Question about Belling 24 in. IDW603 Built-in Dishwasher
Belling IDW604 Hi, I have an error code E4 showing on this machine any ideas on how to fix it?? it seems the pump is wanting to start but then does not I cant see a block in the tubes and I want clean dishes!! Any ideas would be gratefully recieved Rebecca
  • rebeccag1973 Jan 26, 2008
    for what its worth I got my machine going again by using one of those drain cleaner products you can buy for sinks, its seems the outpipe was blocked beyond where I could see. Seems to have fixed it for the min!!
  • lisryan Feb 02, 2008
    I have a belling idw 603 the timer control got soaked and has damaged the circuit board is a briton product, i need to locate a supplier please.
    on line or in the uk or ireland.
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 6 Answers
I found the solution myself. On the bottom plate, there is a float and a microswitch, when the water leaks onto the bottom plate it raises the float and activates the microswith which shuts down the machine and shows E4 on display. To get rid of the fault, you have to tilt the machine and drain the water from the bottom plate. Also make sure that there is no leak in the internal piping, if there is, the fault will come back as soon as the recess in the bottom panel fills with water.
Posted on Apr 05, 2010
I had the same problem and had to call out the Service guy under the guarantee, he says the problem is caused by a small switch which is activated when the water does not drain away properly. He said my machine had not been fitted properly and was not level. I've called the kitchen company who fitted it to get it re-fitted. He said as soon as the machine was level the switch would re-set. I assume then if you could remove the machine yourself and turn it on it's side the switch would re-set, but I can't do that
Posted on Jan 22, 2008
E4 is displayed on my belling idw604 dishwasher and it won't operate
unplug machine. remove right hand side panel. check if water has collected in the bottom tray, if so soak up with cloth or kitchen roll until all water has been removed. switch on power and machine should have reser
Feb 07, 2011 | Belling Dishwashers
Belling dishwasher IDW604 error code E4 on control panel
I found the solution myself. Underneath the machine, there is a plate. On the plate, there is a float and a microswitch, when the water leaks onto the bottom plate it raises the float and activates the microswith which shuts down the machine and shows E4 on display. To get rid of the fault, you have to pull out the dishwasher, then tilt it, and drain the water from the bottom plate. Also make sure that there is no leak in the internal piping, if there is, the fault will come back as soon as the recess in the bottom panel fills with water.Hope it helps.
Feb 25, 2010 | Dishwashers
Belling IDW604
Jan 20, 2010 | Belling 24 in. IDW603 Built-in Dishwasher
Error code e4 flashes on belling dishwasher idw604 , washer is empty cant get any programs to work
Dec 27, 2009 | Dishwashers
Idw604 error code e4
had same problem. Tilt dishwasher to the left and drain all the water (it will come out on the side). That's E4 solved. Now turn it on, E4 should not light up. If it does, turn it on and as soon as u do this, close the door. This won't activate the Trip Switch but will automatically turn the pump on. Good luck!
Aug 02, 2009 | Belling 24 in. IDW603 Built-in Dishwasher
BELLING IDW604
i have just fixed my e4 code problem
take off salt cover and remove all water with tea towel or dish cloth you must make sure all water is out switch off at wall then back on if still e4 reapeat getting water out my washer is cleaning as i type
Dec 01, 2007 | Belling 24 in. IDW603 Built-in Dishwasher
Belling 24 in. IDW603 Built-in Dishwasher Logo
1,154 people viewed this question
Top Belling Dishwashers Experts
Kamil Owsianiecki
Level 1 Expert
Oloyede Monsuru
Are you a Belling Dishwasher Expert? Answer questions, earn points and help others
