SOURCE: GE Harmony Profile Dryer DPGT750EC1PL not heating & blower not working
Check that the dryer belt is not lose or out of place.
SOURCE: GE Harmony electric dryer model DPGT750EC1PL- very
Check the following to address this issue.
Note: Normal drying time for a dryer
is about 45 minutes (some may take up to an hour).
1. Venting
Make sure the dryer vent hose, as well as the rest of the vent duct,
is not clogged.
Unless regular maintenance is performed, chances are there is a lot
of lint accumulated inside the dryer. This might affect the drying
time and could be a fire hazard. Make sure to have your dryer
cleaned regularly. Because this might involve taking most of the
dryer apart, it is recommended to have a qualified appliance
repairman perform this task.
2. Thermostat
There are a couple of cycling thermostats inside the dryer. If one
of them breaks down, it might affect the dryer's performance.
Replace the defective thermostat.
3. Heating element
A heating element might only be partially burned out, in which case
it would still work but will take longer time to dry the clothes.
Replace the element if found defective.
SOURCE: ge profile harmony electric dryer doesn't always heat.
Remove back of dryer and take out the elament shield and replace element don't over strech it start at one side and work it around thank you for useing fixya rate me
SOURCE: DescrI have a GE profile harmony electric dryer
you should not have heat when motor stops there is a switch in the motor to shut the element off....yours is not working(you could burn your house)replace the motor.
PLEASE DO NOT TRY IT AGAIN...can't be lucky all the time
SOURCE: GE profile harmony dryer has power, drum turns,
check out the ignition spark ignitor
that makes the burner to heat up
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
