Question about GE Profile Prodigy WPSE4200A
Wierd smell from washer
Smells electrical not sure if it could be the belt making this smell, machine still working but stops on rinse cycle then we skip to spin cycle and let it finish.
    Scholar:
  • 196 Answers
If the machine will run in wash but not in rinse then I would check the motor first. If the motor is getting too hot toward the end of the wash cycle it may very well have a fault in the foward windings. When in the spin mode the motor is reversed so may continue to operate.
Posted on Jan 12, 2008
White smoke coming from the machine, it was in the middle of the extended cycle. stopped machine and unplugged. Smells as though something burned.
Usually the first repair a Maytag washer needs is to replace the belts. They can wear out and smell.
The belts are located on the very bottom of the machine. They are not covered. If you pull out the washer about 2 feet and lean it back against the wall you will see the belts on the bottom.
If they have shiny parts, or one of them was sticking. You will be able to see if it is burned.
I've made a diagram to help.
The "main drive pully" is the belt that is most likely to be burned. It is also possible for a clothing item such as a baby's sock, to get caught in the pump. That being the case, the pump belt can burn.
If you replace the belts, which you should do if the machine is 10 years old. You must replace them with Maytag belts. This is important, because they are designed to allow some slippage. If you replaced them with belts of the correct size but not the right type, the machine will not work properly.
Of course, the machine can have electrical problems, but it is rare. Let me know what you find and I can advise you further. Happy New Year, Mark
Jan 02, 2011 | Maytag MAV3855A Top Load Washer
Dryer part, smells burnt and is extremely loud
If you notice a burningsmell in your washing machine, the cause could be any number of things. Regardless, this is one smell you shouldn't ignore. It's important to quickly diagnose the problem and find the solution.
The "Burning Belt" Smell
Older, top-loading washing machines use a belt drive to transport energy from the motor to the transmission and pump. The belt can prevent costly repairs to the motor or transmission by slipping, stretching, or breaking if there is a malfunction in the machine. If the belt slips, stretches, or breaks, it can cause friction and a burning smell, most likely a burning "rubber" smell.
The solution is actually quite simple: you need to replace the drive belt on your washing machine. You can call a repairperson or, if your washer is under warranty, the manufacturer. If you or someone you know is handy, you can replace the belt yourself. The belt is located either from the back access panel or from the underside of the washer.
Most new washing machine models are "direct drive." This means they do not use a belt. The motor is directly connected to the transmission. If you have a direct drive machine and your washer smells like it is burning, read on.
Electrical Problems
If your washer smells and you have a direct drive machine, it may be the motor, transmission, or both. If these are shot on your washing machine, the result may be an electrical burning smell. Both are necessary to run your washing machine and can be costly to repair. The first thing to do if you notice an "electrical" smell in your washing machine and not a "rubber" burning smell, is to unplug the machine and call the manufacturer or a repairperson.
An electrical burning smell may also be caused by a water leak coming into contact with electrical wiring. Both are major concerns and should be addressed immediately. A water leak can cause structural damage in your home and can short out the electrical wiring in your washer and cause additional damage to the machine.
Other Causes
Another more likely cause of a burning smell in your washer is overloading. Adding too many clothes to your washing machine can stress the motor or transmission, causing them to overheat or malfunction and emit a burning smell. For top load washers, overloading can cause the agitator to freeze or malfunction, stressing the drive belt and causing friction, which could emit a burning rubber smell.
To prevent overloading, know the size of your washer. They are measured in cubic feet. In addition, know how many towels, pants, shirts, and other items you can safely load. When it doubt, do smaller loads. Not only will this prevent overstressing the machine, it will also ensure clothes are thoroughly cleaned and rinsed.
Nov 07, 2010 | EuroTech Washing Machines
Washer stopped working and smells like it's burning
This would be the motor coupler that has failed common problem and easy to fix. There is a video ( whirlpool style) that will walk you thru the troubleshooting and replacement at www.appliancehelponline.com/servicemanual.html
Mar 27, 2010 | Estate TAWS850PQ
HE2 Plus washer will not complete the rinse cycle.
Hi!!! You best been usin he detergent if not you are in trouble..You have a sud built up..clean all the water out and go to sears and buy whirlout for he machine..tell them that you have suds and want to clean it with whirout..good luck..
Jan 04, 2009 | Kenmore HE2 Plus Front Load Washer
Smell in washer
Vinegar will fix this! Try pouring a quart of white vinegar into the washer, then run a cycle with no clothing in the washer. When the rinse cycle begins, stop the washer. Let it sit for about 30 minutes, then complete the cycle. That should do it! Afterwards, be sure to leave the door open to air dry it.
Oct 27, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore stackable washer and dryer
check the belt, pulley, & idler pulley assy.
Jul 20, 2008 | Kenmore 98702 Stacked Washer/Dryer
Washer hums on rinse cycle
It sounds as if you are using WARM water for the wash cycle since your complaint begins with the rinse cycle. The rinse cycle generally uses COLD water, so I must deduce that your washer is not filling up for the rinse cycle. The humming sound is likely coming from the fill valve being starved for cold water.
Investigate your cold water supply to the washer and if you have good supply, you may want to replace the fill valve.
Let me know what you find...Thanks for contacting FIXYA.com
May 27, 2008 | Amana NAV8805EWW 3.3 Cu. Ft. Elustra Tub...
Frigidaire GLTF1670ASO is cycling fast and not spinning
Hi , try to check timer small motor .,also available in appliances store.
Feb 15, 2008 | Frigidaire GLTF1670A Front Load Washer
Washing Machines Logo
149 people viewed this question
Top GE Washing Machines Experts
Marvin
Marvin
geapptech
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
