Question about AMD Sempron 2400+, 1.667 GHz (sda2400box) Processor in a Box (PIB)
Yahoo messenger installed. then sign in click closed messenger
    Problem Solver:
  • 4 Answers
Just re install the yahoo messenger...
Posted on Jan 17, 2008
6ya staff
SOURCE:
I cannot sign in into yahoo messenger,but i can sign in into my yahoo mail
First, go to you IE, Click on Tools, Click on Internet Options, Click on Connections, then check "Always Dial my Default Connection. Click Apply, Click OK.
When Yahoo detects that you've already signed into Yahoo Mail, it will disconnect you when you try to sign into messenger or vice versa - thus, the message that you are signed in to another computer.
To get rid of your problem simply disable chat in your mail account by clicking the smiley and following the prompts.
Yahoo remembers your settings until you change them.
Hitting the X on the Contacts page in Yahoo Messenger does Not Sign you out of Yahoo Messenger, it merely closes the contacts page. Always Click "Close & Sign Out" for your Y!M.
I hope this solution will act as an insurance upon soling this problem of yours
Jun 16, 2011 | Yahoo Messenger
Tip
To sort out your yahoo messenger problems please read carefully this detailed...
<br /> Hallow Friend, <br /> If you have tried restarting <span>your computer</span>,signing in with your <span>Yahoo</span> e-mail prefix (without the @yahoo.com)and your e-mail password without success, and you are sure your caps aren'tlocked and your information is correct, your <span>Yahoo! Messenger</span> connection information maybe incorrect. Follow these steps to configure your connection:<br /><br />Solution 1.) Click <span>theMessenger menu</span> in Yahoo! Messenger and select "ConnectionPreferences."<br /><br />Enable the "Firewall with no proxies" option. <br /><br />Select the <span>correct Internetconnection type</span> and country from the pull-down menus.<br /><br />Click the OK button at <span>thebottom</span> of <span>thewindow</span>.<br /><br />Yahoo! Messenger will ask you if you want to sign in again with your new proxysettings. Click the OK button.<br /><br />Enter your <span>Yahoo!ID</span> and password and click the "Sign In" button.<br /><br />The above configuration works in most situations. (However, if you connect inthis way, you won't be able to use the Voice feature.) If this configurationdoesn't work, follow these steps:<br /><br />Click the Messenger menu in Yahoo! Messenger and select "ConnectionPreferences."<br /><br />Enable the "No network detection" option and then click the OK buttonat the bottom of the window.<br /><br />Yahoo! Messenger will ask you if you want to sign in again with your new proxysettings. Click the OK button.<br /><br />Enter your Yahoo! ID and password and click the "Sign In" button.<br /><br />If neither of the above options work (sorry), you're probably behind a firewallor <span>proxy server</span>that requires you to enter its address. Follow these steps:<br /><br />Click the Messenger menu in Yahoo! Messenger and select "ConnectionPreferences."<br /><br />Enable the "Use proxies" option.<br /><br />Enter your firewall or proxy server's address and port number. Contact your <span>network administrator</span>(if you're at work), or your <span>Internet service provider</span> (if you're athome) to determine the correct firewall and proxy settings.<br /><br />Click the OK button at the bottom of the window.<br /><br />Yahoo! Messenger will ask you if you want to sign in with your new proxysettings. Click the OK button.<br /><br />Enter your Yahoo! ID and password and click the "Sign In" button.<br /><br />If you try all of the steps above and Yahoo! Messenger still can't connect,contact your network administrator, Internet Service Provider (ISP), or theperson who initially set up your computer to ensure that your firewall and/orproxy settings are correct.<br /><a href="http://help.yahoo.com/l/us/yahoo/messenger/messenger8/messenger/messenger-11.html">http://help.yahoo.com/l/us/yahoo/messeng...</a><br /><br />Solution 2.) You may have accidently saved your ID or password with errors init. To resolve this issue, clear your cache.<br /><br />For <span>InternetExplorer</span>:<br />Click on: Tools<br />Click on: Internet options<br />Click on: Delete Cookies<br />Click on: Delete <span>Temporaryfiles</span><br /><br />For Firefox:<br />Click on: Tools<br />Click on: Clear private data<br />Check: All the boxes<br />Click on: Clear private data now<br /><br />Now try to log onto <span>Yahoo Messenger</span>. <br /><br />Solution 3.) If Step 1 and Step 2 don't solve your sign in issue, tryun-installing then re-installing Yahoo Messenger:<br /><br />Close Yahoo Messenger<br />Click on: Start<br />Click on: <span>ControlPanel</span><br />Click on: Add/remove programs<br />Locate and remove Yahoo Messenger<br /><br />Download Yahoo Messenger:<br /><br />Yahoo Messenger for Windows: <br /><a href="http://messenger.yahoo.com/">http://messenger.yahoo.com</a><br /><br />Yahoo Messenger for Vista:<br /><a href="http://messenger.yahoo.com/windowsvista.php">http://messenger.yahoo.com/windowsvista....</a><br /><br />If you are still unable to sign in, on Internet Explorer:<br /><br />RESTART YOUR COMPUTER<br /><br />If that doesn't help, here is a link to <span>Yahoo Help</span>:<br /><br />IMPORTANT: If all of the above does NOT solve your problem, here is a link to <span>Yahoo! MessengerHelp Form:<br /><a href="http://help.yahoo.com/l/us/yahoo/messenger/messenger8/help8.html?from_url=http://help.yahoo.com/l/us/yahoo/messenger/contactus/contactus-01.html">http://help.yahoo.com/l/us/yahoo/messeng...</a><br /><br />For future reference, please note there is a link to Yahoo Messenger Help atthe very top of your Yahoo Messenger!</span>
on Apr 27, 2011 | Computers & Internet
Why my messenger closes when i open yahoo mail?
