Question about Xerox DocuColor 4LP Laser Printer
Can ping printer but jobs not received
Have Xerox Docucolor 4LP on a home network with 3 XP machines on a standard ethernet router, bridged to the net
All three machines can ping (via ipconfig) the Xerox without packet loss, but only one computer(PCStudy) can print to the printer, and only through the LPT1.
The other printers cannot print anything, tried configuring ports through COM1 and COM3, Xerox is set at, unique and static. The router recognizes the printer and all three PCs. Installed drivers on the other machines and they will print only if PCStudy is up and running. Any ideas?
  • Anonymous Apr 18, 2009
    Was the issue ever solved?
  • 2,072 Answers
Have you checked your firewall?
Often times, even though you can ping the printer, the firewall will block the data going to the printer.
Posted on Jan 14, 2008
I have got a Xerox Docucolor 12 printer, a Fiery X12, and a laptop running on Vista. I dont have any cables except the power cables and was looking for a list of everything I'd need to get it running...
There are 2 cables that go between the fiery and the printer, not sure where you can get these.
You will need to be running windows xp
connect to the fiery with an ethernet line
download the drivers, command workstation, and fiery remote scan from the xerox website
hopefully the fiery still has its software loaded otherwise post a request for a copy here.
Nov 11, 2010 | Xerox DocuColor 12 Printer
When i print one document on my xerox docu color 4lp on the printer display's this message "U6-4 Cycle power"
U6-4 sounds like an NVRAM error and could be a bad board.
I think they probably be the Main System Controller Board 160K58571 or the Engine Controller/MCU 160K60530
Item, Inc.
Aug 10, 2010 | Xerox DocuColor 4LP Laser Printer
How to hook n40 on a network
just add it to one of the router's lan ports..and after that access the tcp/ip protocol into the network card ...of the printer ..and choose to get an ip address automatically ..
This will add it into the network ..and all the other devices will be able to send jobs to its IP ..or just find it when you hit search for printer inside default gateway ..
If this do not work ..than you will have to configure the Ip and subnet mask ..and default gateway manually like this ..
the Ip will be the router's Ip +the number of the port if the router is .. the printer in number 3 port will be .. and the subnetmask will be : and the default gateway will be the router itself..
the dns servers will either be configured automatically and in this case will take the network's ones from the router ..or insert the ISP dns same as in the router ..
May 30, 2010 | Xerox DocuColor 12 Printer
Can I use Xerox WorkCentre 470cx on a wireless home network?
You can get a parallel print server and configure that.These may be hard to find though.
Jul 22, 2009 | Xerox WorkCentre 470CX InkJet Printer
Xerox docucolor 3535 116-321 error
Unplug the ethernet cable, If it does not come up with the code then.
Search for something like internet printing turned on somewhere.
That's a freaky code that normally is associated with some odd ball print job being sent to the printer, or something trying to access the network address. It is a pain sometimes to diagnose.
Mar 16, 2009 | Xerox DocuColor 3535 Copier
6125N won't print in network
If you can address the printer through CentreWare then your halfway there. Is now possible to print a test print via CentreWare if that works look at your p.c, driver setup.
Good luck.
Nov 15, 2008 | Xerox Phaser 6125 Laser Printer
Xerox DocuColor 4LP Laser Printer Logo
681 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
