Question about Performance Teknique ICBM-782 Car Audio Amplifier
Bridge a not bridgeable amp
What would happen if i bridge a not bridgeable amp
  • 102 Answers
It will probably blow a fuse or blow up completely.
When the output stages ar not lifted from ground
as is the case in a bridgeable amp bridging cannot
be done.
Posted on Jan 12, 2008
6ya staff
SOURCE:
I have a kicker comp s with 4 ohm rating, two posotive and negative conections. and a kicker cx300.1 also with two positive and negative connections, the manual only shows how to wire a 2 ohm sub use one...
Its depends, if your bridging the amplifier, you will be using one channel(the bridgeable cchannel , your two 4ohms subs will turn into a 2ohm bridge one negative out of one sub and a positive out the other one then you conect the neg to pos between subs (ohms Law). To your bridgeable amp channel, your amp must be 2 OHM stable on the bridge channel.
Feb 08, 2018 | Car Audio & Video
How to bridge a 1 channel 1000 punch 55amp
You can not bridge a 1 channel amp. Bridging is when you combine the output of a bridgeable two channel amp into one channel, typically to power a sub woofer.
Feb 13, 2012 | Rockford Fosgate Car Audio & Video
How do u bridge a 4 channel amp to 1 ,12 in.sub?
first of all is it a bridgeable model? if yes i guess u can only bridge to 2 channels. if u bridge those 2 to 1 u will blow ur amp... refer to user manual - search web and download pdf file!
Feb 07, 2011 | Alpine Car Audio & Video
Can an explore 4020 amp be bridged?
Well if it's a multi channel amp it can definately be bridged. Yes, and from what I've read it is actually bridgeable at 2 ohms per 2 channels.
May 31, 2010 | Rockwood X-Plore AMP-4020 Car Audio...
Can i bridge the 4 ch. amp to 2 chnl.
Hello bdawson,
Maybe. Some, but not all, 4-channel amps can be bridged. You'll need to provide a specific brand and model number for a more definitive response.
On many bridgeable amps, the connections are shown right on the output terminals, usually the "+" of one channel and the "-" on another channel. The connection diagram in your user manual may also show which channels are bridgeable and the appropriate connections. Some amps may support what they call "tri-mode", powering both full-range speakers and subs at the same time.
Using a multi-channel amp with the channels bridged to power subs is a compromise. While you'll get an increase in power, it usually isn't as much as you would get from a monoblock. And fine tuning for the best sound is more complicated, balancing the filters and crossover so that the correct frequencies are sent to the appropriate speaker.
Hope this helps.
Jun 16, 2009 | Car Audio & Video
Ccan it be bridged with a 5 ohm subwoofer?
Hello cameron_cran,
The information I found on the amp is that is a 2-channel and is bridgeable. It is stable in bridged mode to 4 ohms. You should be able to bridge a single 4 ohm sub without damage to the amp.
Hope this helps.
Apr 22, 2009 | Pioneer GM-X322 Car Audio Amplifier
Bridging the Warrior IS600 Amplifier
No this amp can't be bridged but you can use a third party component that allows any stereo amplifier to be bridged. Try an electronics retail store such as Radio shack or similar for such a device.
Mar 04, 2009 | Audio Players & Recorders
Bridgeable vs not bridgeable
All amplifiers are bridgeable. The bridge setting is for driving a large speaker by using the power output of 2 or more channels. The power will be summed if a bridge is made.
For example, if you have a 800W, 4 channel power stage, you can connect 2 component speakers in the channels 1 and 2 and bridge the channel 3 with the 4 to drive a subwoofer.
Feb 14, 2008 | Car Audio & Video
Is it not bridgable
This amp isn't bridgeable. It's a mono amp (only one channel). You need two independent channels to bridge. Some mono amps are bridgeable if you have two identical amps but I don't think Kenwood recommends that with this amp.
Jan 27, 2008 | Kenwood KAC-9152D Car Audio Amplifier
La1498 amp
If the amp is bridgeable then u should see lettering where the speaker outputs or the channels are and you will a symbol saying bridged and then u can see a + and - symbol with lines going to the other channels. In other words they call it bridged because you are jumping from one speaker output to the other, usually bridging an amp consists of Left - to Right + or vice versa.
Jan 21, 2008 | Legacy Audio LA770 Car Audio Amplifier
Performance Teknique ICBM-782 Car Audio Amplifier Logo
183 people viewed this question
Top Performance Teknique Car Audio & Video Experts
Pierre Laplante
Robert Rankin
Jay Plesset
Are you a Performance Teknique Car Audio and Video Expert? Answer questions, earn points and help others
