Question about Motorola Mobility H700 Wireless Headset
Pairing Motorola H700
I just got a new cell phone and I want to use the Motorola H700 blue tooth that I have been using with my previous cell phone, but when I go through the pairing process it is asking me to enter a numeric passkey and an alphanumeric passkey but I do not have any of that information. Is there any way for me to either use it without entering that information or obtain the passkeys that are linked to my specific headset???
  • 6 more comments
  • Anonymous Mar 30, 2008
    Had the same problem and the "0000" pass key fixed it. Thanks
  • Anonymous Jun 27, 2008
    the passkey 0000 doesn't work. Any other suggestions?
  • Anonymous Jul 31, 2008
    need numeric pass key
  • Anonymous Aug 06, 2008
    I can't get it paired
  • frankiegd Aug 12, 2008
    i put my phone on dicover mode and it cant find the device, what should i do
  • delainad62 Sep 02, 2008
    I do not have the numeric pass key to pair my bluetooth with my blackberry.
  • Anonymous Sep 11, 2008
    i recently
  • orieboo Mar 01, 2009
    i can,t pair with my blackberry
The Default Key is 0000
Posted on Nov 04, 2008
    Genius:
  • 1,003 Answers
Use passkeys 0000 for both
Posted on Jan 14, 2008
0000 didn't work for me until I selected "alpha-numeric" passkey instead of "numeric", then it worked just fine.
Posted on Aug 12, 2008
What i found out with pairing with a blackberry the passkey is 0000 but you have to use the alt key before you enter the zero...so alt 0, alt 0, alt 0 then alt 0 then it would work
Posted on Feb 27, 2009
Hi, The passkey is 0000. That is four zero's then hit pair. If for some reason that doesn't work, I'm sorry. It worked on mine so I thought I would share. Lisa
Posted on Mar 04, 2009
Push in the "nipple" on the Blackberry 6300 when it asks u for the passkey and it will change to alpha numeric. Then type in 0000 and hit the enter button. Yes!!!
Posted on Sep 09, 2008
Thanks very helpful
Posted on Jun 10, 2010
Thanks the numeric key is 0000
Posted on Aug 04, 2008
  • mommy2dance Mar 21, 2011
    Thanks so much!!!! I was going nuts trying to find the paperwork that came with my device !!
2 Suggested Answers
  • 23 Answers
SOURCE: pairing my blackberry curve8310 to a motorola H700 headset
when pairing a handsfree device to your phone the typicaly generic passcode is 4 zero's (0000)
Posted on Mar 12, 2009
Cant conect to sgh t429
you must make sure your blue tooth device is in discovery mode ,to do this it just consists of holding the power button when turning the device on for 6 to 10 second once it is in dscovery mode you can pair the device by searching or add new device on your phone if the pair you will need a 4 digit pin or pairing code most manufactures of blue tooth devices use 0000,1234,9999 or 1111 i hope this helps
Feb 21, 2011 | Motorola Mobility H700 Wireless Headset
Need password to connect to my phone. Motorola bluetooth H371
Hi,it all depends. When you want to connect a blue tooth to a phone, You will need to switch on the blue tooth device and the phones blue tooth you are pairing with.
When pairing both device, you will ask for pairing code, You four digit numbers(default code(0000). and pair.
After pairing both device, you detected paired, you can now use the blue tooth device with your phone.
there are no special code for pairing Blue tooth device.
Normal codes used are any four digit, four numbers you want to use.(0000, 1234).
Hope it helps..
Thanks for using fixya...
Oct 27, 2010 | Motorola Mobility H371 Bluetooth Headset
Changed phones want to install blue tooth h700 but it asks for a passkey. Where do I fibnd the passkey?
The passkey is 0000 (four zeros). If you need instructions do the following:
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} First off, you want to have the H700 fully charged up and it's probably good to have the PHONE fully charged up too. Now turn off the H700 (the ring around the talk button should not be flashing blue every few seconds) then push the talk button for about five seconds, until the ring around it displays a purple color. Immediately let go of the button and flip open the tiny microphone extension. Now it's in pairing mode and you can leave it while you fiddle with the PHONE.
On the PHONE, you want to push the "OK" button to get to your main tools area:
Choose Settings, then choose Connection:
Now you'll be able to pick which type of connection you want:
You want bluetooth, of course, so pick that:
Now you can specify that you want to add a new Handsfree device (even though, logically, you should go to Setup in my eyes):
Select Look For Devices, at which point the PHONE will scan for available units in the bluetooth frequency spectrum and hopefully find your H700 bluetooth headset. Assuming it does, it'll cheerily report the news:
If your PHONE doesn't find the headset, I suggest that you run the scan another time or two. Also make sure that the H700 is still showing purple, not blue or flashing blue. That should be all you need to do!
