Question about Motorola Mobility RAZR V3xx Cellular Phone
Won't turn off!
I went to go turn off my phone..so i held down the end button and when i saw that it was turning off i shut it. when opened it up like 20 min. later it was a blank white screen and i can't get it to turn off... or on for that matter. help!
The first troubleshooting step suggested would be to remove the battery and put it back after a while and then givin it a try..
Posted on Jan 12, 2008
6ya staff
SOURCE:
IPhone 4S won't turn on
Try holding down your Home Button and your Lock Button at the same time for about 10 seconds or until you see the apple logo. This will restart your phone and should resolve your problem!
May 01, 2013 | Apple iPhone Cell Phones
Blank screen even after recharging
Sounds like you need to turn it on,just hold down the power end button for a bit and it should turn it on.They can shut down on their own.
Feb 06, 2013 | Net10 Motorola W409G Prepaid Camera Phone
IPod won't turn on
Hi there, i only see problems and no solutions:
here is what i did:
1. Plugged in iPod with USB to PC.
2. Opened my computer and saw that iPod was there in the list (Devices with removable storage).
3. Ejected the iPod (Use the option "Safely Remove" from the notification area in the bottom right next to your Windows clock)
4. made sure the hold button was off and then held down the Menu button and middle button at the same time for five seconds.
My iPod now works - i think its an issue with the battery charge falling too low - at least in my case :)
Good luck and let me know if this process worked for you!
Sep 12, 2012 | Audio Players & Recorders
My dell inspiron 1545 won't shut down went i click on the shut down icon it won't turn off .
Hold down the power button for 10 seconds. That will hard-shut the PC. Once that is done, fire it back up, and try again. Somethimes, windows will act goofy shutting down. Especially Vista when it is left on too long without shutting it down.
Jun 20, 2011 | Dell Inspiron 1545 Notebook
My little buddy won't turn on, it's charged, plugged into computer. green light won't come on at all. I held the power button on for 10 -15 sec with no response.
I have 2 of these devices. Try using a cellular phone charger with the same plug at the end and plug it in. I have waited 5-10 minutes after doing this and they have come back to life and turn on. Maybe it will work for you.
Lewis
May 14, 2011 | Insignia GPS
Hey, my drop saw wont lock off the sliding arm when i pack it up an put it in the ute. i turn the handle full tighten an still slides freely?
there is a tube underneath and a lock mechanism. what might have happened is the lock has spread open and not putting enough pressure on the slide. Unplug the tool and turn it over and you will see the tube and lock. The lock is held in place by a phillips head screw and if the end is spread you can "GENTLY" squeeze it shut, reassemble and I think this will take care of your problem, also look for excessive wear on the lock and if so turn it 180degrees and try it that way. Let me know if you need more help.
Feb 27, 2011 | Makita 10" Dual Bevel Sliding Compound...
I have a small ceramic tile saw. I have
Look for a button that you can press to lock the shaft in position. When you depress the button, you may still have to revolve the blade and shaft until the lock engages the shaft. Then unscrew the bolt from the shaft. Some others have an Allen wrench well in the end of the shaft, and you can insert the allen wrench to hold the shaft while operatiln the wrench to loosen the blade. Some others have a slot in the shaft end for inserting a slotted standard screwdriver for holding the shaft while the wrench is used to loosen the blade.
One of these methods will be available to you!
Best regards,
--W/D--
Nov 09, 2009 | Saws
The control lock light is on
there is a button on the far rt of the face of the machine...you hold that button down. the button is called end of cycle signal.
ann
Jan 06, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Motorola Mobility RAZR V3xx Cellular Phone Logo
Top Motorola Mobility Cell Phones Experts
vince
Lawrence Oravetz
Vernon Taylor
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
