Question about Microsoft Xbox 360 Console
PC Selected - Failed
Help, I'm trying to stream movies & music down from my PC to my xbox 360. when i test my media connection it tells me that PC selected - Failed
My network route
Internet->Belkin F5D5231-4 Cable/DSL Gateway Router->then 1 x ethernet cable to my PC and 1 x ethernet cable out to my xbox.
Xbox live works without any problems. I have wmp11 set up to share with my xbox. ive turned windows firewall & Mcafee fire wall off and forwarded the correct TCP&UDP ports on my router.
How can i fix this problem
  • 1 more comment
  • ayjay80 Jan 14, 2008
    Thanks for the idea. After reading various forums and trying numerous fixes, I think deleting the files in my DRM folder coupled with restarting my windows media player network sharing services it seemed to work.
    Cheers anyway
  • nell13 Jun 03, 2008
    it use to stream music but now it doesn't and when i did the test it said PC selected failed. please help
  • Chipclips Nov 25, 2008
    every time i put one of my games in the disk slot on my x box 360 the game never works and i have notist that there is a noise every time i do put the disk in that it apers to be un read able
Click Start, click Run, type cmd.exe, and then click OK. a. At the Command Prompt, type the following text all on one line: reg add HKEY_LOCAL_MACHINE\SYSTEM\CURRENTCONTROLSET\CONTROL\CLASS\{4D36E967-E325-11CE-BFC1-08002BE10318} /v UPPERFILTERS /t REG_MULTI_SZ /d PartMgr /f You receive the following message in the Command Prompt window, to indicate that this command was accepted: The Operation Completed successfully After you done that restart and download xboxxpsp2-enu.exe...and you should be good to go if your firewall ports are open 1900,10280,10281,10282,10283,10284 dup and 2869,10243 tcp good luck Restart the computer. 4. After the computer restarts, you can run the Media Center Extender for Xbox 360 application
Posted on May 07, 2008
Help !
Posted on Feb 07, 2008
    Problem Solver:
  • 8 Answers
Wmp11 streaming works upon universal plug and play on your router to direct streaming. I have had this problem too. Maybe people do. I found that upnp on my router was always the problem. Make sure it's enabled, and if you have not restarted your router do that. and after you enable upnp, its a good idea to restart it also. I'd give it a 75% chance its a universal pnp problem. Yet if your port forwarding, you might need to disable it, i dont know, i always just used upnp for simplicity. Finally, double check you have a static ip for your port forwards if you continue on that route.
Posted on Jan 13, 2008
  • mark w Jan 14, 2008
    lol ya drm would do it
Xbox wont let me play movies from my pc 69-807B0191
Xbox 360 has limited codecs, if you want to utilize more file formats download the media pack on xbox live. but for your streaming pleasure try out TVersity or PS3 Media Server it also supports xbox. just install it on your PC then stream the videos to your xbox.
Mar 23, 2011 | Microsoft Xbox 360 Console
Tip
Stream AVCHD videos to Xbox 360 via DLNA-AVCHD to Xbox Converter
Xbox DLNA-AVCHD MTS/M2TS to Xbox 360 support formats on Windows 7 <br /><br />Generally, I have my video to be kept in a D-Link NAS box, so that I can watch them on Xbox. The NAS is quite old, and I will buy a home server similar to the HP models one day. Xbox has a "Windows Media Center" window in the dashboard view, and <b><a href="http://dts-ac3-converter.com/2011/07/stream-avchd-videos-to-xbox-360-via-dlna-avchd-to-xbox-converter/">Xbox Streams videos from NAS via DLNA for HDTV</a></b>. <br /><br />However, the AVCHD files from my Sony DSC-TX100V could not read by Xbox. While looking for the solution to <b><a href="http://www.aunsoft.com/final-mate/">stream AVCHD videos to Xbox</a></b>, I find Aunsoft Final Mate as the recommended AVCHD video converter and joiner with best quality. After dealing the AVCHD files with Final Mate on Windows 7 Premium, I can share the videos using Windows Media Center software for streaming. <br /><br />Below is just a simple guide with AVCHD to Xbox supported format. <br /><br /><b>Step 1. Import AVCHD videos to Final Mate.</b> <br />Run Final Mate as the <b><a href="http://www.aunsoft.com/final-mate/">best AVCHD to Xbox converter</a></b>, and click the Add file path button on Resource tab to browse the folder with .mts or .m2ts files on PC hard drive. For videos from camera, just connect camera to PC via USB cable, and follow the pop-up wizard to import videos. <br /><br /><b>Step 2. Select and join AVCHD files for output.</b> <br />Select the clips on Resource tab or Camcorder tab, drag and drop to the Movies tab. You can create a movie for each file or a movie with several files with conversion. For another movie, just click the Create New Movie button. <br /> <br /><b>Step 3. Choose Xbox format.</b> <br />Click the icon next to the Movie name in the Movies tab, you will see the format options. Move to the Device group, find Zune/Xbox 360 Device and choose Zune Xbox 360 - Windows Media Video(*.wmv) as output format. <br /><br />Click Export button, and the conversion from <b><a href="http://www.aunsoft.com/final-mate/">AVCHD to Xbox 360 support format</a></b> will start right away. Wait for a while, and put the videos to the video folder for sharing. Xbox 360 then can stream videos from the NAS via DLNA.
