Question about Sony Handycam CCD-TRV37 Camcorder
Continually ejects i have a sony ccd-trv37 8mm that just ejects over and over, whether there is a tape in it or not.  there is no error code in the display.  any ideas, or am i better off just taking it in.  thanks in advance
  • MANCHU Feb 20, 2008
  • bugbug67 Mar 09, 2008
    I am having the same problem. Did replacing the battery really work?
Posted on Feb 23, 2008
  • 64 Answers
The clip that catches may be out of alignment, best to have a repair shop take a quick look.
Posted on Jan 12, 2008
Sony CCD FX500E ejects tapes
Mechanical fault. Contact any service technician; or the authorized service centre for Sony. Electro help
Nov 29, 2014 | Sony Video Cameras
Tape will not run
The "will not run problem" was solved by replacing the CR-2025 Lithium battery. The eject symbol continues to appear sometimes and I can remove it and continue operating the camera by turning the power supply "Off then On" again. Camera is now running a recorded cassette but quality of picture is low.
Jan 14, 2010 | Sony Handycam CCD-TRV68 Camcorder
Sony ccd-trv43 showing c:32:00?
Error Code = C:32:00 - Tape will not eject... I found that the Camcorder ate the tape and the tape was rapped all up inside the Camcorder, preventing the tape from ejecting. I took the Camcorder entirely apart and removed the tape manually and re-assembled the Camcorder. When finished there were no extra parts or screws and my Camcorder works perfectly once again. However, I DO NOT RECOMMEND this procedure if you are not confidant that you can disassemble and re-assemble your Camcorder.
Dec 05, 2009 | Sony Handycam CCD-TR416 Camcorder
Error Code C:31:00 in a Sony CCD-TRV75 Handycam Camcorder
    This error shows that the problem is in mechanical section of the tape loading path. Please contact an expert for mechanical adjustment
 Thanks for using fixya.
May 21, 2009 | Sony Handycam CCD-TRV75 Camcorder
Tape won't eject from CCD-TRV608
There is a little plastic piece on the tape and it is getting stuck, you have to maually move this piece, witha paper clip or something else. it might break the piece off, but that is the only way I know to get it out.
Dec 18, 2008 | Sony Handycam CCD-TRV608 Camcorder
Tape will not eject
If you remove the power while the basket is halfway up, you should be able to remove the door. Then look to see if the reels are turning when you try to elect the tape. The error code you are getting indicates the reels are not turning for some reason. You can ssist the reels turning as the tape is ejected if you have a small plastic pick or a toothpick into the reels to assist the reels turning and tehn you may be able to remove the tape.
You need your CAM into Sony or service center Sony to repair it the error code is indicated the LS chassis assembly faulty or loading motor faulty it require a lot of work mechanis and electronics it may not worth to repair it. It would cost between $150 to $250 in AUS
Oct 07, 2008 | Sony Handycam CCD-TRV308 Camcorder
Sony Handycam CCD-TRV37 Error code C:32:20
1. I removed the battery. 2. With the power switch On position and holding the tape ejected I inserted the battery back on & it ejected the stuck tape.
Jul 24, 2008 | Sony Handycam CCD-TRV37 Camcorder
Error code C:32:20
My best solution, is to pull all power sources form the camera for 24 hours. If this does not work, then take the small screws surrounding the Tape housing, in order to try and get the tape out. Best of luck dude ;)
Feb 05, 2008 | Sony Handycam CCD-TRV37 Camcorder
Sony Handycam CCD-TRV37 Camcorder Logo
192 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
