Question about Sony PlayStation 2 Slimline Console
Slimline hy my ps2 slimline turns off after a while please help
  • helpmeps2 Jan 16, 2008
    i have the same problem.I have 8.5 v adapter but when i plug it out i have to wait 2 or 3 min. and then when i plug it in it works fine for a while. sory for my bad english
Yes my system is overheating is there a solution tu fix that
Posted on Jan 19, 2008
Check the back see if the you have the ps2 8.5v ac adapter if you dont then get one and plug it in and if you do have one then try pluging it in and out
Posted on Jan 15, 2008
    Problem Solver:
  • 7 Answers
Maybe your system is overheating? To check if it is, place your hand on top near the back of the console.
Posted on Jan 17, 2008
  • Sub Zero
    Sub Zero Jan 21, 2008
    Well, when the system has a bad problem of overheating, WHATEVER YOU DO, DO NOT PLACE ICE ON IT. It will melt and could very well fry the machine. What you do, is place a small fan near the machine, blowing into one of the vents. Or, the other option, is Buy a standard laptop coolant device (the flat one that goes under the machine) and place it under it. And, if it needs to be plugged in Via USB, there should be USB ports on the front of your machine if I am correct.
  • Sub Zero
    Sorry if my response was a little slow.
Ps2 scph 77001 won't play backups on swap magic 3.6
This is a problem that has too many IF's in it lol. Let's take it from the top shall we?
When you said that you owned other PS2's were they the thick ones or the slim ones. Swap magic works best in the "thick older" models. In these new slimline ones it's got issues. That model number you posted belongs to a slimline model.
So since you're using a slimline model, I have to ask, Have you blocked the 2 sensors that you need to block in order to use swap magic. The slimline models are not like the older thick models. You need to block two sensors under the flip top so when you open the flip top the PS2 still thinks there is no swapping going on. If you have not blocked these sensors head over to youtube.com and start watchin vids with seach "how to block slim PS2 sensors" or "how to block slimline PS2 sensors" out of the three sensors you only really need to block two. If you have not done this at all, that is reason why it's not working. On older PS2 models you used a slidecard or some form of a flip top to swap out your disks. Nothing has changed on these slimline models. The PS2 still needs to be tricked out so it doesn't think you're swapping disks in and outa the system.
Hope that helps,
9x|
Oct 28, 2008 | Sony PlayStation 2 (PS2) Console
Slimline PS2 makes weird noises
u gota change ur ps2 lens...this problem always occures when the lens gets old!
ur only choice is to change the lens! and you can't do it alone! have to take it to experts
Sep 16, 2008 | Sony PlayStation 2 Slimline Console
Ps2 turns itself off.
Hi, I had same problem, I just changed the fuse underneath mainboard, 3.15 Amp 120V If it doesn't work change this for 4AMP fuse
Aug 11, 2008 | Sony PlayStation 2 Slimline Console
Japanese game wont play on ps2 slimline!
if its in a region lock, its impossible to be played on a American PS2, if your PS2 is modded it will read any region locked discs, the only possible solution is to buy a Japanese Version PS2
Jul 12, 2008 | Sony PlayStation 2 Slimline Console
Ps2 slimline not playig dvd's
hold "reset button" for 3 sec while turn on your ps2. always to check the region of dvd's are supported by console. hopefully this help.
Mar 03, 2008 | Sony PlayStation 2 Slimline Console
Help ps2 slimlined
there is most likely a loose connection
Feb 10, 2008 | Sony PlayStation 2 Slimline Console
Disk read error on slim ps2 scph 75003
hello pauldonp...if this is an early version of the slimline they had a problem with over voltage which inturn took out the laser.your only option may be to replace the laser . sony did bring out a mod for this..i preferr the real old version of the ps2 as they had all separate boards and if one went faulty you didnot have to replace the lot ,also the lasers were a lot cheaper than the later models .in the slim lines the lasers are not all that expensive .they do take a bit of setting up as you have to know the ohms setting on the laser for each model..hope this helps
Feb 08, 2008 | Sony PlayStation 2 Slimline Console
PS2
First off get a network adaptor)if u hav the slimline then it comes with it. Then u need 2 buy a ethernet cable. Now that you hav both turn off ur computer and router and ps2. connect the cable to the back of the router and to the back of the ps2. Then turn the router and modem on. Then turn the ps2 on. Finally place the start-up disk(which was given to you with your ps2) in your ps2 and follow the on screen directions.
Nov 03, 2007 | Sony PlayStation 2 Slimline Console
Sony PlayStation 2 Slimline Console Logo
111 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
