Question about LG LSC183VMA Split System Air Conditioner
Air con does not run
I have a split system air con that is gassed to correct pressure but when it is turned on both the high and low pressure sides begin to drop to about 15 psi and then unit turns off . both taps are open . its a reverse cycle model that has just been sitting for about 2 years.
    Master:
  • 619 Answers
The compressor valve weak
Posted on Jan 12, 2008
2005 mitsubishi endeavor blows hot air.
Some times, it can be many causes
settings, gass scape from system,ac relay out of range
Anyway, read pressure of system high pressure, is good and low pressure is good too make vacuums to recommend psi put gass
Mar 10, 2017 | 2005 Mitsubishi Endeavor
Lg split system wont stay on
When the freon is low the unit will start. When the compressor starts the low pressure side drops and shut it off as the high pressure rises. The low pressure switch shuts off to protect the compressor when there is not enough freon to carry the oil to lubricate it.
Oct 18, 2014 | Heating & Cooling
R-22 home condenser unit low side and high side pressures when running
Pressures look good but to know if it is charged correctly you have to do a sub cool or superheat to know for sure. Rule of thumb is if turn unit it on let it run 10 minutes. If the suction line sweats and is cold. Might be proper charge.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/michael_70df8fb57a5e233e
Jun 24, 2014 | Ruud Central System Air Conditioner
Please help me reset conia split air con ca2422
If you need to reset a pressure switch...then the refrigeration system needs to be checked. High or low switch looks like about a 3/4 inch Diameter plug with 2 wires & a red manual reset switch in the middle.
Dec 13, 2013 | Heating & Cooling
High low side pressures and sight glass contains lots of bubbles
The system has a lot of air in it. If u haven't had any AC wk done on it that mean there is a leak in the system. System must be evacuated, pressurized & find the leak. Repair the leak, vacuum air from system & charge w proper AC gas. SPECIALIZED EQUIPTMENT & GAUGES NEEDED. good luck
Jul 28, 2017 | Cars & Trucks
Hi, The air con in my 2003 Audi A6 1.9 tdi 130 is blowing warm air the air con rad is fully gassed and all fuses are ok . Thanks in advance for any advice on how to fix
The only other thing then would be if the compressor is turning, engaging, and the cooling fan working properly. You should either be able to see the compressor clutch engage, as the switch is energized, or at least hear it click loudly when the switch is energized. If it is not, then there are sensors for the low pressure/high pressure line to tell the compressor when to function, that also have to be checked.
As the engine runs with the compressor turning, one line should be hot/warm, the othe,r (larger diameter hose) should be cool/cold, if the system is working properly.
If the compressor is turning when you have the A/C turned on, then see if the cooling fan is running as well. It must run to remove the heat and cause the process to function properly.
Mar 27, 2012 | 2003 Audi A6
We have a 2007 CX7 and the air conditioning is not working well on either recirc or outside air in low ambient temps. When idling at the lights the air con becomes worse. There is no belt sqeal, and I dont...
When you have a moment pop the bonnet and look for the air con compressor run by a automotive belt on the side of the engine. Get the engine running at idle and then get someone else to turn the air con on whilst you watch the compressor. As the system is turned on the compressor clutch should engage and the unit should start turning, if this isn't happening there isn't enough pressure in the system (leak or just low on pressure) Get to your local air con guy and they will pressure test for leaks. Air con system is run on pressure, so that is really the issue you need to rectify
Note:- Manufacturers put the air con rad infront of the engine rad so stones get to that first, check the condition of the front rad through your bumper
Feb 19, 2011 | 2007 Mazda CX-7 Grand Touring
System 3 in-door with system 4 out door inverter. all in door unit show error code CH24 pls help
CH 24-Splits and Multi Splits = High or low pressure trip. Low at 1 bar High at 35 bar check pressures. Multi V = High pressure trip.
Nov 17, 2010 | LG LS-L1210CL Mini Split Air Conditioner
Rplacing an AC compressor on a 2002 Volvo S70
will be ok compressor will not operate until system is gassed pulley will just freewheel . the oil will be put in when system is gassed a pressure switch in the air con pipe prevents it operating until at correct pressure
Dec 06, 2009 | 2000 Volvo S70
Sanyo split high pressure side tube icing
ok, on these units, if by high side line you mean the small tube going from outside to inside, that tube is actually on the low side, the metering device is in the outdoor unit. If you shut the unit down, let everything thaw then restart and find that small tube is freezing up right at the outdoor unit right away, my guess is its low on charge. I see that you put some in, make sure it is the right knid of refrigerant. they do not hold alot. Where is your suction pressure running. If you put 2 to 3 pounds with no change, you may have overcharged but that is telling you that there is a restriction in the line inside the outdoor unit, probably the filter if it has one, or the metering device itself. Let me know what you find.
Jun 16, 2009 | Sanyo Split System Air Conditioner
LG LSC183VMA Split System Air Conditioner Logo
204 people viewed this question
Top LG Heating & Cooling Experts
Tim Whalen
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
