Question about Microsoft Xbox 360 Console
Disc tray
Disc tray only opens , after three or four attempts when clicking on to open tray, when clicking for tray to open theres a noise and then reads reading then back to open tray again after four attempts it opens.
  • dabidos Jan 13, 2008
    thankyou by removing the faceplate, problem solved. its nice to know theres people who you can ask.
  • 121 Answers
My console does the same thing just take the faceplate off and when you press the open button grab the disc tray and gently assist your console in pushing out the tray. Taking the faceplate off does not terminate your warranty.
Posted on Jan 13, 2008
CD-RW drive won't open, only beeps when trying to open.
Look for a hole on the front tray a little bigger then a pinhole. Straighten out a paper clip and insert it into the hole to eject the CD.
Mar 20, 2013 | Dell Inspiron 8100 Notebook
DVD tray will not open on my Toshiba DVR620KU
Googled this for two days with no success! Finally, out of despiration I took the screwdriver to the top cover. (four screws in the back, and two screws on each side) Lifted up the rear section of the cover which the released the front for removal. The input pc board is right on top of the dvd tray so little could be seen, so I removed the screws and clips holding the pc board. Make sure that you you disconnect the power before doing this however. Once you have removed the three screws, (two of which have attached grounding clips) you will need to disconnect the HDMI cable which plugs into the back of the board if you had not already done so. Now carefully plug the unit back into ac power, and while holding the board in your hand careful not to allow it to touch anything,press the open button on the front of the unit, and as you move the board slightly while pressing the button, the tray mechanism will start to try to release. Press the button several times till the tray opens completely and stops. Now comes the tricky part: Unplug the AC power plug while the tray remains open. (Otherwise the tray may close again and you'll have to go through the wiggle routine again to get it to open) Once it is open, remove the DVD Disk if there is one in there. OK, so now if you have followed these instructions so far the tray is open and empty, and there is no power to the unit, you can begin reassembly. Put the three screws and two clips back into the PC board loosely at first till you have all three started, then proceed to tighten each one. Replug the cable into the back of the PC board and then replace the top cover and the screws following the same procedure. Plug the unit back into the AC receptacle, and turn the unit on, then press the open/close button, and the tray should open and close as normal. I think what caused the problem to begin with is that I had left a DVD disc in the player for an extended period of time in the start play mode, and it either jumbled the programming or damaged the disc. I have not tried to put the original disk back in the unit to find out! I want to use it for awhile first!
Jul 10, 2012 | Toshiba DVR620 DVD Recorder/VCR
The DVD Player won't Open/Close and there is a DVD inside. How do I force it open?
The DVD player jammed, that is why it is not opening.
To get it to open and close, you will have to unplug the player, then unscrew the screws around it. Take off the cover then you will have access to the disc tray. Then you can plug the player and press open, it will attempt to open but stop, then you can try to apply a little force in pushing the disc tray towards the open direction, it will sit properly and open up.
You can as well unscrew the disc tray and remove your disc, then you press the open button and sit the disc tray properly it will open freely and easily after then.
Take care and good luck
Oct 30, 2010 | Mitsubishi DD-4020 DVD Player
Xbox 360 Console: i will put in a game or a movie and the xbox 360 w...
This is the Open Tray error which basically means that the laser is messed up or your disc is gone. Solution one: Make sure that the disc is clean. Two: Try other discs if it doesnt work choose 3,4 or 5. Three: Buy a new console (Recommended) Four: Send off to microsoft and they will charge you (EXTREMELY NOT RECOMMENDED) Five: Open up and replace laser (NOT RECOMMENDED)
May 17, 2010 | Microsoft Xbox 360 Console
It wont read my disc it sits there and doesnt attempt to read any disc it says open tray how can i fix this?
Ahhhhhh This is a fun one! Ok here is the first thing you should do. Put a disk in the tray and keep in mind the position it is facing. Close the tray and wait for your system to say open tray now open the tray and examine the disc. Let me know if it is in the same position and we'll go from there!
Mar 14, 2010 | Microsoft Xbox 360 Console
Reads the games but only says close tray and open tray
It sounds like you will need a drvie replacement or motor. Sometimes the magnetic disc on the motor comes loose and it sticks to the top of the dvd drive cover and causes it to not function. We can fix this for you if your interested email us.
Jan 11, 2009 | Microsoft Xbox 360 Console
DVD tray will not open.
The disc is dislodged and jamming the drawer. You have to remove the cover, about three, maybe four screws, and then take the disc out to resolve the problem.
Jun 15, 2008 | Zenith XBV442 DVD Player/VCR
Disc tray stuck closed
Is it making the noise like it will open then getting stuck? If so, this can be tricky! It happens with me sometimes. Press the open button and as it goes to try and open push the disc tray in slightly and up and it should pop open, it does with me anyway.
Oct 22, 2007 | Microsoft Xbox 360 Console
Player won't function
The Lazer is dirty open it take a ear bud then apply alcohol to bud wipe Lazer gently normally you can use nail polish remover to clean
Mar 03, 2017 | Sony DVP-NC655P Multi-disc DVD Player
Microsoft Xbox 360 Console Logo
330 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