Once the PHONE has found the H700 unit, you need to actually pair them, so don't stop here. Select the H700 and you'll be asked if you want to bond the two units:
You want to say "YES", of course, at which point the PHONE will ask you for the bluetooth passkey of the H700, which, like all Motorola bluetooth headsets, is 0000. Enter it:
Choose "OK" to proceed to:
The phone has saved the pairing passkey, now it'll disconnect and search for it again in regular connection mode:
Hopefully it'll still find it, and verify the PIN:
Now, look at the H700. Notice it's no longer in the purple "pairing" mode but has switched to the regular slowly flashing blue mode. You're up, running. I hope this helps and Good luck!
v\:* {behavior:url(#default#VML);} o\:* {behavior:url(#default#VML);} w\:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);} Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Please remember to vote 459e9de.jpg and leave a testimonial. Thanks.
Nov 02, 2009 | Motorola Mobility H700 Wireless Headset
Want to pair existing motorola blue tooth head set with new phone, but can't get headset to go into "pairing" (purple) mode.
The center button must be depressed with boom "closed" until it turns purple. Once it is purple, let go of the button and extend the boom. It should then remain a constant purple color and then be in "pairing" mode.
Aug 28, 2009 | Motorola Mobility H700 Wireless Headset
Motorola H700 won't pair with LG CU720 phone
You will need to enter pairing mode on your device. The H700 User Manual indicates that you do so by first turning off any previously paired device and opening the headset BOOM. The indicator light should light a steady purple while in pairing mode.
You may not need to turn off your phone if you do not desire this, you may be able to get by turning the blue tooth function off and on, on your phone and attempt to pair again.
Pairing Pin is likely 0000.
Dec 29, 2008 | Motorola Mobility H700 Wireless Headset
I am trying to program my nokia 2600 phone to my motorla h700 blu
First of all, the Nokia 2600 is not a blue tooth phone.
If you should get a Nokia phone that supports blue tooth your best bet would be to make sure any previously paired devices are turned off.
Then make sure that blue tooth is enabled on your phone. For most Nokia models its as follows;
Menu > Settings > Connectivity > Bluetooth > Bluetooth On
Then attempt to put your device in pairing mode.
Return to;
... > Bluetooth > Search Audio Enhancements
If your phone supports Bluetooth the phone should and device should pair after you enter the pairing pin, usually 0000.
Johnny_Nh, to answer your question, different Models are equipped with blue tooth when they are manufactured. Also, there are different versions of bluetooth, 1.0 and 2.0. If you have an older phone supporting Bluetooth 1.0 you will not be able to use a bluetooth 2.0 headset.
Dec 26, 2008 | Motorola Mobility H700 Wireless Headset
Motorola bluetooth pairing
1.Press and hold the Multifunction button in the middle of a boom headset while the headset is closed. The light will glow blue.2.Open the boom microphone and the blue light should remain on. If not, repeat step 1.
3.On the cell phone, press Menu > Settings > Connection > Bluetooth > Handsfree > New Device
4.Select H700 once a connection is detected.
5.The passkey "0000" is now entered to confirm the connection has been made.
6.The cell phone screen will now read "Bluetooth Connection".
Tips:
1.Provided you set the Bluetooth power to "On" after the initial connection has been made, the phone will automatically re-connect to the headset.
2.To set the Bluetooth power on - Press Menu, Select Settings, then Connections, then Bluetooth link, scroll to Setup and select that. Scroll to Power and chose Change. Scroll to On and press Select. The screen should now read "Changed: Power On".
3.Test Your Connection: Close the headset and watch for cell phone to say "Disconnected". Re-open the headset and the phone should be connected automatically and will now display "Bluetooth Connected".
please give good rating if the solution works.
Thanks for using FixYa.
Aug 09, 2008 | Motorola Mobility H700 Wireless Headset
Pairing h700 to sanyo s1
After your phone has found the H700 you have to tell your phone to pair with it. It will then ask for the code. Punch in 0000 and confirm. After a little bit the H700 will flash blue several times rapidly and then start blinking about every 5 or 6 seconds. It is then paired with your phone.
Apr 21, 2008 | Motorola Mobility H700 Wireless Headset
LG RUMOR
With the H700 BT headsets the pairing mode is different from other BT headsets. to put it in pairing mode you first hold the talk button on the headset until the purple light comes on.Right after the purple light comes on you have to flip open the headset for it to stay in pairing mode. From there you continue through the phone. It will ask for a password; that will be "0000". then connect.
Jan 26, 2008 | Motorola Mobility H700 Wireless Headset
I can not use my blue tooth
PUT HEADSET IN PAIRING MODE
1. Ensure the headset is turned off (indicator light not blinking and headset
boom is closed)
2. Press and hold the Call button. After about 4 or 5 seconds, the indicator
light becomes steadily lit in magenta
3. Release the Call button and immediately open the headset boom. The
indicator light remains lit in magenta.
If the indicator light is flashing in blue or not steadily lit when opening the
headset boom, repeat steps 1 through 3
Ensure that your phones blue tooth is active and looking for a new device
Jan 13, 2008 | Motorola Mobility H700 Headset
Motorola Mobility H700 Wireless Headset Logo
10,715 people viewed this question
Top Motorola Mobility Radio Communications Experts
Lawrence Oravetz
Dennis
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
