Question about Philips Televison & Video
Im trying to hook up my Xbox 360 to a Philips 32" HD TV using the Xbox HD AV cable. On this model it has the normal three colours red white and yellow at the side which i was using with my old non HD cable. (when you choose the ext' on the TV there is an ext' for the side and then a few more for ext' on the back of the TV). I have hooked up the new blue green and red part of the HD AV cable but then below that i haven't got a space for the red and white audio part of the cable, there is only a lil black hole which states its for the audio L/R. I have tried putting the red and white cable back into the side and also in another spot they can go on the bottom of the TV but as they seem to be different ext' on the TV the sound doesn't work with the blue green and red which is set at ext' 3 ( if i select ext' 3 i get the picture but no sound, if i select ext' side i get sound no picture!) Can some one please help me as im at my witts end!! ????
  • Ubora Mar 17, 2008
    I received a used Philips TV from a five-star hotel renovation in San Diego.
    I have trying to hook up the cable connection to the t.v., but there does not seem to be any outlet directly on the t.v. where I can plug in the cable cords. I have gone to Radio Shack & our local cable co. and they suggest I contact the manufacturer. The model No. is pc0127C121 and the serial no. is 62544863. Please help me get this great t.v. hooked up with cable.
    Thanks.
    [email protected]
6ya staff
SOURCE:
Anonymous
  • 19 Answers
SOURCE: No Sounds when connect XBOX 360 to HD port
you need to run the white & the red to the aud. input
Posted on Sep 16, 2007
doktah
SOURCE: samsung lcd ln46a550pf3 no sound from hdtv reciever
ok your tv does not come with the very best sound, you have to get a receiver 7.1 or you can use the optical wire , that's if the system you are using has that option.
Posted on Jun 28, 2008
Benimur
Louie Role
  • 6966 Answers
SOURCE: setting up tv sound to come thru stereo speakers
Offhand, your Philips 32PFL7422/98 do not have regular Audio Output RCA jacks (white and red), sorry. However, right before the antenna connector is an S/PDIF output connector. This should allow transfer of digital audio signals from the Philips 32PFL7422/98 to a S/PDIF capable receiver or amplifier. If you would look at the rear of your stereo and determine if it has such an input, then it would be a matter of getting the right cable/connector.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Posted on Nov 16, 2008
rainsocket
  • 32 Answers
SOURCE: Proscan 26LB30Q Vs PS2 = HELP
The red white and yellow cables are composite connections. The red/green/blue connections are component connections.
The playstation's composite connections consist of two audio connections- red & white, and a composite yellow video connection. The TV's white connection is the audio, and the red/green/blue are component video. You need an adapter that will connect the one yellow(composite video) to the three red/green/blue (component video) connections
Posted on Apr 02, 2009
Anonymous
SOURCE: lcd tv hookup
Ive got 3 samsung tv's (lcd, plasma, DLP) and I use HDMI cables on all of them. Its the only way to get the full potential out of the tv. When you use the red/white/yellow RCA cables the signal is anolog aka "old technology". Component cables are good but HDMI is the best. HDMI is a digital signal and thats what all the components that go with the tv should be run on. If your dvd player does not have an HDMI output I would suggest getting one that has that output. As for the cable box most require you to upgrade to digital cable in order to get one with an HDMI output. If you dont want to spend the money on new components and run what you have now the picture will stay mediocre at best. Good luck hope this helped
Posted on May 11, 2009
I have a daenyx lcd tv, model DN-15, input 12VDC-4A and am trying to hook it up to an xbox 360 console.
If you are using the Red/Yellow/White cable, that's composite cable, but if you're using the one that's Red/Yellow/White/Blue/Green, that's called component. So basically, you set your TV's input to the corresponding color match. 5 colors: Component, 3 colors: Composite.
Sep 13, 2014 | Video Game Consoles & Games
Hi, I have a 32 inch sony bravia and im trying to hook it up to kinect. I can either have normal picture with colour but no sound (using an hdmi cable) or black and white with sound if i hook it up with...
This is a very odd situation you are having, because what is unique about HDMI is that it transfers video AND audio. Make sure there isn't more than one HDMI port on your TV, that should help you out.
Jan 13, 2011 | Microsoft Kinect Sensor for XBOX 360
My Xbox elite is just over a year old. I have no red rings. Problem is that all games played on the box are now in black & white. There is no colour on my tv screen. There is nothing wrong with the...
