Press OK.
4) Press Right arrow untill "Semifull Reset" is displayed.
5) Press OK.
Apr 28, 2010 | HP Photosmart C6280 Printer
I have a HP 3300 photosmart printer, have an error code that says 0xc18a0507?? i cant print or anything..
Try doing a reset by holding down the * and Menu/Enter keys while plugging in the unit, hold the keys down until the screen says that it is resetting.
The 3300 also has a "Secret Menu" that can be accessed by;
To View The Secret Menu:
1: Press Both The Left And Right Navigation Arrow Keys
2: It Will Ask You To "Enter A Special Key Combo.", Enter "123" (Without Quotes)
3: You Should Be In The Secret Menu Now.
P.S. Use The Arrow Keys To Navigate.
The manual can be found at;
http://www.fixyourownprinter.com/reference/manuals/public/hp
Hope this helps!
Dec 09, 2009 | HP LaserJet 3300 All-In-One Printer
Message states: the following ink cartridges cannot be used after device intialization, and must be replaced
Try the following steps to resolve the issue,
1.) Press & hold the * key
2.) press the # key & release both the keys.
3.) Display should say Enter Special Key Combo - Press & release in sequence 1,2 & 3 buttons.
4.) Press and release the right arrow button (or the right arrow icon on touch screen displays) to look for the System Configuration Menu then press OK.
5.) Press and release the right arrow until the Ink Initialization status is displayed.
6.) Press and release the OK button.
7.) Display should say Ink Initialization status: Clear. Press OK to set it.
8.) Press and release the OK button ONCE. (This is very important; do not press the OK button for a second time).
9.) Press the cancel button three times to leave the support menu.
10.) Unplug the unit from the power supply and wait 10 seconds.
11.) Plug in the unit, Follow the on-screen instructions, the unit will initiate the initialization cycle.
Thanks,
Fame..
Oct 23, 2009 | HP Photosmart C6280 Printer
False error empty cartridge
HP C6280 reset:
3) Press Right Arrow button until "Reset Menu" is displayed. Press OK.
4) Press Right arrow until "Semi full Reset" is displayed.
5) Press OK.
Now, check the functionality of the All-in-One.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
May 31, 2009 | HP Photosmart C6280 Printer
Error Oxc18a0001 on an HP C6280
Press and hold the "*" key. Press the "#" key and release both keys.
Press and release in sequence the "1", "2" and "3" buttons.
Display should say "Support" and display the FW rev (something like R0631R)
Mine reads R0631M
. Press and release the right arrow button until the display says "System Configuration Menu".
Press and release the "OK" button.
Display should say "Hardware failure status". If not there already, Arrow Key over to "Hardware failure status",
Display should say "Hardware failure status: Clear. Press OK to clear".
Press and release the "OK" Button. Message changes to "Hardware failure status Cleared. Press Cancel to continue".
Press and release the "CANCEL" button as many times as necessary, so that, either the "Welcome to Photosmart Express" screen appears, or, the "Ink System Failure" screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.
Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.
Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer.
Turn the unit on. The printer may display message "USE POWER BUTTON TO SHUTDOWN THE PRINTER" followed by "PRESS OK TO CONTINUE". Press OK. The Printer will start the "ONE TIME INK INITIALIZATION PROCESS". Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page. Good Luck!
Jul 08, 2008 | HP Photosmart C6180 All-In-One InkJet...
Computers & Internet Logo
892 people viewed this question
Alun Cox
David Payne
David Payne