Hi
Welcome to FixYa.
Your yahoo messenger close when you open yahoo mail because on your yahoo mail the chat automatic sign in. For you to be able to sign-out that follow the steps below.
1. On the top page you will the see "Available" there is an icon "arrow down" click on that icon.
2. Click "sign out of Chat"
3. You will be offline for chat on your yahoo mail
4. Then sign in on your yahoo messenger.
Hope this information can help.
Thank you for using FixYa.
Mar 23, 2011 | Yahoo Messenger
Yahoo messenger is closed after sign-in
1. Reboot your computer. 2. Press Ctrl+Alt+Del on your keyboard. Thiswill bring up the Windows Security window. Click the "Task Manager"button and then click the "Task Manager" tab. 3. You will see a list offiles/applications. These are the applications running in the background onyour system, whether they show on your taskbar or not. Any one of theseapplications could be causing a conflict with the Yahoo! Messengerinstallation. 4. Click the top item on the list tohighlight it. Then hold the "Shift" key down and click the last itemon the list. This should highlight the whole list. 5.Click the "End Task" button. This will temporarily close allbackground applications on your system. 6. Click the "X" in the upperright corner to close the Task Manager window. 7. Install Yahoo! Messenger. You should notexperience the same issue that you had before. 8. After Yahoo! Messenger is installed,runregistry cleaner reginout also rebootyour system. All other background applications will return to their originalconfigurations.
Feb 17, 2011 | Yahoo Messenger
I GOT A SIGN OUT WARNING, CLICKED THE CLOSE X. NOW I CAN'T GET MY YAHOO INSTANT MESSENGER TO REOPEN? HOPE YOU CAN HELP ME???
Clickthe "Messenger" menu in Yahoo! Messenger and select "ConnectionPreferences." 2.Enable the "No network detection" option and then click the"OK" button at the bottom of the window. 3.Yahoo! Messenger will ask you if you want to sign in again with your new proxysettings. Click the "OK" button. 4.Enter your Yahoo! ID and password and click the "Sign In" button. youmay have a registry problem download registry cleaner reginout to fix the issue
Feb 12, 2011 | Yahoo Messenger
Always hang up every time i sign in to my yahoo messenger.
uninstall messenger and then Reboot your computer. 2. Press Ctrl+Alt+Del on your keyboard. This will bring up the Windows Security window. Click the "Task Manager" button and then click the "Task Manager" tab. 3. You will see a list of files/applications. These are the applications running in the background on your system, whether they show on your taskbar or not. Any one of these applications could be causing a conflict with the Yahoo! Messenger installation. 4. Click the top item on the list to highlight it. Then hold the "Shift" key down and click the last item on the list. This should highlight the whole list. 5. Click the "End Task" button. This will temporarily close all background applications on your system. 6. Click the "X" in the upper right corner to close the Task Manager window. 7. Install Yahoo! Messenger. You should not experience the same issue that you had before. 8. After Yahoo! Messenger is installed,run registry cleaner reg in out also reboot your system. All other background applications will return to their original configurations.
Oct 04, 2010 | Yahoo Messenger
Cannot open yahoo messenger, yet i am signed in
Try using the below website for signing in:
http://webmessenger.yahoo.com/
If that work than the issue is with the Messenger application reinstall the messenger.
Sep 05, 2010 | Yahoo Messenger
Problems signing in
If Yahoo Messenger is not responding after clicking Sign In, it could be the root file is corrupted. You can try to uninstall/re-install the YM and it should work.
Have a great day!
Sep 12, 2009 | Yahoo Messenger
Problem signing into Yahoo Messenger.
uninstall yahoo messenger completely and download a fresh one, re install fully, if still has errors, contact ym http://help.yahoo.com/l/us/yahoo/messenger/contactus/contactus-01.html
Nov 20, 2008 | Yahoo Messenger
Open Questions:
See all AMD Sempron 2400+, 1.667 GHz (sda2400box) Questions
AMD Sempron 2400+, 1.667 GHz (sda2400box) Processor in a Box (PIB) Logo
Top AMD Computers & Internet Experts
Ekse
Alun Cox
Carlo Barzo
Carlo Barzo
Are you an AMD Computer and Internet Expert? Answer questions, earn points and help others
