Question about iRiver PMC-120 Digital Media Player
Pulling music file from pmc120 to computer
I am trying to move music from pmc120 back to my computer. When I try to synch it, I get a message saying there are no files on the device. Any ideas?
  • kenmoresp Jan 12, 2008
    If you can help, please email to [email protected]
  • kenmoresp Feb 10, 2008
    I already did this. Was hoping to find an easier method. Thanks anyhow.
  • 594 Answers
Look at it via explorer in windows, (my computer, K drive or whatever the iriver comes up as) there will be some folders in it and the music should be in there.
Posted on Feb 09, 2008
6ya staff
SOURCE:
Can't create new folder on memory stick
Sometimes these things get confused. try moving everything to a folder on your machine then, use the SanDisk tool to format the flash drive and move everything back.
Sep 08, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
How do I delete files?
The files on your music menu are connected to the folders on your computer. You can't delete the files from your music menu. You have to delete them (or move them) from the folder you took them from.
I suggest that you create a special folder on your computer for only the files you wish to put in coby media manager so that when you get a message like you mentioned you can get the files off your list by moving them back to your normal music folder.
I hope this helps!
_______________________
(^_^)*
Mar 31, 2009 | Coby MP-610 MP3 Player
Will i lose all my synched ipod music if dad reconfigures comp??
If you try to sync with Dad's PC via iTunes you will lose your music. However take a look at XPlay 3 from mediafour.com; that will allow you to recover music from your iPod onto a PC.
If you need to do this on a Mac try Senuti.
Jeff Underwood podserve.co.uk
Mar 01, 2009 | Apple iPod nano
Synch problem
are you using the same windows account / itunes as your wife? if so her ipod may be primary...if you & wife have different windows accounts....you can bring up itunes set up your very own (you will be able to add/delete all the songs you want) hope this works out for you
Oct 30, 2008 | Apple iPod nano 8 GB Pink (3rd Generation)...
Message says player error - music is not available?
Your VX8300 can only play .wma files .. so if there's any .mp3 on there it's going to say that. Also, if you recently put on new files try taking them off then trying the card again .. .if that works then one of your new files are corrupt/unreadable
Another thing to try: goto: Get it now .. music n tones....my music ...songs ...options...reinitialize library database. ( Be warned, you may lose some files this way so make sure everything is backed up on your PC)
Nov 30, 2007 | LG VX8300 Cellular Phone
Not synching correctly with itunes music folder
I know another way you could try formatting which may fix this problem. Restoreing just restores all the setting to your iPod yes it shoudl format as well but it may not due to an error or something.
To do try it another way follow these steps, first click on "Start" - "My Computer" look for you iPod when it's connect usually called "Removable Disk" once you've found it "Right-click" on it then click on "Format", once format is complete disconnect, then connect it again then run "Update" for your iPod and for iTunes, once you've done that have another attempt.
Good luck. Hope my solution was helpful in some way. Further problems leave a comment and i will get back to you.
Nov 11, 2007 | Apple iPod nano
Not playing music
No Music Files Problem solved
Plug the MP3 player to PC
In Windows XP open Windows Explorer and navigate to one of the music files
Try to play the file in Windows
If it fails, unplug player and once the player switches off carry out a reset
Reconnect player to PC and repeat the process described above
You may need to repeat this several times until the music file plays in Windows.
After this format the player using Windows XP
Select the removable hard drive, right click and select format
Choose Fat32, enter a volume label (for example GMP33005) and select quick format
If formatting fails try several times
Once format is succesfull reload your music files using the software that came with the player
Be careful not to exceed 2.5 or 2.6 GB (leave some free space as this might be needed for the player to work)
The player should now play the music files correctly
Sep 22, 2007 | Audio Players & Recorders
Sansa MP3 M240 No volume when playing songs, says to synch
Where did you download the songs? Napster?Rhapsody? Any online music stores? Try synchronizing them using their software. If you have ripped songs from a cd you may want to rip them again and before ripping them check this option on your windows media player software. Tools > Options then under RIP MUSIC remove the check mark that say's Copy Protect Music or choose the file format as MP3. Then format the device using the windows media player software(for version 10 = click on the sync tab then choose the pencil like icon on the far right, for version 11 = right click on the sync tab choose the player and choose format) use after doing that rerip the songs using the windows media player software.
Jul 14, 2007 | SanDisk Sansa m240 MP3 Player
Lexar problem
You need to change your USB Port... try the back of your computer. Or you need a firmware update.
Dec 10, 2006 | Lexar LDP-400 MP3 Player
Synching from computer not working!
update the firmware from creatives website.
Oct 29, 2006 | Creative Labs ZEN SLEEK MP3 Player
Open Questions:
pmc 120 when i set up a sync list on media player and start to sync it to the pmc, it works sometimes, other times it aborts. it gives me the message "you can now disconnect iriver Portable media centre" when i try to do it again it tell me Windows Media Player encountered a problem while synchronizing the file to the device. For additional assistance, click Web Help. when i go to th web help it explains the problem as You've encountered error message C00D1236 while using Windows Media Player. The following information might help you troubleshoot the issue. Cannot sync the file Windows Media Player encountered a problem while synchronizing the file to the portable device. Because this error can occur for a variety of reasons, there is no single solution. To resolve the problem, try disconnecting and resetting the device. See your device owner's manual for specific instructions on performing this procedure. In some cases, this error can occur if you try to sync a hidden file to a device. To resolve this problem, either remove the file from the sync list or change the file's properties so that the file is not hidden. Also the error details are Technical Details This error might have been triggered by an error in another program or component of Windows. The following information describes the original error. Original Error Code Original Error Message C00D1179Windows Media Player does not detect a portable device. Connect your portable device, and then try again. So im not sure why it keeps aborting. if you can tell me your views on this please do. Other information that may be useful i tried formatting the unit : 1. Through windows media player 2. through explorer the pmc is supposed to be used with windows media player 10. i had wmp 11 originally and it didnt really work too well. i rolled back to 10 and it worked better but still not consistantly. i tried installing wmp11 again and now the Pmc120 will abort after about 3 songs of an album i would have setup to sync. thanks for your help. Gavan Doran. Ireland.
Oct 16, 2007 | iRiver PMC-120 Digital Media Player
iRiver PMC-120 Digital Media Player Logo
66 people viewed this question
Top iRiver Audio Players & Recorders Experts
Steven Wander
Steven Wander
Ekse
Peter Dragonetti
Are you an iRiver Audio Player and Recorder Expert? Answer questions, earn points and help others
