Question about Tomtom ONE GPS Receiver
Tom tom not working
Hve not used for few weeks plugged into lighter green light has come on but no picture
  • 5 more comments
  • Anonymous Jan 13, 2008
    When I turn the unit to the on position, the screen lights up but it is blank. I have to push the reset button every time to start the unit working properly.
  • boobybell Jan 15, 2008
    My screen is blank but is fully charged, i have tried the reset button for a few seconds then tried to switch it on, bit still the screen is blank, please help!
  • dpwebb01 Jan 17, 2008
    TomTom would not turn off, so I set it to turn off when the external power source was disconnected. Came back to it later that night and now it will not turn on.
  • Anonymous Feb 04, 2008
    Tom tom will not come on even though the green light indicates power is reaching the unit. Screen is blank and I am totally lost somewhere in Kent.
  • Anonymous Jun 29, 2008
    NO PCTURES GOT SOUND NO PICTURE
  • boxing2005 Dec 21, 2008
    I just got my TomTom One -- if I plug it into my laptop, will that charge the battery? For example, does it work like when I plug my ipod into my laptop to charge it? Or do I have to put it in my car and plug it in. Or does the darn thing already come charged?
  • ruach5 Dec 25, 2008
    had not used for weeks, plugged it in, no screen but the green light is on
    Novelist:
  • 158 Answers
  1. First , try a re-set through the 'reset' hole underneath the tomtom. 1 quick short press is all thats required. Unlike others suggest , you do not need to hold it in for anything longer than half a second. You should feel the switch 'click' as its a tactile switch. Don't press too hard as you can damage the switch and cause it to lock ON. Once pressed , try turning the tomtom on as normal. Sometimes a tomtom battery can drop below its normal "shelf" voltage ( normal is about 3.8 volts ). A tomtom charger has a protection circuit inside to stop or slow the current it gives out if there is a short. If your battery HAS dropped volts TOO MUCH ( less than 3 volts ) the charger can "see" the tomtom battery as a "short" and the charger therefore shuts down and doesnt charge the battery. You could leave the charger connected and HOPE that the very small amount of current it's putting out will eventualy bring the battery up over 3 volts. Once it is up near its "shelf" voltage ( called shelf voltage as that is the voltage the battery is at 'on the shelf' ie . when its not powering anything ) the charger will begin to charge as normal....... OR ... you can gain access to the battery and charge it from a bench power supply that has voltage and current meters. Once again , once the battery voltage gets something near 3.8 volts the normal tomtom charger can be used to charge it. You caould connect another normal battery to the tomtom battery just for a few seconds ( not recommended and can be a bit dangerous ) if the normal battery is such as a PP3 9v type it should bring up the tomtom battery to over 3.8 volts in a few seconds. The tomtom can then be charged as normal. .............. It is also possible that some internal IC's ( chips ) have blown inside the tomtom and unfortunatly this would require a specialist repair centre to replace them as they are really very very small and are not a normal soldering job. Good luck. ... if this post has helped you or interested you please rate the author.
Posted on Feb 05, 2008
  • 102 Answers
Press the reset button underneath the tomtom with a paperclip for a few seconds when plugged in. This could take half an hour of resetting every 5 minutes and sometimes does the trick straightaway. If it still does not come on there might be something wrong with it and you might need to get it repaired.
Posted on Jan 12, 2008
    New Friend:
Hi I have tomtom one gps when I turn on so on the screen theysay take the memory card out and put back I did this but still not working
Posted on Dec 10, 2013
Have not used for few weeks plugged into lighter green light has come on but no picture
Posted on Nov 02, 2008
Tom tom will not switch on when i try to charge it the led light does not come on i have hardly used my tom tom
What is your charging method? In car or house hold plug? Suggest that charger is not working (Green) if light on Tom Tom (at bottom near charger lead) is not lighting. Check your charger and see if you have an indicator light on it showing it is on. If yes, plug in Tom, then press and hold the "on" button for 15 seconds constinuously. Tom Tom should reboot.
May 01, 2011 | GPS
Hi, Tom Tom 710 has not come on for weeks.
it doesnt get better by itself. Despite having a green light doesnt mean it is charged. try changing the battery
Jul 05, 2009 | Tomtom GO 700 GPS Receiver
LG 42 LCD no sound or picture
Did anyone find out the solution for this??????? I have the exact same problem with my LG 32 LCD. I only had it for a year and a half, and the green light blinks a few times and it shows no picture. Not even a red light when the tv is off. The same thing happened a couple weeks ago and by some miracle it started working again.
Jan 28, 2009 | Televison & Video
Tom tom one v1 Loose power connector
If the problem exists both when you use the vehicle power connector and the usb cable to your computer, then you have to assume that the problem is with the socket on the One. If it's still in warranty, I would send it back to Tom Tom for repair. Contact customer support for repair information.
The link is as follows:
www.tomtom.com
Jan 26, 2009 | Tomtom ONE GPS Receiver
Green light blinking
The green light on the front blinkes and does not stop even after hitting re-set button.
Oct 26, 2008 | Mitsubishi WS-65513 65" Rear Projection...
Recently after working one day the next day when i tried to use mt tom tom 710 it wouldnt switch on but the mains light was lit when plugged into cig lighter
Try giving it a full charge. I used different model Tom Tom that would not turn on even if plugged in until after the battery was recharged.
Oct 10, 2008 | Tomtom GO 700 GPS Receiver
Unit will not come on green light is on and is docked to computer
tom tom kicked reset button[510]called customer assistance. use paper clip bent to a point turn unit upside down so ser# can be read you will see one gold ternimal on left side and about a dozen small terminals to the right just above last three terminals is a notch in plastic cover reset button is in middle of slot push with paper clip two or three times not overly hard.mine started working.when plugging to cig. lighter button kicked.easy fix hooray for TomTom.hope this helps.greetings from Music City.
May 29, 2008 | GPS
GPS Won't Turn On
www.batteryship.com
look up tomtom 510 - or whatever model you have
Order the battery..........comes with manual and tools to fix it
only 20.95
it works
cheaper than sending it in!!!!!!
These are genuine replacement parts!!
Laura
Jan 30, 2008 | Tomtom GO 510 GPS Receiver
Tomtom ONE GPS Receiver Logo
1,970 people viewed this question
Top Tomtom GPS Experts
LP
k24674
Marvin
Marvin
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
