Troubleshooting basic troubleshooting in networking and Internet
  • 207 Answers
Can you specify your problem about this??
Posted on Jan 14, 2008
How to use cmd on window 8
It depends on what you want to do, cmd is just a command line interface, I use it for basic network troubleshooting, a couple of commands are ipconfig ( find out the internet addess of the computer) ping and netstat. So the question is what do you want to do with the command line interface
Sep 06, 2017 | Computers & Internet
Network Troubleshooting in windows
<p>Some Time Network trouble shooter faced some problem in but they can't solve out where is the exact problem. Yes it create critical situation some time to find out where the problem is. In windows based OS have a feature to take out problem. Network trouble shooter is the feature where we can recognise the trouble of hardware, software or network. Here I will describe about <span>how to troubleshoot a Windows XP-based home network. Usually it will describe also about a network structure, how to use the Home and Small Office Networking Troubleshooter, and how to troubleshoot basic connectivity, and how to resolve file and printer sharing issues. If you have problems with your home network, follow the steps in this article to help isolate and troubleshoot the configuration of your home network's basic connectivity, and file and printer sharing. First, try to identify and resolve the issue by using the following steps. </SPAN><br> <p><span><span> </SPAN></SPAN>At <span>first you have to know the kind of network structure that using there. If you are not sure, go to the "Home-network structures and their configurations" section. To identify the problem first </SPAN><span>Click starts and then click </SPAN>Help and Support<span>. </SPAN><span><span> </SPAN>After that </SPAN><span>Pick a Help Topic, click Networking and the Web. </SPAN><span><span> </SPAN></SPAN><span>Under Networking and the Web, click Fixing networking or Web problems, and then click Home and Small Office Networking Troubleshooter. </SPAN><span>Answer the questions in the troubleshooter to try to find a solution. </SPAN><span>Before you troubleshoot home networking issues, first determine the network structure you are using. The network structure is the arrangement or mapping of network elements such as links and nodes, and the physical connections between them. There are several common home-network structures.</SPAN><br> <p>If in that Lab the computers are connected to a hub, where only one computer has Internet connection shared by using Internet Connection Sharing<b><span>.</SPAN></B><span> </SPAN><span>In this configuration, the computer that shares the connection generally assigns IP addresses to other computers on the home network. The computer that is sharing the connection will have IP address configured for the adapter that is connected to the home network. Other computers on the network will have addresses in the range 192.168.0.<span>x</SPAN>, where <span>x</SPAN> is a number between 2 and 254.</SPAN><br> <p><span> </SPAN>If t<span>he computers are connected to the Internet</SPAN> through a broadband connection, then<b><span> </SPAN></B><span>this configuration is also known as an edgeless network. In this configuration, the computers on the home network each have an IP address that is provided by the Internet service provider (ISP). The addresses that are used vary, depending on the ISP. </SPAN><span></SPAN><br> <p><span>So Network trouble shooter is very useful and easiest process to identify or troubleshooting a network problem.</SPAN>
on Mar 24, 2011 | Microsoft Windows XP Professional With...
How to Troubleshooting Network
Here you will learn network troubleshooting tips, fix tcp/ip errors, tcp/ip settings, internet connectivity errors, how to fix pc errors, lan connectivity issues, traceroute and ping commands. Whether your operating system is Windows or Linux network problems are likely to arise. Many times the network problems arisee due to improperly configured TCP/IP settings. Following is the basic checklist to identify and troubleshoot the basic networking errors.
1. First of all you should learn what stopped working server or client computer also see if the outage affecting the other computers or only one.
2. If you server stopped working you should inform the users of the server and you should start working on fixing the error.
3. If a single client computer stopped working or disconnected from the network, ask the user of that computer that what recent changes cause the server to stop working such as newly installed software or games, service packs, internet software, new hardware or any other thing.
4. Check the physical network connectivity. The most network problems arise due to the physical layers failure.
5. Check all the network cable connections. You can start at the NIC and check if the green light is blinking then check the hub and see if the computer is getting the link across the cable.
6. Get a cable tester to check the connectivity of the cables.
7. Finally start pinging the network both Windows and Linux have the PING command. You can use ping command in this way start > Run > cmd > type "ping" then IP address of the other computer
on Mar 25, 2010 | Computers & Internet
How do i get internet explorer to load so i can go on facebook
There are different options to diagnose the problem. Either:
* Check your network cable if it properly connected to the ethernet port
* restart your modem/router
* Check internet explorer if there is an available update.
click on this link that I posted so you can have more options to troubleshoot it. How to troubleshoot network connectivity problems in Internet Explorer
Oct 15, 2014 | Microsoft Windows Vista Home Basic for PC
I can't connect to the internet. The error message is that the network adapter isn't working.
