Gaggia Classic Espresso Machine Logo
Posted on Nov 21, 2009
Started up gaggia classic for the 1st time today. followed the instructions in the manual but when switching on the pump, it made ery loud noise and no hot water or steam apeared through the nozzle or filter head. Is it broken? Thank you
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jan 22, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
523
Points
Are you sure you had the right toggles selected? A friend does this all the time. inevitably he has it set for steam, not water pressure.
Anonymous
Level 1:
Problem Solver:
  • Contributor 10 Answers
  • Posted on Dec 15, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
10
Questions
0
Helped
4967
Points
20
You need to let this happen for awhile until the pump "primes" or fills all the way with water. Let the it run with the noise for awhile. Also, let it sit for at least 20 minutes before you start running the pump.
Gagging espresso maker does not pump water
Hi There,
It's either the pump or the solenoid.
When you turn of the coffee switch after there should be a discharge into the water tank - if this happens - the solenoid is blocked but the pump is not.
It is an easy fix.
( This happens when the machine has not been descaled and the solenoid is blocked.)Usually its not the pump.!
Vibration pump Gaggia Saeco Gaggia classic solenoid
Low flow, pump starts normal and within a few second becomes quiete
Hi There,
Try descaling - sounds like the the solenoid is blocked with lime - don't use vinegar! Try that 1st.
If machine is more that 2 years - not regularly descaled or no water filter replaced regularly, it probably the solenoid.
It the machines is 4 years + replacing both would be a good idea. Gaggia classic solenoid Vibration pump Gaggia Rancillio
1helpful
I have a brand new Classic and can't clear an airlock by following the advice in the instruction manual. Is the unit faulty?
Try to clear the airlock by having the steam knob open at the same time as the coffee switch is on.
This allows any air to come out of the group head and the steam arm.
Gaggia Classic First time use and no water comes out.
Me to! Not happy. Have you found any solutions to this? I don't really want to send away my machine that just arrived but also don't want to mess around with something that should work
1helpful
Brand new Gaggia classic, no water coming through the brew head
take out screen and screen holder,and unscrew piece in head,clean with wire and try,i think its your head plugged out.
1helpful
Lost instruction manual for Classic Espresso Machine
You can find the manual of this product on this following link and download the operating manual.Good day!!!
3helpful
Airlock in new machine
I have a similar problem, I think. I get water through the steam thing, but not through the brew head. Not sure what to do either.
Top Gaggia Coffee Makers & Espresso Machines Experts
Sulejman Sulejmani
Sulejman Sulejmani
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