Check and recheck and triple check the av/hd cables. If you want to help isolate, try hooking up your xbox 360 to another tv and doesn't matter if it is hdtv or standard to test out. That method will give your answer quick to help isolate the problem. If you have hdtv make sure your adapter has the switch set for hdtv and not standard and then go in the xbox 360 dashboard system settings and see if it shows up for display. Good luck!!!
Please rate and comment!!!
Dec 23, 2010 | Microsoft Xbox 360 Elite Console
Hello, i am trying to hook up my xbox 360 to my
Make sure the tv is set to A/V 1 if it has multiple A/V hookups make sure the tv is on and set to the A/V channel you are trying to use. And make sure your cable is set to tv if you have a composite cable. If that does not work try buying a composite cable (thats the yellow red red blue green white cable). If that does not work. There might be something wrong with the xbox or tv.
Jun 26, 2010 | Video Game Consoles & Games
I have a jvc i'art tv. model # av-27f476. i have an xbox 360. how do i hook em up? i have plugged the red, white, yellow cables to the corresponding colored jacks on the front of my tv. i turn my xbox 360...
on the xbox i think the hd works with all 6 cables connected so you will need to switch it back to standard definition. if its still not working try it via scart m8
Mar 06, 2010 | Video Game Consoles & Games
How to join xbox 360 to new tv
The AV cable you are using is an older model known as "Composite". You need a newer AV cable known as "Component". These should be available at a local video game store, such as Gamestop.
Dec 27, 2009 | Video Game Consoles & Games
Which wires doi use to connect up my xbox with my
In order to connect your Laptop with Xbox 360, you will have to use the ethernet cable that came along with the Xbox 360,
For connecting the Xbox 360 to TV you would be having a HD AV cable if you have a Xbox 360 Pro model, you would have to insert one part of this cable with 3 colored wires red,blue and green to your composite video port behind your tv with similar color coding, and on the Xbox 360 HD AV cable you have an option to choose either TV or HD video output based on your TV make, also this cable has two more wires red and white meant for audio connectivity which would go to audio port behind TV with same color code ports
If you have got a normal AV cable with Xbox 360 then it would be a a wire with one single yellow colored wire for video and two wires Red and White for audio
Nov 23, 2009 | Microsoft Xbox 360 Console
My xbox 360 turns on fine but it won't show on my tv
Im presuming you have check all the cables settings...
and still just audio , It requires that the G.P.U. be Preheated
and seated ( clamp down) and then Burn in A.K.A. x clamp mod.
the dead video problem needs a little more then the regular
x clamp mod , so make sure who ever dose it has a good
success rate .
Jun 22, 2009 | Microsoft Xbox 360 Console
No picture or sound on the tv
where you put the cables for the sound and picture if you look on the end where you plug it into the xbox 360 you will see a little switch it has HD and TV on it depending on what your tv supports (HD ready TV) (normal TV) switch that switch to what TV you have (e.g. HD TV, switch the switch to HD) if that doesnt work then try checking that you have all the cables in the right ports if you have pluged the HD cables into a normal TV then this is not going to work, check cables and check the switch!
Jun 05, 2008 | Microsoft Xbox 360 Console
WIRE ELIMNATION
For the TV:
There are a few possibilities.
1)You can connect a red and white AV cable (or the red and white portion of a red, white and yellow cable) from the TV Audio OUTPUT to the "Audio In/TV" portion of the HTS (NOTE: Many TV's do not have an Audio OUTPUT).
2)You can connect a red and white AV cable (or the red and white portion of a red, white and yellow cable) from the Audio OUTPUT of your cable or satellite box to the "Audio In/TV" portion of the HTS.
Note: Using a red and white cable may not give you sound on all 5 speakers.
3)Get a digital audio or SPDIF cable and run it from the TV, Cable or Satellite Box's Digital Audio OUT to the "DIGITAL IN" of the HTS. This will give you the best sound quality. When using this (or any of the other) type of connection, press SURR until you get sound from all 5 speakers.
For the Xbox, try hooking a red/white audio cable from the Xbox into the Audio IN/AUX on the back of the HTS, and then switching the source on the home theater to AUX.
Also, the manual can be obtained from www.usasupport.philips.com
-Tha Mp3 Doctor
Jan 06, 2008 | Philips HTS-6500/37 System
Televison & Video Logo
567 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
