Question about GE 36 in. Profile JGP962 Gas Cooktop
Stoves 700CTH hob
My frameless touch control ceramic hob is flashing '7A' when it is switched on. There is a constant alarm beeping and the hob will not work
  • 2 more comments
  • copey Jan 28, 2008
    same problem stoves 700cth hob flashes and beebs A7 on display 2 yesra old hardly used have switched off power but problem comes back
  • cmbcleveland Oct 04, 2008
    I have the 900CTH with the same problem. Driving me mad!!! Let me know if you find the answer. cmbcleveland@ntlworld.com
  • Anonymous Oct 27, 2008
    Same problem. Have yoi fixed it ?
  • gary2882 Dec 14, 2008
    i have the same problem
I have a Stoves 900 CTH with the same problem. Its been like it for about 6 months and we're still able to get it going eventually.
If you turn the power on at the mains and leave it beeping for about 2 hrs then press the power on touch button. You should see all the "0."s flashing. When the flashing and beeping goes slow try pressing one of the hob buttons alot until the little dot illuminates next to the 0 then quickly lit the + button.
It sometimes works after 5 mins but other times it takes 20-30mins and is a real pain in the ****.
I did ring Stoves a while back and they quoted me £190 for the pcb but I hardly use it so just lived with it as it is but I finally had enough tonight and done a web search which turned up this thread.
I've just pulled it to bits to see if I could locate this "C17" but not 100% sure what I'm looking for.
Stoves 700CTH hob - 29792d1.jpg Is it the big silver thing in the center with 5B RVJ on it?
Posted on Oct 13, 2009
Hi, I am about to try a mod on my 700cth stoves toch hob. Apparently C17 on the PCB needs changing to a 1000uf 16v capacitor. I will up date on my findings soon.
Posted on Jan 15, 2009
  • cmbcleveland Jan 17, 2009
    Changed C17 for 1000uf 16v Cap and now works perfectly. took about 30 mins from removing from counter to cooking again!!! Cost 50p and a little time. Well done Flash.
  • cmbcleveland Oct 22, 2009
    To Scoobycity, yes the silver cilinder is the cap. Carefully remove with a soldering iron and replace with a 1000uf 16V cap (it may not look the same), you can get online or a maplin store easy enough. Make sure you take note of the polarity (marked on the cap). I did this fix a year ago and it works fine to this day. Good luck. Let me know how you get on. cmbcleveland.
Hi, this worked for me as well on a 900CTH. Has to be a design fault judging by the number of people with the same problem.
No idea what this capacitor does but a guess would be that it is the reset circuit for the processor. This is normally a simple CR circuit which holds the reset pin down so the processor resets on power up. Only in this case their design does not hold the pin down long enough hence increasing the capacitor from 220 to 1000 micro-farads increases the time constant so that the pin is held down long enough. The installed value probably works well initially but due to the heat on the hob the capacitor ages, capacitance decreases in value (a common issue with electrolytics) and low temperatures at start up exhibit lower capacitances hence the fault is, as reported, worse in cold conditions. So my additional advice would be to pick a replacement with a high temperature rating.
Posted on Apr 07, 2010
I have fixed mine with a new pcb £189.00 not cheap.
My ceramic hob goes on and off frequently(almost every two seconds) with clicks when I use it on. four stoves have the same problem. does any body know the reason or solution?
Could be one of your control knobs is not releasing fully which puts pressure on the pressure switch ang makes it spark and click.
Mar 22, 2014 | Cooktops
Hi I have a Samsung ceramic hob that when I have the oven on and cooking veg in saucepans it cuts out randomly displaying SE flashing I'm guessing its overheating but how can I fix this ? It makes
An SE error message on the display of a Samsung ceramic hob means the control panel sensor has been on for too long.
There are a few reasons why the sensor could be saying it's been on for too long:
  • Touching the key area for more than 10 seconds.
  • Leaving a wet cloth on the touch key area.
  • Spilling a liquid on the key area.
  • By touching 2 or more keys together. All of these can be fixed by turning the hob power off at the wall, then back on again.
Jan 30, 2018 | Cooktops
TOUCH CONTROL HOB (SCHOTT CERAM) GLASS CRACKED
Hi. Yes you can buy a new glass. Most of the come with frame top now. If you get me the model # I can look this up for you and get you an idea on cost.
Vic
May 18, 2009 | Cooktops
Cant switch on hob
gud day,the ceramic hob is very sensitive to operate if u not read the manual.after u unlock the switch go to the control of the hob wat area u want to operate by touching the sensor then if u see the zero # touch again the area,positive side to increase the heat 1-9 the standard control heat.some model & brand have a different operational procedure,try to read the manual 1st or check the voltage of the unit coz the ceramic have a 4voltage standard for different country. tnx gerbee
Jan 26, 2009 | Neff 23 in. T1443 Electric Cooktop
Got a diplomat ceramic hob with no instructions
If the KEY lock is on (key botton flashes when switched on) ... touch AND HOLD the lock symbol for AT LEAST TWO seconds until it beeps, then hold the on/off button for AT LEAST 2 SECS.
If the CHILD lock is on ([L] on all displays when switched on), then:
1)Hold the on switch for TWO secs min (unit swtiches on) ...then
2) touch AND HOLD the + AND - for AT LEAST 2 secs
3) touch the - button once again.
Jan 14, 2009 | Cooktops
Safety lock on Neff hob
I have a Neff T4344N0/08. I cannot stop all four hobs flashing - ie: I press the 'on' button all four flash, I then choose which one I want to use plus the number but they all keep flashing instead of stopping after the usual three or four. Please help - have I pressed something I shouldn't, perhaps a child lock?
Sep 27, 2008 | Neff 23 in. T4343 Electric Cooktop
Miele KM5753 Induction Cooktop - Error 30
I have a KM5753 with FE31 and it remains after a breaker 1 minute re-set as per instruction booklet - anyone seen that one?
Mar 01, 2008 | Cooktops
GE 36 in. Profile JGP962 Gas Cooktop Logo
1,023 people viewed this question
Top GE Cooktops Experts
Marvin
Marvin
Dave Harrison
80stech
Are you a GE Cooktop Expert? Answer questions, earn points and help others
