Question about Mitsubishi VS-4543 45" TV
VS-4543 Mitsubishi 45" TV
My TV show a red gosting or how ever it's call double image.
I found out that on the main PCB one of the coil (L8W01) was burn out and also the trace that connects to VR connector pin 1to resistors R8W45, R8W05, R8W09,R8W01, and C8W02 location. It looks like it is grown point that was also burnt.I don't know if thoughs components are still good or not due to the fact that I don't know the value of it. I had replace the burnt coil and retrace the connection of the burnts trace. The picture still has the same problem. (Gosting or double image).
  • Acqra Jan 17, 2008
    Terryfic, I had change the red convergence IC. I don't know it I had
    change the right one. May you or any one show me where the red
    convergence IC is located. Also you had mension both IC. What's the
    other IC? I am still have that red gosting / double image.
    Genius:
  • 1,694 Answers
Replace red convergence IC,both IC's for solid fix
Posted on Jan 12, 2008
  • Vista Electronics Jan 17, 2008
    Acqra,
    What part # and board location for IC's?
    Compare good resistors in good circuit with bad resistors...use
    ohm meter for correct values verification.....
    Use good quality convergence IC's.........
    Get some tech assist locally,if it is available......................T.
Blank screen and no audio on Mitsubishi vs 4543 when ps3 is connected through rca cables. other electronics work fine.
Check and replace the main power regulator [SMPS] board to your TV. Contact any service technician, or the authorized service center for Mitsubishi. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy.
Mar 12, 2014 | Mitsubishi VS-4543 45" TV
I have a Mitsubishi vs-4543 tv that when powered
check the power supply section.. probably the electronic component got problem.
Jun 04, 2009 | Mitsubishi VS-4544 45" TV
I have a vs-4543 picture only works part time sound always works
most likely bad solder connection or cold solder connection which is making contact after the set is moved or vibrated doe's this happen right away
or after the set is warmed up
May 07, 2009 | Mitsubishi VS-4543 45" TV
Mitsubishi VS-5071 rear projection turns on, has audio but no video
That is a VZ3 chassis, similar to Mitsubishi models Ts-4545, Ts-5045, Ts-5545, Vs-4543, Vs-4544, Vs-5043, Vs-5044, Vs-5047, Vs-6043, Vs-6047 and has common failures in the vertical circuit, specifically vert Ic401 which is a La7845 which is usually caused by defective C402 100uf 50v and/or open 1.2 ohm 2 watt R510 next to FBT.
If not that check C268 off Q215 on signal board 22mf/50v and Ic200 on signal module Cxa2025s. However the vertical failure is more likely.
Bill
Sep 10, 2008 | Mitsubishi VS-5043 50" Rear Projection...
Mitsubishi VS-4561 picture curved inward
Its Your Convergence Chips!. And Maybe a few Resisters!. Common Problem with this kind Of Set!.....
Jun 30, 2008 | Mitsubishi VS-45607 45" Rear Projection...
Red convergence wont move
if the red line is blurry and you have adjusted the screen focus control and does not work then you prob have a bad red CRT or bad red CRT fluid.........
convergence STK have nothing to do with the red being blurry
Dec 09, 2007 | Mitsubishi WS-55809 55" Rear Projection...
MITSUBISHI VS-4543
PVAT!!Look for bad connects--start w/easy first. Power supply,then vertical IC pins,then regulators.Take your time,be thorough.
Oct 01, 2007 | Mitsubishi VS-4543 45" TV
Mitsubishi vs-4543
Most likely the convergence output IC has shorted out and has overloaded the convergence power supply, which has stopped working. The computer senses that the convergence power supply is not running and shuts the set down. The convergence IC should be replaced, the power supply restored and the convergence circuits realigned by someone experienced in Mitsubishi projection sets. When I do a housecall for a set like that I charge $150, but shops in your area will vary so ask around.
Aug 04, 2007 | Mitsubishi VS-4543 45" TV
TV turns off a second after turning on....
You have a high voltage shutdown problem, look at the threads here on Mitsubishi and you will find your answer.
Dec 09, 2006 | Mitsubishi VS-4543 45" TV
Televison & Video Logo
143 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
