Question about Samsung HC-P4752W 47" Rear Projection HDTV-Ready Television
Samsung HCP4363W I need to enter the service menu on this set in order to adjust the convergence. Can you supply me with this info. thanks
  • 3 Answers
On your remote, press
MUTE 1-8-3 POWER
Posted on Nov 28, 2009
    Problem Solver:
  • 6 Answers
When you find out let me know please
Posted on Jan 26, 2008
Unable to enter convergence menu
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony,Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit wiith instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Another common problem is dull or washed out video.
Your TV2_bing.gif may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find a fix here
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Oct 08, 2009 | Toshiba 42H82 42" Rear Projection...
Technition secret code
To get to the convergence menu pressmute - 1 - 8 - 3 - power
Apr 09, 2009 | Samsung HC-P4363W 43 in. TV/DVD Combo
Samsung HDTV 1080I-Model#HCP4363W-Convergence Problem
  • Screen Looks 3-D
  • Colors wont align
Problem #2
Your TV may have one or more of the following symptoms....
Jan 21, 2009 | Samsung HC-P4752W 47" Rear Projection...
Corner convergence for panasonic pt51hx40c projection tv
Yes there is a Service Code you need in order to set convergence and on this set it is not easy to enter! 1) Switch Antenna to cable (2) Set Sleep Timer to 30 mins,Exit menu Enter ch 124 (3) Now Press vol- on front of TV / A red CHK should appear on screen / NOW enter menu and turn sleep timer off / Exit again,now Press Power untill you see 0V00 press ch up untill you see 0V1 Then Press vol+ you should now have convergence Pattern on screen. To adjust use (ch- ch+ and vol- vol+) (cursor) moves to where you want to adjust (mute) locks place you want to adjust RTune changes R-G-B when done make sure you Save adjustments.
Jan 04, 2009 | Panasonic PT-47WX49 47" Rear Projection...
Samsung:pcl4515r
You may still one more resistor opened , samsung most of the time its 2 low ohms but can be 3 it will be same value as other 2. I think they are 2.7ohms or 3.9 How to Enter Service Menu for convergence Turn TV off Press Mute 1-8-2-power now you should be in convergence use vol- and vol+ to select an item Use mute and menu to adjust when done Press ADD to save adjustments made.
Dec 12, 2008 | Panasonic PT-51HX42 51" Rear Projection...
Rear Projection Samsung w/ convergence out
I believe it is mute-1-8-3 to enter the service mode, HOWEVER, I have also read that until the convergence problem is repaired, i.e. - depending on the configuration, either 2 individual IC's located on the lower board with 'playing card' size heat sinks or a simple replacmenet convergence board, adjusting the convergence through the service mode is comparable to "ripping the transmission out of your car to fix a flat tire". I myself have not gone into the service mode since I am still waiting for the replacement IC's - I get to do a component level repair.
May 05, 2008 | Samsung PCL545R 54" Rear Projection...
Service Manual for sp43t8-hex/shi - convergence problem
My sp43w6hpx needs the red pulled back in any one help with service manual
Dec 21, 2007 | Samsung HCN436W 43" Rear Projection...
Saving settings in service menu
Hi, I have a similar problem too on the SP47Q7HF. That one the lower level to match the red, and blue. Turn off the tv, and then restart, and still the colour runs off. Do you have a manual on the service mode adjustment? Or where to upload this info? I would like to try and adjust it. Thks
Sep 19, 2007 | Samsung HC-P4752W 47" Rear Projection...
Samsung HDT HCP4363W
you need to get the service manual for your tv the microcomputer needs to be replace use the test mode from off your remote control enter the numbers 0-6-2-5-9-6-menu do it fast ypou should see a display come at the bottom of your screen consult your service manual and reprogram your tv if this does not work as i say change your microputer at this time i do not have a schematic to give you a part number.
Mar 08, 2007 | Samsung TXM3298HF 32" TV
Samsung HC-P4752W 47" Rear Projection HDTV-Ready Television Logo
236 people viewed this question
Jerry Greenberg
Jerry Greenberg
