Question about Hotpoint Aquarius WD63 Front Load Washer/Dryer
Drum not turning
The drum is not turning although everything seems to be telling it to. i have had the back off the machine and the belt is intact and tight enough
  • 139 Answers
If you look at the motor which of course is on the top right of the drum. you will see either white or black palstic parts inserted eiterh side and a wire connected to them
These are the brush holders for the carbon brushes.. These have worn out and need replacing easily done just get yourselfthe parts and remove the old one and replace with the new ones....
Posted on Jan 13, 2008
Washing machine drum seems to be jammed. Filter is clear. Drive belt seems to be intact OK and intact. Any suggestions?
sounds like something jammed between the inner and outer drum.
sometimes people get curtain hooks jammed in there. Obviously turn off the power before you start dismantling it. Sometimes you can get access via the drain plug opening with a long screwdriver or something.
Mar 02, 2015 | Tricity Bendix AW1400W Front Load Washer
My Ariston washer dryer wont turn the drum although everything else is functioning as normal
try taking the back cover off and checking that the drive belt is not loose or come off if the motor is working that could poss be the problem
Jan 28, 2014 | Washing Machines
Changing dryer belt for lse7804ade washer dryer stacker
If the washing machine / tumble dryer / spin dryer seems to be making the right sort of noises, but the drum is not turning, unplug it, take the rear cover off and check to see if the drive belt is still intact and on the pulleys.
Mar 09, 2010 | Washing Machines
Check the belt. it may be broken or, it may have slipped of the pulley or drive motor. if the belt is fine, replace the motor.
Jul 11, 2009 | Kenmore 98702 Stacked Washer/Dryer
Washing machine WK61420GB drum does not turn
replace the brushes in the motor ( approx £5 parts)
Dec 30, 2008 | Siemens WK61420GB Front Load Washer /...
Kenmore Dryer: Drum will rotate, but only manually
Best way to confirm if it's a belt/pulley problem is to remove one of the access panels on the back of the dryer. For many models, it's on the bottom, right hand side. Open it and look inside. You also use that access panel to put a new belt on since it can be difficult to do from the front, having to reach past the drum. But if everything is intact, then you should be able to "rethread" the belt around the idler pulley and onto the motor pulley.
Here's a common diagram:
If the belt is OK, but came off the pulley, then most likely, your idler pulley has too much play in it or the spring has lost tension and isn't holding it securely. I'd put the belt back on. If it comes off again, then look into replacing the idler pulley and/or spring.
Oct 20, 2008 | Kenmore 62602 Electric Dryer
you may have some clothing or such under the drum ,
pull back the rubber lip and look under tub.
or the drum bearing is going bad.
does it turn easily .
Dec 02, 2007 | Whirlpool LHW0050PQ Front Load Washer
Zanussi tumble dryer
take it apart and you will see that the belt is probably find the belt broke
Nov 05, 2007 | Kenmore 64902 Electric Dryer
Hotpoint Aquarius WD63 Front Load Washer/Dryer Logo
Top Hotpoint Washing Machines Experts
Todd Arndt
Todd Arndt
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
