Question about Foxconn WinFast K7S741MG Motherboard for AMD Socket 462 CPU (K7S741MB6L)
OS won't work with RAM upgrade
I upgraded to 1g RAM with PNY DDR PC3200 400/333/266 stick, OS wouldn't run until I removed the 512m stick already in the first slot. Things worked fine, until I decided to add another identical 1g stick to other slot, now OS will not run. Are there any settings I can change to make this combo work?
  • kathypete Jan 12, 2008
    The combo I'm trying to make work is 2 x 1g sticks of RAM. Will this work, or is it too much for this motherboard to handle?
Hi !
if u wanna upgrade RAM ,ur RAM should be of same capacity in both slot. i mean to say if u wanna use 1 GB....then put 512 & 512 or else put single 1 GB. But u cant use 512 in one slot & 1 GB in another slot at a time. if u do the combination like that ,it will never work.
--APARNA (Mumbai)
Posted on Jan 12, 2008
I have this ASUS P4GE-MX Motherboard. I want to upgrade my ram from DDR 256 MB TO DDR 1 GB. For temporary purpose, I tried another 256 DDR ram with 400 MHZ, but I had some problem with booting my system....
Hello, The Motherboard's specifications mention that it uses DDR Ram, while the FSB runs at 400MHz. That means that any kind of DDR memory will work up to the maximum of 2 GB (it has 2 slots, so it's up to the max of 2x1GB DDR sticks).
There's no issue with the speed, actually the faster you can get the better results you will have. Try looking for 1GB DDR 400MHz (preferably two of them, if you want to max out the capacity and since it's kind of cheap to do so).
The one you tried and didn't work, might be due to a faulty RAM module.
Mar 13, 2011 | ASUS P4GE-MX Motherboard
Will pny pc2-5300 work with a emachines t5082
Ships with
512MB DDR2 (1 × 512MB), 533MHz (PC4200)
Expandable to 2GB
2 DDR2 Slots (Total) | 1 DDR2 Slot (Available)
recommend
512MB PC2-4200 M-533D-512BD10
Aug 24, 2010 | E-Machines T5082 PC Desktop
Dell Dimension 4600 desktop memory upgrade
well first the mother board needs to be capable of handleing that much memory you can check that by going to the dell website and checking the specs on that model pc or mother board if the bios isn't recognizing it the chances are it won't but take out the 512 stick and just try one of the 1Gig if it does recognize that then try the second stick if it doesn't recognize them both then chances are it can't handle that much memory.
Oct 07, 2009 | Dell Dimension 4600 PC Desktop
I have an asus k8v-mx motherboard running only 512 mb of ram what type of ram would suit this mother board and could i fit a 1 x 2mb ram instead of 2 x 1mb?
Dear Sir,
*********** board is Asus old p4 Mother board.It supports maximum 1GB RAM of DDR 400(DDR1). According to your post your computer having only one 512 MB working RAM. If you want good purformance you can upgrade your computer by purchasing another 512MB DDR400 RAM and install it on another RAM slot.If your computer have only one working RAM slot,you can purchase 1GB DDR400 RAM & install it on older RAM place. I think it solves your problem.if you have any problem come back with more information. I will try to assist you more accurately.
good luck
Aug 05, 2009 | ASUS K8V-MX Motherboard
Added 2g to a dell dimension 3000, only 1g recognized
Dell has a really good support site. You log on, enter your service tag number (on the top of side of your PC) and they will tell you exactly how much ram you support, the type of ram needed and how many slots it has. If it was a matching pair then it should be working, unseat it and reseat it, it may not be in all the way. If still don't show then put it back in the old computer and see if it reads it. If not then the RAM stick got damaged during the move. But no doubt you should be able to handle more that 1GB of RAM. Good Luck, let me know if you have any questions.
Please rate this solution.
Apr 13, 2009 | Dell Dimension 3000 PC Desktop
Which memory ram for amilo pro v7010
http://www.fujitsu-siemens.ru/Resources/123/2080773523.pdf
Here's a link to the Data Sheet with the specifications to that Laptop in Adobe Reader format.
Looks like your Laptop came with either 256 or 512 MB of DDR SDRAM and it is upgradable to 2 GB of DDR SDRAM.
You can check to see exactly how much RAM your computer came with by going to Control Panel, double-click System and it should tell you how much RAM you currently have in the System Properties box.
The motherboard has 2 slots for RAM, you you could add a second 256 MB or a second 512 MB stick of RAM. Or if you wanted to upgrade to the 2GB of maximum RAM this computer handles, then you can take out the RAM chip(s) that is installed and install two 1G DDR SDRAM.
Jan 31, 2009 | Computers & Internet
Want to upgrade ram to 1gb
Kingston Value Ram will do, nothing over 533mhz
regards
Nov 24, 2008 | EliteGroup P4M800-M7 Motherboard
Upgrade memory in a Xerox 7400.
Unfortunatly you have to have the memory stick from Xerox.
Aug 07, 2008 | Xerox Phaser 7400DN Laser Printer
IBM thinkpad g40..i want to upgrade
To upgrade your CD drive there is a screw on the bottom of the machine that holds it in place. Remove this screw and the drive will slide out. I buy most drives for my customers and shop from Ebay. I've found that there are some very good vendors with good prices and warranties there. Now for the memory. The memory you need for your machine is PC2100, and 1g is the max. I mainly use Kingston or Infiniton. Both of these are good chips, and there are other good chips out there. I suggest that you use two 512mb chips that are the same make. I've found that sometimes two different chips will create a conflict with each other. The memory is located under a panel on the bottom of the machine. For memory I use pricewatch.com If you have any other questions please fell free to ask.
Jul 21, 2008 | IBM ThinkPad G40 Notebook
Foxconn WinFast K7S741MG Motherboard for AMD Socket 462 CPU (K7S741MB6L) Logo
306 people viewed this question
Top Foxconn Computers & Internet Experts
Alun Cox
Rommel Balcita
David
David
Are you a Foxconn Computer and Internet Expert? Answer questions, earn points and help others
