Question about LG RD-JT91 Multimedia Projector
Reset the bulb
I need to change the lamp but I need to reset the bulb counter.
  • 2 more comments
  • GABYD Feb 19, 2008
    Reset the bulb TIME OF LG DR JT91
  • hirkania Apr 28, 2008
    Projetor has not any Exit button.Where is it?
  • Anonymous Jun 16, 2008
    i need to resent the new bulb to count hours
  • nomaro Dec 18, 2008
    There's no news for this problem?? I have the same :/
I have the service manual.In this manual I found how to reset the bulb, but I´ll need a special remote control from LG.I´m looking for how to reset it without the remote control.
Posted on May 02, 2008
  • 682 Answers
1-press the exit button on the projector for 3 second to display the total used lamp time.2-press menu button on the projector during the lamp hour message- an adjustement message will be appear press right or left arrow to reset timer to zero.if success osd change to(lamp hour reset ok!)
Posted on Mar 14, 2008
  • Anonymous Apr 28, 2008
    i will search for service manual and tell you the solution when i find it.
6ya staff
SOURCE:
How to reset lg 501b projector lamp life after replacement of new lamp
You'll need to go into your system setup screen on the projector and reset the lamp counter. It doesn't know when a bulb is changed, so it is a manual process.
Jan 19, 2014 | LG Refurbished Electronics BX501B...
Cannot reset lamp counter on benq mp620 projector, projector bulb has been replaced but lamp counter warning is displayed on startup and requests buld change and reset of counter. So I'm stuck in a...
Hi, I don't know if this is to late but oh well, hold down the exit button on the projector panel for 5 secs, and then press auto on the same panel after, this should reset the hours back to a lovely zero
May 26, 2011 | BenQ MP620p DLP Projector
Instructions on changing bulb
Turn off the projector, unplug the AC power cord, let it cool for 45 minutes.
remove the screw that holds the lamp cover on.
remove the 2 screws that hold the lamp in. lift the lamp out by the handle.
replace with new lamp and do the reverse.
press the menu button.
go to setting menu, then to lamp counter, press select button, select reset, select YES. then YES aqain.
Apr 06, 2011 | Sanyo PLC-XT25 LCD Projector
Replaced bulb but still getting "lamp will fail soon replace" warning
When you replace the lamp, you need to reset the lamp counter as well. The procedure for this should be in the owner's manual. This counter is a guide only. Lamps have an expected lifetime and the message indicates that the lamp is nearing that lifetime. Once reset, the counter will again trigger the message once this new lamp reaches that usage time.
Dan
May 06, 2010 | Optoma H30 Multimedia Projector
How do I change the light bulb in the Sanyo pro traX multiverse projector
unscrew the lamp door on the bottom of the projector, unscrew the lamp, remove the lamp, replace with new lamp, screw in, replace door, turn on, and reset lamp counter (menu-settings-lamp counter reset-yes)..
Nov 03, 2009 | Sanyo PLC XU30 Multimedia Projector
I changed the bulb in the m50wh72s RCA DLP tv. Before I changed the bulb I had sound. Now I have no sound or picture. Any ideas? Thanks
Check that when you turn on the TV the Lamp is striking (turning on).
My thoughts are that you will have to reset the lamp hours counter to make it work, as the TV does not know that you have replaced the lamp. To do this, check the leaflet that comes with the lamp - it should explain how to reset the counter for the lamp hours.
Mar 14, 2009 | RCA Televison & Video
Bulb Replacement
the bulb hot indication has nothing to do with the lamp counter.u would have reset the counter as suggetsed by the manufacturer,
this problem is because of the following:
1) wrong bulb
2) cooling fans not working adequately
3) defective ballast
check the above for a solution
Jan 08, 2009 | Toshiba Replacement Projector Bulb...
Lamp error
keep an owner manuel, can download one online, but you need to replace the bulb, then reset the counter. to reset the counter press (-) volume on the tv then while holing that down press the pip button on the remote that will reset the counter
Jul 01, 2008 | Panasonic PT-50LC14 50" Rear Projection...
LP 530 Lamp does not power on
Did you cancell the bulb fault status in the main menu ie bulb hours when you changed your bulbs if not try this turn unit on and see if it works it may do.
To reset the lamp hours counter press and hold down the Volume minus button - , then press the source button whilst still holding down the volume button for 5 seconds .
If this works you can then verify that the lamp counter was reset by viewing the counter in the status window in the OSM
hope this helps... Regards Vortash
Feb 27, 2008 | InFocus LP 530 Multimedia Projector
LG RD-JT91 Multimedia Projector Logo
914 people viewed this question
Top LG Office Equipment & Supplies Experts
jasbo
jasbo
scj103
Ekse
Are you a LG Office Equipment and Supply Expert? Answer questions, earn points and help others
