Question about Durabrand DUR7 Portable DVD Player
Battery Charging i plug in my DUR-7 Portable DVD Player but i can't get a charge light and the battery won't charge. it won't even work while plugged in. what should i do
  • 64 Answers
Perhaps one of the contact pins are slightly bent, best to remove the power lead from the wall, grab a magnifying glass ... and have a closer look.
A bent pin will appear to be out of line with the others.
The connector may also be worn in such a way that it will not make contact... no matter which way hold your tongue. :)
Take extra care when straightening the pin or pins.
Also a worn connector can build up a type of scum on the surface of the pin or pins, otherwise known as oxisidisation and corrosion or in simple terms ... RUST !
Carefully clean the pins with a Q tip dipped in methylated spirits and allow 5-10 minutes to dry, before reconnecting the charger to the DVD player.
The other possibility remains that the battery or charger may also be past it's used by date and may need to be replaced.
Posted on Jan 12, 2008
DUR-7 charging problem
Are you sure it is not the charger itself at fault here?
If you have or know someone with a multimeter get them to check if any voltage is present on the charger plug of the cord. Batteries do not suddenly stop they usually give less and less time in uptime mode before they finally stop altogether. I would suspect the charger or charging circuit.yes it can be fixed
Please rate my help++++Thanks for using FIXYA
Jun 03, 2010 | Durabrand DUR7 Portable DVD Player
Will not work with the DC adapter
Can u please give me a little more info?
I can see that it is not powering up?
Jul 04, 2009 | Durabrand DUR-1700 Portable DVD Player
Need help charging my mintek dvd player battery
The way the battery is usually charged is by plugging it into the player and plugging the player into the a/c outlet. Do not use the player, Just allow the player to charge the battery. The way you tell if the charging is working is the light on the front will usually be a red color and it will be steady color or blinking while charging. When the battery is fully charged, the light will turn green or turn off . This lets you know that the battery has fully charged.To test this try using the dvd player on the battery only. Play a dvd or cd and see if the battery is working properly. I hope this information helps you with your problem.
Apr 01, 2009 | Mintek MDP-1770 Portable DVD Player
Mintek Portable DVD Player
The overall life over portable DVD player batteries is terrible.
Here is some information on ordering a battery
Jul 23, 2008 | Mintek MDP-1810 Portable DVD Player
Mintek 8" TFT portable dvd player MDP1810
DO NOT continue to try to charge that battery. The company recalled those batteries because they explode or start on fire. Do a google search of "mintek" and you can read about the recall.
Jan 10, 2008 | Mintek MDP-1770 Portable DVD Player
DUR-7 portable dvd player battery life?
Wal-mart does sell replacement batteries. For this particular unit. However; in the future I would suggest researching a particular item before buying esp from Wal-mart. As Durabrand doesn't even have a website.
Oct 22, 2007 | Durabrand DUR7 Portable DVD Player
Battery not charging
Try connecting the Adaptor directly to the battery and charge it for 4-5 hrs and that should work...
Sep 02, 2007 | Durabrand DUR-1700 Portable DVD Player
Durabrand - DUR 1700
Hi Phylis, You don't mention the plug-in battery pack which slots into the 4 pin socket on the back of the player. If you don't have the battery pack it will only play when plugged in. Peter
Aug 15, 2007 | Durabrand DUR-1700 Portable DVD Player
Insignia PD10135 Portable DVD Player Battery won't work
I have the same unit, and had the same problem numerous times. I finally removed the battery and sprayed CRC electronic cleaner over the battery terminals as well as the units terminals. Put the battery back in hooked up the charger and it went green. It is playing as I write this.
Apr 05, 2007 | Insignia PD10135 Portable DVD Player
Durabrand DUR7 Portable DVD Player Logo
74 people viewed this question
Top Durabrand Televison & Video Experts
matt martin
matt martin
Are you a Durabrand Televison and Video Expert? Answer questions, earn points and help others
