Question about Eagle IntelliMap 500C GPS Receiver
Marine GPS I have a Eagle Intellimap 500C which has 2 problems. 1. It tells me "The GPS module is not responding" 2. The unit turns itself on and the screen goes haywire with lots of noise> The Unit is 14 months old. Any solutions? Thanks.
Change the antenna with new
Posted on Jul 08, 2008
How do u put the gps locations in the Eagle Fishmark 500c Color Fishfinder
Hi, no good news I'm sorry. It's a fish finder not a combo fish finder/gps so you are unable to enter co-ordinates. Sorry Phil.
Sep 22, 2011 | Eagle Fishmark 500c Color Fishfinder
The Eagle 640c will not show the second Menu any ideas
try whats called a "soft start reboot"it worked for same prob on my one. with unit turned off hold down pages and power keys until it starts up and map of usa appears,release keys. you wont lose any waypoints or data but youll have to reset units of measure etc.
Dec 23, 2010 | Eagle Intellimap 640c Marine GPS GPS...
Hi,it does nt want to pick up any satellities
How long are you leaving it?
Sometimes when the GPS unit is off for an extended period of time or if it is off and you travel and turn it on when you have travelled somewhere, the GPS needs to take in new information and I have seen it take about 45 minutes or more the first time. Leave it be for a while, once has picked up the satellites the first time, they will come in just as normal all of the following times.
Feb 06, 2010 | Eagle IntelliMap 500C GPS Receiver
Fish finder manual
hello there:
here is a link that will help you get the manual u need ok?
best regards micha
Eagle 250 DS - FishEasy GPS safe.gif Learn more about the Eagle FishEasy 250 DS before you decide to buy. Download User Guide and Manual ... fish finder EAGLE FISHEASY 250DS. www.bestfishfinder. ... - 69k - Cached el
Aug 27, 2009 | Eagle Fisheasy 250ds Fishfinder
Eagle 640c Fish Finder dosen't read corectly.
I had the same problem and got the transducer changed. It now works perfectly. That could be the problem you are having... bad transducer.
May 17, 2009 | Eagle Intellimap 640c Marine GPS GPS...
Alarm says" gps module not responding"
"GPS Module Not Responding" is the display units way of telling you there is basically no GPS module connected. You didn't say which unit you have, so I am assuming this is something like an LMS-520? The GPS module is the LGC-3000? If this is the module you have, make sure that you have powered the NMEA 2000 network. The display unit's power cable has a set of red, black, and sheild wires that need to be hooked up to a 12VDC power source. There is a power diagram somewhere in the manual that should show this.
Make sure that you have the NMEA 2000 network connected properly. If it is a newer version, it should just be a single 15ft cable that has two female ends, the module plugs into one end, and the other end plugs into the back of the display. If it came with some T connecters and 120Ohm Terminator caps, then make sure you have that hooked up correctly. There should be a diagram in the manual for that as well but you just connect the two T's together like TT, put the 120Ohm terminators at each end, and run the extensions to the display and GPS module.
There is a decent troubleshootin guide for checking to make sure power is getting to the module at
If this doesn't tell you anything, most likely the GPS module is bad.
Apr 05, 2009 | Lowrance Lcx 28c Hd 7" Gps Fish Finder...
Mio digi walker 220
I had that error and when I did a restart (hold in the power button for 10-15 seconds to turn off then again for 10-15 seconds to turn on) the unit restarted fine. Try that.
Mar 01, 2008 | Eagle IntelliMap 500C GPS Receiver
Eagle IntelliMap 500C GPS Receiver Logo
399 people viewed this question
Top Eagle GPS Experts
Computer Links
carl blood sr
Are you an Eagle GPS Expert? Answer questions, earn points and help others
