Expert
- Posted on Nov 21, 2009
Re: Carrier heatpump model 25hba324a300 unit will not...
May be cycling on high pressure switch. is your filter clean? also that is a 13 SEER unit was the indoor unit replaced at the same time? if not it may not be compatible causing higher than rated pressures. if the ac is working then i would rule out it being a low pressure problem
