Question about NAD T531
Nad t531 when playing certain DVD's usually music related the colour guns don't seem to be synchronised giving a multicoloured ghost like image. The dvd's are usually region 0.
0 characters
1 Points
GPX plays music cd's only not dvd's
You need to replace the motor disc spindle because with time lose some velocity and thats why don't play dvds
Sep 30, 2012 | GPX D200B Player
The NAD T-550 doesn't seem to be willing to play CD-Rs. Is there any update or adjustment that can be done that will allow it to do this?
Best bet to go to their website, support, enter you model number and see if a firmware update is available.
Aug 11, 2010 | NAD T550 DVD Player
NAD T531 - reading problems
Try taking the outer casing off and manually cleaning the laser lens with alcohol , this should work for you.
Aug 13, 2009 | NAD T531
RCA drc286 screen flicker
it sounds like the vertical hold on your tv set needs adjusting also with your tv and dvd are there a set of three plugs usually red,white and yellow in colour ?? if so connect these with a cable as this by passes the tv tuner hope this helps regards JIm
Mar 12, 2009 | RCA DRC-285 DVD Player
NAD T532 probem
CD and DVD disks use a different set of optics for each type of operation. Some units have a different laser for the different format types.
The fault could be mechanical alignment, calibration, or a failure in the signal and or processor path. These types of faults are impossible to guess at.
If the unit is under warranty, contact the dealer to find out how to get it serviced. If out of warranty it may not be feasible to service.
Jerry G.
Dec 02, 2008 | NAD T532 DVD Player
"check disc"
I had a problem with my T531 similar to this and found that the area around the lens focus area was totally covered in dust/fluff as though it we acting as a "dirt magnet" every where else inside was clean (could this be a unforseen problem in the design?) once carefully cleaned the unit worked well finding discs and playing like when it was new.
Hope this helps
Aug 12, 2007 | NAD T531
Cannot play dvds
well my knowledge on dvd is not as good as I want it to bes. But, check the small print in your manual of the unit and see if it supports the formats of the dvds you are using. I know I used to get certain music cdr and burn cds on them and the cd player I had would not take certain cds. I had to see in the manual to see what the problem was and it had to be a good quality of cdrs and certain formats before it would play them. Wish I had a better answer for ya but that is the best I can do for ya. oh yeah check with some of the techs at best buy or circuit city. They have technicians in there that can probably tell ya. Make sure you have what type and model number of the unit you have and what type of dvds you have been using.
Sep 18, 2006 | Koss KS3120 DVD Player
Reads CD's but not DVD's
Hi I responded to Parisica's problem, so you have read the "bad news" already. All I can add, is that we see your problem quite often, and without spouting a bunch of tech jargon, lets just say it is easier for the laser to read Cd's than DVD's, so quite often when the laser begins to fail, DVD's will no longer play, but Cd's are fine. I'm not an expert on your model, but Parisica mentions a menu setting that turns DVD video on & off, which may be worth checking, and also cleaning may help, as a dirty laser lense can give the same symptoms as a weak laser. I don't want to get your hopes up, 2-3 years of service can certainly be long enough for laser problems, depending on how much you used it. Good Luck!
Aug 15, 2006 | Kenwood DV-6050 Multi-disc DVD Player
NAD T531 Logo
48 people viewed this question
Top NAD DVD & Blu-Ray Players Experts
Raj Patel
Are you a NAD DVD and Blu-Ray Player Expert? Answer questions, earn points and help others
