Question about JVC RX-662V Receiver
All speakers not not sounding at same time; hookup problem...
I think I may have setup the system wrong. I routed speaker wire from peaker to back of rceiver. What am I missing?
5 Suggested Answers
  • 979 Answers
SOURCE: No sound from rear/surround speakers
What source are you using? And, do you have a surround mode selected?...accordianman
Posted on Nov 26, 2007
  • 163 Answers
SOURCE: rear speakers on 7.1 not working
Most likely you have wrong setup- two rear speakers are assigned for zone 2. Press setup on a remote controller go to OPTION SETUP and assign POWER AMP to S.BACK.
Posted on Apr 09, 2009
  • 8546 Answers
SOURCE: i am having problems getting optimum sound out of
Define optimum.
If it tests out in the speaker setup then it's probably just fine. There usually isn't much program material directed to that speaker.
Posted on Mar 19, 2010
  • 3247 Answers
SOURCE: I have the receiver setup
It is possible the system has gone into a 2ch speaker setting.
Check out pages 17 to 20 of your manual for speaker settings.
In case you do not have the manual you can download form this site. Click on download and Scroll down to enter the verification code displayed and start the download.
Hope this helps you to set the sytem up back it used to be. Please rate the solution so that fixya can help you better in future.
Posted on Oct 09, 2010
SOURCE: I have a JVC Receiver that I'm trying to hook a
What does the fm75 ohm coaxial antenna hook up for audio video receiver wire lolook like and where can i get one
Posted on Oct 07, 2012
0 characters
1 Points
How to hook up Panasonic SB PM19 speakers to SA-PM23 reciever
yes you can. these are called "bi wired" speakers which means there's a hook up for the woofer and the tweeter individually. If your amp have just 2 speaker hookups it's no problem to hook the woofer/tweeter wires of each speaker together. If your amp had 4 speaker hookups, you could put the tweeters in 1 and the woofers in the other but it will still work fine with 2 speaker hookups.
Mar 21, 2013 | Panasonic Audio & Video Receivers
We have a denon avr-589 5.1 system. It worked great until my son tried to hookup the wii into it. We now have no sound on the tv and dvd player. He normally plays the wii through the samsung flat screen...
How funny my son just did the same yesterday!
Make sure that the speaker selectors and the input modes are set correctly. He must have hit both buttons at the same time which turned off the speaker outputs and changed the input mode to a setup we were not using.
Jan 09, 2011 | Audio & Video Receivers
I recently purchased a new Denon AVR-391 receiver and am having a problem hooking up my subwoofer. It seems that the Denon has a pre-out RCA looking output and my subwoofer uses conventional speaker wire. ...
Your sub-woofer apparently does not have an amplifier built into it. This type requires you to use your front left and front right speaker output to got through it to your regular speakers. It is called a passive sub-woofer for that reason.
To set it up, Connect your front speakers to the "output" of the sub. It should say "to speakers" on it.
Then connect the Speaker Outputs for the left front and right front on your Denon AVR-391 directly to the Sub. It should say on the back of the Sub "to amplifier".
Here is some theory you should know, if you don't already know it, that will help you get a satisfactory result in setting up this system.
There is a condition on setting up all speakers and subs that not everyone know. It's call "phase alignment". Phase alignment (A Good Thing) refers to all of the speakers in a system moving in the same direction (in and out) at the same instant in time. This gives you much clearer sound and better response from your sub-woofer.
Phase Cancellation (a bad thing) is when some of the speakers are moving out and other moving in during the very same instant in time. It causes problems in sound.
Here is how to handle it:
On the back of the receiver the speaker terminal outputs are colored Red and Black. Black is considered negative and Red is considered positive. On the back of the Sub woofer and on the speakers the same colors apply. MAKE SURE THAT ALL OF THE CONNECTIONS GO BLACK TO BLACK AND RED TO RED WHEN CONNECTING UP THE SPEAKER WIRES.
The system will work either way. But you will have severe bass loss if the woofer wiring is out of phase because of phase cancellation.
Hope this helps,
Best Regards,
"Phase Cancellation"
Jan 05, 2011 | Audio & Video Receivers
Surround Speakers will not work
Perhaps you have the live wire in the wrong connector from the speakers? They should be color coded. I would check that first. And if you have moved, they are most likely in different positions, you'll have to rerun the audio setup for the surround sound. You should have a separate microphone to use for that that plugs in to the system.
Aug 31, 2009 | Onkyo HTR500 Receiver
'Buzzing' is not a good thing; it implies that filtration of the DC used by the output section is not as it should be. Power supplies that are mildly overloaded can cause this or an abnormal current drain from one (or more) channels.
The odd problem with the back speakers does sound like a setup problem rather than a circuit failure.
Oct 31, 2008 | Onkyo TX-DS989 Receiver
Front speakers have no sound now.
Hups, apparently my friend put the speakers into wrong slots. Then i just copied him while trying different speaker setups and it simply never occurred to either of us to check if these were the correct slots :-D
Anyway sorry for these useless posts.
May 05, 2008 | Yamaha HTR-5830 Receiver
No sound from "Front Right" channel
The very FIRST thing to check is to make certain ALL of your speakers have an IMPEDENCE of 8 OHMS. Virtually all speakers of even modest quality will include this specification on a label on the back of the speaker. You CANNOT run more than (2) TWO speakers with 4 OHMs impedence on ANY amplifier (technical discussion too long!) [NOTE: MOST HK equipment have internal overload protection systems to prevent permanent damage. However, you cannot re-set these systems yourself. Your dealer or authorized HK service center must do this.] But, before you take this beast in for service, there is one more "test": check for shorted and/or mis-connected/disconnected speaker cables/wires. Visually inspect connections at the receiver and speakers first. You might find something obvious! If everything looks okay, then disconnect ALL of the speakers; and reconnect and test them one at a time (at relatively low volume.) For example, reconnect the left front speaker, test the system; THEN add the left front, test the system,and so on, ADDING one more speaker each time - FIRST MAKING SURE EACH OF THEM HAS AN IMPEDENCE OF AT LEAST 8 OHMS! IF there is a short (or bad speaker) this will help isolate it. HK is among the best equipment money can buy, and their equipment is pretty much "bullet proof!" Hopefully one of these "fixes" will work for you. GOOD LUCK!
Jul 02, 2007 | Harman Kardon AVR 325 Receiver
"Check Speaker Wire" error on my Yamaha Receiver
found the source of the problem with "Check SP Wires"! to solve it is necessary to check each speaker connected to the device Yamaha on the rear panel (red and black) using the device for determining the number of ohms, which shall not be less than 4 ohms, in large passive speakers experienced in Amfitone AU-027, the result showed that left at 0.45 (7) ohms, and the right-hand column, as such, no.
The successful test ... and good music!
Mar 13, 2007 | Yamaha HTR-5790 Receiver
Onkyo srtx601 receiver
Please add a comment to your previous post next time, it makes it easier to see this post has a relevant history. I had to go check in your profile when I saw the word "still". Shooting in the dark, and saying the obvious(just bear in mind a month ago I was going crazy over a problem that ended up being the blanace knob turned to the right) - could it be that you're not using a digital signal? I'm not sure you can get surround with analog. Make sure all settings are for digital, and that you're using a coaxial/optical cable going from the DVD to your receiver. I hope you'll end up embarassed but happy. Good luck
Jun 17, 2006 | Onkyo TX-SR601 Receiver
Audio & Video Receivers Logo
35 people viewed this question
Top JVC Audio & Video Receivers Experts
Chris Hunt
Are you a JVC Audio and Video Receiver Expert? Answer questions, earn points and help others