In order to troubleshoot any internet connectivity related issue, we can work out with the basics first and if they don't help then we have to perform step by step advanced troubleshooting. You can reach me on the below mentioned details so that I can talk to you and can spell out some commands which may help to get your problem fixed.
+1 (503) 583-2414
Oct 02, 2014 | DMCOM Gateway Sx2855-ur11p Desktop Black...
My dell inspiron 1525 has a built in mobile broadband network and will connect with an outside wifi network but won't connect to the internet. It's saying that my modem test failed and my modem hardware...
Have you tried resetting your Wifi adapter, next time you can't connect, try using the network troubleshooter and it will ask a couple basic questions. Usually by the end of troubleshooter it will reset your wireless adapter.
Aug 24, 2013 | Computers & Internet
My computer doesnt want it connect to internet,, appear the connection icon but when the page try to open , it cant do
Please follow the steps provided below:
Q: Basic Wireless Troubleshooting
The following steps will help determine if the wireless card in the system is functioning properly.
Please go through all the troubleshooting steps. If the wireless card is functioning properly, please check the network configuration. Acer America can not assist with configuring the network.
Before you start:
  • Make sure there is a wireless router or wireless access point.
  • The wireless router/access point is plugged in.
  • Refer to the owners manual to ensure the wireless adapter is on (you can turn the wireless card on and off by pressing a clear button)
  • Contact the internet service provider to make sure ther account is active and the network is connected in a way that supports their configuration.
If the computer was working properly at an earlier time:
If the laptop was working fine, do a System Restore which rolls the system back to the last known working configuration. System Restore is located in System Tools under Accessories. Here is a link to explain the use of this feature:;en-us;306084
To find the wireless network:
1. Click on Start winxpstart%20button.jpg then click on "Control Panel."
xpmenu.jpg 2. In the Control Panel window, click on "Network and Internet Connections."
3. In the "Network and Internet Connections" window, click on "Network Connections."
networkconnect.jpg 4. Once in Network Connections, right-click on the wireless connection then select "View available wireless networks"
5. If the wireless network is a secured network, please refer to the manual of the wireless router to make it unsecured for the purpose of testing the wireless network.
NOTE: Acer does not recommend leaving a wireless network unsecured and is not responsible for data accessed due to unsecured wireless networks.
6. If the wireless network is listed, the wireless adapter is functioning properly. If unable to connect to the wireless router, go through "Before you start" at the beginning of this article.
Mar 05, 2011 | Acer Aspire 5100 Notebook
We hooked up our router to our modem following the instructions and tried to run the network set up and it says 'not connected to the Internet'.. But the lap top says it is connected. It won't let us get...
These types of issues can be tough to troubleshoot. Let's start with the generic basics and you can let me know if we need to get more specific. .
  1. I'm assuming that you have the laptop connected (wired) to the router and the router wired to the modem. When you're troubleshooting, everything should be wired, not wireless.
  2. Make sure that the cables are connected to the right ports! Not trying to insult you here, but I've done this accidentally myself.
  3. Turn off everything except the modem.
  4. Follow the manufacturers instructions to reset the modem. Most of them have a reset button. Make sure the modem indicates Internet link is up before proceeding.
  5. Now turn on the router. Does it connect to the modem? Check the lights. If the modem is connected, but the router is not, then I would suspect a cable issue, or even possibly a defective router. If the router and modem are connecting, go to the next step.
  6. Start up the laptop and try to connect to the Internet via the WIRE. When troubleshooting, it is important that you test wired before trying wireless.
  7. If that works, try wireless. Make sue you're in the same room as the router when you test this out. In other words, make sure you have good signal.
. So those are the basics on how to isolate the problem to a particular piece of equipment. Once you know where the problem is, then we can get to specific troubleshooting techniques. . Let me know how this works out.
Jan 13, 2011 | NetGear WNDR3400 N600 Wireless Dual Band...
I'm using mozilla firefox, and cannot load my farmville on facebook... help me please...
download and install these 2 and after that reastart and try again ..if you still have trouble..look at ..and see if you have any settings that may obstruct the page..
Apr 21, 2010 | Microsoft Internet Explorer 8
Avaya is not communicating with the ecas. what are the troubleshooting steps?
Basic network troubleshooting would be the first step. Can you ping the Ecas server?
Jun 24, 2009 | Veramark Avaya eCAS for IP Office...
Computers & Internet Logo
60 people viewed this question
David Payne
David Payne