on Jul 15, 2011 | Sony Alpha DSLR-A580 Body Only Digital...
How to play video/music on xbox what formats does it support
Movies I convert them to .avi and stream them from my PC to 360. Music is .mp3. Again I stream these from my PC. You can put a music cd in the 360 and copy the contents to the HDD.
Here's a link for one of my other answers to link your PC to 360:
http://www.fixya.com/support/t6640258-connect_pc_xbox_360
If you need any nore help let me know
Nov 25, 2010 | Microsoft Xbox 360 Console
How to stream video through xbox
on the dash board go to media center
write down the 4 digit number and log onto the site it tells you
enter in the number
you will use the media center to look at pics listen to music or watch movies off any windows pc on the network in your house. If you have multiple computers in the house you can access them all with the media center extender.(your 360) it streams all this over your network. sometimes this can be a problem due to lagging. I bought a Western Digital 1terabyte (1000GB) my passport external hard drive and formatted it to FAT32 and backed up all of my music and movies off my computer to it. the external hdd runs off of a usb and doesn't need to be plugged into the wall so I can take it any where. it is a little bigger than my iphone. it works on my 360 and ps3 great. if you have xbox live download the "optional media update" from the marketplace for free to be able to play more types of video formats. you don't need a gold subscription to do this
Oct 17, 2010 | Microsoft Xbox 360 Console
How do i get windows media to work on my xbox
To use your Xbox360 as a Media Center Extender, you must "link" the Xbox to your Media Center PC. Follow these instructions:
http://support.xbox.com/support/en/us/nxe/xboxlive/troubleshooting/networkhelp_mcxpc.aspx
This should only need to be done once. If you just want to stream music/movies from your PC, it should be auto-detected by the Xbox as long as it's on the same network. Make sure you have the latest version of Windows Media Player (version 11).
May 02, 2010 | Microsoft Xbox 360 Console
I wanna use a phone line to get the internet and the music off my laptop to connect to my xbox 360...?
Phone line? As in dial up? No dice. You need, atleast, a DSL connection or faster to get Xbox live.
You can use a UPnP media server, such as TVersity to stream music from your laptop to the 360. What's cool about TVersity is that even though the music you want to play is an unsupported format for your Xbox, it will automatically transcode (make it into something the Xbox 360 can play).
If you have a broadband connection (e.g. DSL, Cable, Sat, etc.) you can have Tversity stream your favorite internet radio stream to your Xbox 360.
Download the latest Windows Media Player, Tversity or These other media servers, install, configure (TVersity is fairly easy to setup), and go look for the Tversity folder in your Music section in the NXE menu.
I wrote a how-to on setting up TVersity here if you need help setting it up.
Hope this helps,
Bill
Sep 06, 2009 | Microsoft Xbox 360 Console
Pc with xbox problem
When you get to the Market place scroll down with your D-pad and stop on Redeem Code, insert the code info from your new card, select the profile you want to associate it with and that should update your account with your new paid subscription.
Aug 27, 2008 | Microsoft Xbox 360 Console
PC Selected test failed
hi i had this problem so i went to wireless but my m8 just had the same but it does not matter if it comes up or not it will still wrk all it means is that u can not tranfer any music or anything like that m8 so no need to worrie
Apr 23, 2008 | Microsoft Xbox 360 Console
Problem with streaming from my laptop to my xbox 360 wirelessly
Call microsoft for a solution, they will most likely know in a few minutes. Even though you get punjab from india.
Mar 02, 2008 | Microsoft Wireless Network Adapter Xbox...
Microsoft Xbox 360 Console Logo
584 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Stu Morris K
shaun taylor
mitch_3020
mitch_3020
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
