Question about BenQ FP731 17" LCD Monitor
Monitor blank hi1 I'm ykeong fr malaysia.I'm having the same problem.All the c5707 is ok I also measureed PF751 fuse n is about 90 ohm.Is this reading ok cos i thought all fuses should have very low ohm
    Champion:
  • 220 Answers
It's open if it shows 90ohms.
Also remove all 4 2Sc5707 transistors and check.
Also invertor transformer is dry solder ,Resolder all pins of transformers.
Samir
Posted on Feb 27, 2008
6ya staff
SOURCE:
Dryer runs but does not heat.
Hi.
Check the thermal fuse. The fuse can be tested reading impedance.You can replace the fuse straight away, or you can first test it using a multimeter set on Ohms. If the multimeter reads Ohms infinity when you touch the fuse contacts with the probes, then the fuse is gone. A good fuse will read zero or low impedance.
If the fuse is OK, then you can have a defective thermostat.
In the same way you test the thermostats, thermistors or cutoff located in the heating group, near to fan and element. If they are OK, then they will be conductive at room temperature and will read zero Ohms. If they are bad they read open (infinity). You need to disconnect the part's contact to test properly.
The rest depends if the dryer is electric or gas.
On electric dryers you test the heating element. The heating element is tested in the same way. Set multimeter on impedance, disconnect element, and touch contacts with multimeter probes. If it reads open, then element is gone. A good element reading depends on the specific model. Most washer-dryers, including Whirlpool and Maytag read between 10 and 20 Ohms.
With gas appliances you need to test the ignitor, then coils and then the flame sensor. The ignitor is the most common cause for the problem. Heating coils problems are also common. The flame sensor does not fail very often.
Regards.
Ginko
Sep 06, 2011 | GE Dryers
It will read my ext hard drive, reads all the folders/menu's etc, but does not register the files "(null)", yet my other ext hard drive works fine.
try using file option instead of movie or music cos some time when you use movie or music it will only look for movie or music files also what formatt are your movies in cos it has a prob reading certain files and codecs like mp4
Nov 01, 2010 | AGPtek NBOX RM RMVB MP4 VOB MPG 3GP AVI...
Why the cos of 90 is -0.44... ?? and the tan sin its'nt correct in the calculator what can i do ?
The trigonometric function evaluations depend on the angle unit you are using: degree, radian, grad
While cos(90 deg)= 0,
cos(90 rad )=cos(90* 180/pi degrees)= -.448073616
ALWAYS CHECK UNITS before using trigonometric functions or their inverse functions.
May 13, 2010 | Casio FX-7400G Plus Calculator
Power Board Dell E151FPp
Did you check the fuse PF751, it should be less than 1 Ohm?
Also look for cold solder joints.
http://s807.photobucket.com/home/budm/allalbums
Mar 23, 2010 | Dell E151FPp 15" TFT LCD Flat Panel...
Dell monitor e17s fbp.. wont turn on
Flashing power LED light means you may have shorted (Emitter to Collector) out transistors (c5707) or bad fuse (fuse has high resistance) PF751. Those are what you need to check. see pictures here: http://s807.photobucket.com/albums/yy352/budm/Dell%20E173FPb/
http://s807.photobucket.com/albums/yy352/budm/Dell%20E15x%2017x%20series%20PWR%20INVERTER%20BD/
Post back what what you find so we can guide you further.
Feb 27, 2010 | Dell E173FP 17" LCD Monitor
Microwave comes on but does not heat
This means the magnetron is either bad, is not receiving the high voltage it needs (failed diode) and/or the fuse is blown.
You can trouble shoot this yourself with the help of a cheap digital multimeter and a reading of the Chinglish instructions that come with it.
Be advised though; if the magnetron and the diode are OK you can encounter ~ 700 volts on a charged capacitor so let the unit rest unplugged overnight if you intend to poke around in it.
Oct 04, 2009 | Whirlpool MH1170XS Microwave Oven
BenQ FP731 17" LCD Monitor Problem
Connect it to another device, if you get the same result the backlight is bad! These can be replaced, but can be costly!
Nov 14, 2007 | BenQ FP731 17" LCD Monitor
BenQ FP731 Screen briefly displays then turns off
hi. i had the same problem and fixed it. the problem are the 4 transistors (C5707) one of more are shorted (Q739,Q740 and Q759, Q760). Also the fuse PF751 (3a) has to be replaced in most cases. In my case i replaced the fuse and 1 transistor (C5707)
Dec 06, 2006 | BenQ FP731 17" LCD Monitor
BenQ FP731 17" LCD Monitor Logo
123 people viewed this question
Top BenQ Computers & Internet Experts
Ekse
Tommmix
Level 1 Expert
Joaquim Martins
Are you a BenQ Computer and Internet Expert? Answer questions, earn points and help others
